#562 (permalink) |
![]() Join Date: 26th February 2008
Thanks given: 5
If you want the best mpg, use a 0w-20, but they are really expensive and the car is likely to burn so much that it will not really save you any money overall. Probably best to go for a 0w-30.
http://www.opieoils.co.uk/c-652-0w-30.aspx All of those are good oils, but the Gulf and Redline are the best ones. Cheers Tim |
#563 (permalink) |
![]() Car: 2006 1.8 5 door, Black
Tim one more question that i can't find answer for, Im gonna go for Motul 8100 X-Clean 5w30 but there's also X-Clean plus 5w30 which one should i choose?
Both are ACEA C3 - API SM/CF and be used instead of ACEA A3/B3 or A3/B.4. (shell(probably crappy) that i used was A3/B.4). |
#564 (permalink) | |
![]() Join Date: 12th September 2012
#565 (permalink) |
Thanks given: 5
Either are fine, the difference is the VW504/507 spec that the X-Clean plus meets and that doesn't affect your car.
Cheers Tim |
#566 (permalink) | |
Thanks given: 5
Full synthetic and and a Hamp filter is fine, there's no need to go for a K&N unless you really want one. Cheers Tim |
#568 (permalink) |
Thanks given: 5
The materials used in them, giving the PS a higher flow rate, but for an unmodified road car that isn't important.
Cheers Tim Last edited by oilman; 12th September 2012 at 14:51. |
#570 (permalink) |
Drummers Do It Better
![]() Car: 2007 CTR Black
Thanks given: 90
Eneos
Hi All!
Personally I have tried a couple of oils and found that ENEOS Racing oil suits my FN2 the best. The car was needing a top off too often ( imo) I drive my car quite aggressively considering how people drive here in Greece. The hot summer climate here doesn't help at all. Found the car running smoother and top off much, much less. I think the ENEOS is best suited for the Honda engine. My FN2 is: 2007 07 plate Hondata Flash Pro set at the simple set-up no other engine mods just installed the Eiach camber bolts (spot on) Best regards George |
#571 (permalink) |
Love Mi-VTEC!
![]() Car: Black 2008 Civic TypeR GT
Thanks given: 242
Hi Oilman,
Just want some quick advice on something. Just about to top up the engine oil on my 2008 CTR (bought some Fuchs Titan Race Pro S 5W-40 from Opie a couple of weeks ago after your advice). I'm just wondering, is that okay to add if I have something different in at the minute? I'm assuming it's currently running 0w30 as per the handbook. Wasn't sure if this os okay to mix? Thanks, |
#572 (permalink) |
Thanks given: 5
Hi
Thanks for the order. Yes, it's fine to mix oils, so no problem in using the Pro S for top ups. Cheers Tim |
Thanks to oilman from:
#574 (permalink) |
![]() Car: 56 1.8 I-VTEC SE
Thanks given: 22
I had to do an emergency buy from a shell garage. I ended up buying 5ltre of the shex Helix Ultra 5w40. Used just over 1ltre.
Is this oil ok for my car? Civic 1.8 SE on a 56 plate. 54K on the clock. When I got the car I took their service plan also. I suspect they use really cheap oil. I have one service left. My plan is to let them do the service (its already paid for) then after a week or so get my local garage to do a engine flush. If the Helix 5w40 is ok I plan to buy a couple more litres and a UFI filter for after the flush leaving me with a litre topup. Does this sound ok? How much oil is required for a oil change? Thanks |
#575 (permalink) | |
Thanks given: 90
#577 (permalink) | |
Thanks given: 22
Thanks Tim. First time I've ever had an oil light come on and bricked it a bit. The 5ltre from shell garage cost me £47 so would like to make use of it.
Whats your thoughts on a engine flush after running a week with whatever Arnold Clark use? Quote:
#578 (permalink) |
Thanks given: 5
Yes, make use of that 5w-40. You should find that it won't burn much as the garage was probably putting in a 0w-30 or 5w-30, which burn off easier.
No need to flush (and flushes can be too harsh), just make sure the oil is nice and warm when it's let out. Cheers Tim |
#579 (permalink) | |
![]() Car: 2007 HCH II, Galaxy Grey
Thanks given: 2
I will second the idea of using the ENEOS products. I have used for a couple of years the 0W20 grade and I am more than satisfied. |
#580 (permalink) |
![]() Join Date: 21st May 2012
Thanks given: 1
hello, how is TRIPLE QX 0w30 Fully Synthetic Engine Oil 5Ltr?
Similar Threads for: Oil advice and recommendations here
| Mobile recommendations | apemonkeyman | Any non Civic chat here please! | 22 | 6th July 2007 16:48 |
| Cleaning the exterior - recommendations *** | Fedorov | Cleaning | 21 | 28th January 2007 21:14 |
| Speakers Size specs and recommendations for speakers needed | phuket | Ipods, MP3 Players and ICE | 1 | 3rd January 2007 09:38 |
| Car Seat Recommendations? | TheBull | Any non Civic chat here please! | 3 | 2nd November 2006 14:38 |
| UK Satnav recommendations please | Fedorov | Any non Civic chat here please! | 17 | 6th September 2006 21:33 |
