| This thread is about: 1.8 Dipstick levels - what are 'high' and 'low'? (merged), it's in Engines and Transmission at the Honda Civic forum Civinfo; This may seem stupid, but the maual refers to the upper and lower marks on the engine oil dipstick the queston is which are the ... | ||
12th June 2006 1.8EX
Big blushes |
#4 (permalink) | ||||
****EDIT - huge apols - wrong button to merge the threads |
yep - I found out (the hard way...
but I patched it up as best I could - do you think anyone will notice? merge thread / merge posts.... d'oh! |
Big Civic fan
ok, tanks for clearing tha up. oil is fine then. So the 3rd marking is nothing to do with oil level. Excellent.
Thanks |
Urm...does anybody know how to read the 1.4-DSI dipstick?
It seems to have 2 "holes" in the dipstick, but my oil is way above the top hole, so it's not like they're man and min. |
It seems a bit late in the day to worry about how your dip-stick reads. If the engine is'nt knocking or smoking, you should be ok.
#12 (permalink) | |
The answer is on page 299 in my hand book. It says the oil should be BETWEEN the upper and lower marks on a 1.4! "Sex appeal - please give generously!" Charles H. |
To be honest, I didn't have time to go through the handbook, so I will do that. However I did check the index and it isn't in there! But cheers - I might get it looked at because it's quite a bit over the max, and I haven't put any oil in it!
The stealer said that knocking noise from the engine was normal! |
#14 (permalink) | |
It was my neighbour banging on Millie's roof, wanting to go for a ride. "What impresses me is the way that Americans obey their children!" Charles H. |
#15 (permalink) | |
#16 (permalink) |
Yup, cheers elfa.
I'm going to check the dipstick in about half an hour - once I go for lunch. As even last time I checked it the engine was slightly warm (although had been off for 3hrs). But when I last checked it, the measurement was about half over maximum. To be honest, I never checked it before always thinking that the oil light would save me, until I found out recently that the light was a very last resort. (cheers Pottsy) I have never put oil in to the car and nobody else has either, so I can only imagine that the dealer did this on my last service, about 7 months ago! I haven't noticed any problems with the car, so hopefully I should be ok; but I think that there's still some havok to be played, especially if it has done any damage at all. |
#17 (permalink) |
too much oil = no good, as is too little oil.
if 1-2mm over the dipstick max level then i guess its ok. best to be at the max level. drain any excess out. |
#18 (permalink) |
I'd say it's a good 4-5mm over max, not just a couple.
I would love to drain any excess out, but to be honest - wouldn't know where to start. To the dealer it goes, just don't know when! |
#20 (permalink) | |
Mine read correctly after the first service and way over the top after the second (by a different dealer). When I took it back the workshop foreman told me they put oil in by dialling up a quantity on a dispenser so that the actual amount in the car should be correct for that engine. He then found me the correct stick for the 1.8 and it read just right. I guess I must have been running around with insufficient oil after the first service. The car's now got 103,000 miles on it so no damage was done. Just waiting for my Civic to arrive to replace it. |
| Oil 1.8 iVTEC Sport - Help with Dipstick and Correct Oil | nelster | Engines and Transmission | 7 | 10th October 2007 17:06 |
| Noise levels? | Naresh | General Discussion | 16 | 29th July 2007 22:28 |
| Dipstick | rtypeblack | Type-R | 3 | 12th June 2007 07:09 |
| Oil Measuring oil levels 2.2 diesel | tonyt | Engines and Transmission | 8 | 3rd June 2007 12:38 |
| Forum membership levels | Charlie | General Discussion | 27 | 20th July 2006 07:29 |
