This thread is about: any one from honda - which oil for 1.8?, it's in Engines and Transmission at the Honda Civic forum Civinfo; Ancient Nerd Further to my post above re A3 B3 phoned Castrol and spoke to Jeff Briggs Tech division at Castrol (Very helpful guy who ...
Old 15th December 2006, 09:26   #21 (permalink)
surferjr1999's Avatar
Ancient Nerd Further to my post above re A3 B3 phoned Castrol and spoke to Jeff Briggs Tech division at Castrol (Very helpful guy who seemed to know what he was talking about) If I recall the conversation correctly he said that the A3 B3 spec was a performance spec higher than the A1 B1 and his recommendation was definitely the 0w 30 Edge
surferjr1999 is offline   Reply With Quote
Old 15th December 2006, 13:31   #22 (permalink)
Nice's Avatar
I'm not too sure that Honda's Castrol recommendation isn't part of a " DEAL " that the two companys have with each other ??
We use Mobil one 0W-30 for the 2.2 diesel and a fully synthetic Mobil synt S 5w-40 for the 1.8. A semi synthetic 10-40 is also available but we would recommend fully.
No doubt the use of Mobil within our company is probably part of a similar type of " Deal ".
I believe the oil business can be quite ruthless
Nice is offline   Reply With Quote
Old 15th December 2006, 15:03   #23 (permalink)
PTR
PTR's Avatar
FORGET THE 5w, 10W oils!! It is good, for older engines with more miles, bigger clearances, but it is def. too stiff for a brand new Honda engine with latest technology!!! Trust me I know what I am talking about!!
Go for a full synthetic 0w-30 or 0w-40 that's the right one!!
Old 15th December 2006, 23:08   #24 (permalink)
Originally Posted by damianscott71 View Post
I'd read that the car needs 5.something litres though, is this true? It sounded like a hell of a lot! (2.2 diesel).
Yes, you'll get a drip or two left out of 6 litres. There's a turbo to lubricate and cool - so the oil will cost £70+
Old 15th December 2006, 23:48   #25 (permalink)
Castrol? Magnatec? I'm lost, i've been filling mine with some crisp 'n' dry
Old 18th December 2006, 00:19   #26 (permalink)
DT
DT's Avatar
This is the leaflet I got from the dealer when I picked up my car in March. Leaflet states LongTec which is now called Castrol Edge. So far had to add 1 litre of oil (Castrol Edge) in my 1.8 petrol since March and covered 8,000 miles.
DT is offline   Reply With Quote
Old 18th December 2006, 00:40   #27 (permalink)
Thats great DT, thanks!
Old 18th December 2006, 16:51   #28 (permalink)
Good to see the leaflet confirming Honda recommend Edge. However I mentioned on my longer note earlier in this thread that Jeff Briggs from Technical Division Castrol advised not to put this oil in for the first 10k miles but to specify this on first service. Not ideal for new engine bedding in. Also should it be necessary to top up in meantime then Edge is oil of choice.
Old 20th December 2006, 18:44   #29 (permalink)
Kids use a lot of space
MC Hammer's Avatar
Seems a strange range of oils being used, hopefully they all mix ok
I found the oils to be 0W-20 for the petrol cars and 0W-30 for the diesel.
Old 28th December 2006, 12:08   #30 (permalink)
knightrider's Avatar
Oh no, now i'm worried! I 'topped up' (nearly a litre bottle!) yesterday and used some Castrol GTX Magnatec 10w-40. This is the second time i have put this in the car, i've done 9000 miles.
I didn't realise choice of oil was so crucial and just used the handbook for reference. Will my engine be ok?!
knightrider is offline   Reply With Quote
Old 28th December 2006, 13:43   #31 (permalink)
PTR
PTR's Avatar
no prob! do not worry about the oil... that is also ok. not perfect but ok!
at the next oil change choose some 0w-30 or 0w-40
Old 28th December 2006, 14:30   #32 (permalink)
DUNCAN's Avatar
why not perfect..when honda recommends 10w-40 for civic petrol...contact honda uk on 0845 200 8000
Old 28th December 2006, 14:51   #33 (permalink)
Duncan,
You can use either the "OK" 10-40 oil, or the "Good" 0-30. Your choice.
Old 28th December 2006, 17:34   #34 (permalink)
DUNCAN's Avatar
why dont honda give this choice when we have are cars service.
Old 28th December 2006, 18:39   #35 (permalink)
Because Honda do not service the car - the dealer does (and the dealer is an independent company). The oil will be within the specification laid down by the manufacturer, but if you want to specify further, then you must talk to your dealer.
Honda - a car manufacturer that sells to dealers, and has a contract with the dealer.
Car Dealer - a company that sells you a car, and may sell you servicing. You have a contract with the dealer, and not Honda!
Old 28th December 2006, 21:55   #36 (permalink)
DUNCAN's Avatar
no the dealer has a contract with honda, and honda will say what is done on the servicing of its cars (what oil to use)
Old 7th January 2007, 22:06   #37 (permalink)
DUNCAN's Avatar
oil that is put in at swindon.in the new civics is castrol edge 0w 30.. thanks to ( power of dreams )
Old 7th January 2007, 22:36   #38 (permalink)
PTR
PTR's Avatar
aham, good to know, thx for the confirmation...
so you can use 0w-30 or 0w-40 is also perfect but better forget the 10w-40 they are not even full synthetic..
Old 7th January 2007, 22:48   #39 (permalink)
DUNCAN's Avatar
to late for me honda dealer put in mobile 10w 40 on first service.
Old 7th January 2007, 22:49   #40 (permalink)
Fallen Angel
sarahjo's Avatar
You and me both Duncan........
sarahjo is offline   Reply With Quote
Similar Threads for: any one from honda - which oil for 1.8?
New lightweight Honda hits road - Honda S2000 CR Honda News Feed Honda News 0 17th April 2007 09:30
Servicing Honda Happiness? Honda Jinx more like Daren Buying, Dealers and Servicing 13 4th April 2007 11:44
New Honda Aviation Subsidiary 'Honda Aero, Inc.' Begins Operations Near Washington, D Honda News Feed Honda News 0 2nd November 2006 22:44
