| This thread is about: any one from honda - which oil for 1.8?, it's in Engines and Transmission at the Honda Civic forum Civinfo; Originally Posted by sarahjo Oh your funny!!!!! you know I'm just kidding....!!... | ||
#64 (permalink) |
At First Service 20000km/1 year, Honda guys changed oils to Mobil Synt S 5W-40.
Some "specs" from Oil: SAE Grade: 5W-40 Kinematic Viscosity mm2/s: 40'C -> 84 100'C -> 14,2 Viscosity Index: 176 Density at 15'C g/cm: 0,855 Pour Point 'C: -39 Rash Point 'C: 220 "Fully synthetic high performance engine oil. Ideal for modern, high performance engines, especially turbocharged. Excellent low and high temperature properties. Suitable for most types of gasoline and diesel engines found in passanger cars." |
#67 (permalink) |
Due to the reported oil usage here I am intending to pick up a litre of oil when I collect the car on Saturday.
Out of interest has anybody got any this way and is it a mega expensive way of getting the stuff ? It seems that Castrol 0-30 5-40 or 10-40 synthetic will do just fine for topping up. |
#69 (permalink) |
popped into my dealer today to get an oil "top up" pack comes with 1ltr oil, filling funnels, gloves and wipes in a nice castrol bag and they said that the reccomended oil for the 1.8 i-vtec is castrol 10w-40.
#72 (permalink) |
Lubricants and Fluids
Lubricants and Fluids [IMG]file:///D:/A00/PNG/SMG6E900000000K0081BAAD02.PNG[/IMG] [IMG]file:///D:/A00/PNG/SYM/ATT2.PNG[/IMG]Used engine oil may cause skin cancer if repeatedly left in contact with the skin for prolonged periods. Although this is unlikely unless you handle used oil on a daily basis, it is still advisable to thoroughly wash your hands with soap and water as soon as possible after handling used oil. For the details of lubrication points and type of lubricants to be applied, refer to the illustrated index and various work procedures (such as Assembly/Reassembly, Replacement, Overhaul, Installation, etc.) contained in each section. Lubrication Points Lubricant A Engine Always use synthetic genuine Honda Motor Oil (Highly recommended), synthetic 0W-30 motor oil ACEA A1/B1 (Highly recommended), or synthetic motor oil ACEA A3/B3. ACEA viscosity: See chart. B Manual transmission Honda Manual Transmission Fluid (MTF) Always use genuine Honda MTF*. Using motor oil can cause stiffer shifting because it does not contain the proper additives. C Brake system (including VSA line) Brake Fluid DOT 3 or DOT 4 We recommend genuine Honda Brake Fluid. Using a non-Honda brake fluid can cause corrosion and decrease the life of the system. D Clutch line Brake Fluid DOT 3 or DOT 4 We recommend genuine Honda Brake Fluid. E F G H I J K L Release fork Battery terminals Brake booster clevis Clutch master cylinder clevis Shift lever Fuel fill door Hood hinges and hood latch Tailgate hinges and tailgate latch Multipurpose Grease M Brake caliper piston seals Rubber Grease N O Brake caliper piston boots, piston pins and boots Shift cable ends Silicone Grease P Air conditioning compressor Compressor oil: DENSO ND-OIL8 (P/N 38897-PR7-003, 38898-PR7-003, or 38899-PR7-A01) For refrigerant HFC-134a (R-134a) If genuine Honda MTF is not available, use API service SL or higher grade motor oil with a viscosity of SAE 10W-30 or 10W-40 as a temporary replacement. [IMG]file:///D:/A00/PNG/SMG6E900000000K0081BAAD01.PNG[/IMG][FONT='Arial','sans-serif']Recommended Engine oil[/font] [FONT='Arial','sans-serif']· Engine oil viscosity for ambient temperature ranges[/font] [FONT='Arial','sans-serif']· Synthetic oil only[/font][FONT='Arial','sans-serif']*: Using oils other than preferred viscosity may adversely affect consumption.[/font] Last edited by DUNCAN; 30th December 2007 at 20:27. |
#73 (permalink) |
how long will this topic be open ? the right answers are given long time ago.
Let's repeat: 5W40 is good and advised (has to do with a pricepoint of course), 10w40 is aloud, but 0w30 is advised for high performance and fuel efficiency. (and according to this it's clear that a 5w30 is also very good choise by the way) My personal choise if money doesn't matter: Shell 0w30 So make up your choise and close this stupid-getting topic ! |
| New lightweight Honda hits road - Honda S2000 CR | Honda News Feed | Honda News | 0 | 17th April 2007 09:30 |
| Servicing Honda Happiness? Honda Jinx more like | Daren | Buying, Dealers and Servicing | 13 | 4th April 2007 11:44 |
| New Honda Aviation Subsidiary 'Honda Aero, Inc.' Begins Operations Near Washington, D | Honda News Feed | Honda News | 0 | 2nd November 2006 22:44 |
