Old 13th June 2009, 00:48   #1 (permalink)
Car: CIVIC 2.2 i -CTDi EX BLACK
Thumbs up remapping made simple 2.2 diesel
*EDIT by FWH*
WARNING.
This is a home made map and it is not proffesionally tested.
It was made my a member who is now banned.
Using this map may seriously damage your car.
Civinfo takes no responisibily for this map or any damage caused by using it.
Hi Guys ,
you can remap your own civic very easily with the Galletto 1260 ,which can be purchased off ebay for as little as £25.
I have experience in building maps and have 3 tuned maps of various stages of performance , 15% , 25% , 30% . .
You will not find these maps advertised on ebay ,even on the disks boasting 35000 tuned files for a Tenner, the honda maps are not readily available.
I have recently done my new 2.2 civic 08 plate , and i have not had it on a dyno but the performance increase is unbelievable .0-65 is returning 7.3 secs, the torque increase is neck wrenching from 2200 ,to 4500 revs.
From experience i would estimate 175-185 bhp.
These maps are well within the limits of the engine and drive train , however if you are having clutch issues like some people are complaining about on this forum , then the power increase will make this worse. I have had the high performance map in my car now for 3 months without the slightest problem ,except for the big grin on my face when i accelerate.
I can supply these maps if anyone is interested and i will also guide you through the process if required , it is honestly very simple a child could do it.The hard work is in building the maps.. .If you are not happy with the new maps you can simply reload your original maps into the ecu and you are then back to standard , no one would ever know.( Honda dealers ).
**Edit by DR** **Edit by DR**
Edit (Pottsy): There is now a wiki page about this here.
Last edited by FWH; 22nd January 2011 at 13:53. Reason: Forum Rules / added Warning
jemmcat is offline   Reply With Quote
Thank You to jemmcat from 4 Users:
Old 13th June 2009, 01:08   #2 (permalink)
Car: 2.2 ICTDI EX 5 door BLACK
Thanks given: 52
Sounds interesting mate but I'd like to know a bit more about it first.
Have you done anyone elses motor other than your own?
Where abouts are you in the UK?
Maybe youd like a guinepig to give you a testimonial or review on your maps???
P UNIT is offline   Reply With Quote
Old 13th June 2009, 01:13   #3 (permalink)
2008 Honda Civic Type S
griffo571's Avatar
Car: 08 Civic Type S 2.2 CDTi
Thanks given: 3
keep talking
griffo571 is offline   Reply With Quote
Old 13th June 2009, 07:06   #4 (permalink)
Magic Detail Winner 2012
Car: Two fast Skoda vRS's
Thanks given: 737
Here:
Galletto 1260 EOBD2 OBDII ECU Remap Flasher Tool UK on eBay, also, Diagnostic Tools Equipment, Garage Equipment Tools, Cars, Parts Vehicles (end time 22-Jun-09 17:42:39 BST)
Thanks to robbo51 from:
Old 13th June 2009, 08:56   #5 (permalink)
matg's Avatar
Thanks given: 8
Is your MPG affected?
What are the chances of bricking the ECU doing this?
matg is offline   Reply With Quote
Old 13th June 2009, 09:10   #6 (permalink)
Thumbs up remap made simple
Guys
i have done many cars ,
for example Golf, passat,octavia ,bmw,mercedes c classe,many peugoets,
Seat Leon,to name but a few.
I assure you it is very easy to do, and all the maps are well within specifications.
you can buys many maps off ebay that have also been tried and tested, but as i say no one is selling the Civic files.with a programme called Winols it is possible to tweak your own maps to suit your driving style .if you preferre torque at low end or top end this is very easily achievable with this software.
On average each ecu hold 140 maps that control the engine management system,the most common maps that are modfied are the fuel ratio/boost / turbo/throttle response maps .in total approx 6 -12 maps are modified depending on the car.
for example only 2 maps need to modifed on the Mercedes c classe diesel.
On the civic 12 maps ,but 6 are duplicated so in reality you are modifiying 6 maps only.This is the hard part .
Loading maps into your car is childs play with the tool i mentioned,all you do is download your original maps for safe keeping then upload the modifed maps,job done.!!!
saving your self £100's of pounds.
The Galletto does all of the vehicles i mentioned above + many more **Edit by DR**
thansk for listening ,hope this helps
Old 13th June 2009, 11:42   #7 (permalink)
Car: Jag XF 3.0
Thanks given: 121
jemmcat
If you are here to sell stuff (like your maps), then you will need to post in the appropriate section (For sale and Wanted).
If you are not (and just a genuine enthusiast here to help others), then you could zip the maps up and upload them here for others to enjoy.
Old 13th June 2009, 15:26   #8 (permalink)
Fabia vRS
H17YD_L's Avatar
Car: 2011 Fabia vRS
Thanks given: 4
i'll deffinately be in. Will you provide them maps free or would you want paying, i.e as pottsy asked. i'll get the thing off ebay an i'll be a tester best news i've heard for a while!
H17YD_L is offline   Reply With Quote
Old 13th June 2009, 16:32   #9 (permalink)
Fabia vRS
H17YD_L's Avatar
Car: 2011 Fabia vRS
Thanks given: 4
Does anyone know if any of the following is the 2.2 one
HONDA BOSCH_EDC15 C7 READ AND WRITE
HONDA BOSCH_EDC16 C31 READ AND WRITE
HONDA BOSCH_ME7.1.9 READ AND WRITE
I've found the galletto for £25 with postage, just want to check is it will work with the car first
Old 13th June 2009, 17:16   #10 (permalink)
crazyfool46's Avatar
Car: 2006 2.2 i-cdti 5dr Sport
Thanks given: 24
I'd definitely be interested in it aswell; if you could do it so you could reset back to normal map aswell, (as per service time) then that that would be even better!
crazyfool46 is offline   Reply With Quote
Old 13th June 2009, 17:32   #11 (permalink)
Now with Type R :)
Thanks given: 7
So then, whos going to invest in this kit? Any my next question, whens the next meet? hehe
spike4real is offline   Reply With Quote
Old 13th June 2009, 18:28   #12 (permalink)
*EDIT by FWH*
WARNING.
the Galletto 1260 will work on the EDC16 C31 ECU, all of the new civic 2.2 diesels i have come across have this ecu .
just connect to the odb port turn on iginition ,not the engine,and select the Honda /edc16 /then press find ecu.it will connect and display all the info from your ecu. once this is done just downlaod your original map,save it in file somewhere just in case you decide to put it back to standard spec for selling etc.Then upload the new map i have given you . ,the software will firstly erase the memory of the ecu ,don't worry this is normal .it will then upload the new map .approx 2 minutes.
JOB DONE !
enjoy your new car and let me know what you think
any questions i will be glad to help
Jem
Thanks to jemmcat from:
Old 13th June 2009, 19:29   #13 (permalink)
Thanks given: 737
So ....Who is going to bold and do it??
Personally..."If it looks too good to be true...... It usually is"
Thanks for the file
I'll let someone else give it a go
Old 13th June 2009, 19:41   #14 (permalink)
Jack The Lad.'s Avatar
Thanks given: 18
I don't wish to offend jem, but I'm with robbo on this one, until proven incorrect.
Old 13th June 2009, 20:35   #15 (permalink)
I am not offended guys , only here to help , i understand your concerns ,that is why i have explained the procedure ,it is really simple , i am in the midlands if you want me to do it for you .
The hardest part is done for you ,that is building the maps,
if you get a galletto, you can plug it in and just look at the ecu if you wish ,
download your map and compare with 'winols' this will not effect your ecu what so ever.or download your map send it to me and i will confirm that it is fully compatible before you continue any further .
making it idiot proof ( that does not mean i am calling you idiots ) lol
regards
Jem
Old 13th June 2009, 21:18   #16 (permalink)
Fabia vRS
H17YD_L's Avatar
Car: 2011 Fabia vRS
Thanks given: 4
is that file you attached the map, only its a video file on my computer and windows media player cannot play it, or is it a video of the car or something.
so if i bought this galletto 1260 it would be fine as it says ecd16 etc...
NEW Galletto 1260 EOBD1260 OBD ECU Remap Flasher Tool on eBay, also, Diagnostic Tools Equipment, Garage Equipment Tools, Cars, Parts Vehicles (end time 02-Jul-09 14:11:56 BST)
thanks
Old 13th June 2009, 22:57   #17 (permalink)
yes it is the map , you can only open it with Winols which is the modification software ,you will not find this software anywhere on the net ,it is meant only for dealers /bonafied tuning companies.( very expensive) there is software called wingal which is similar , personally i don,t like using it .but it is fine to use.with ths you can compare my modifed map with the original one you take from your car.this may be supplied with the Galletto 1260 (ebay)as well as the upload/download software ,
hope this helps .
Old 13th June 2009, 23:00   #18 (permalink)
impreza's Avatar
Car: FR-V 2.0 i-vtec sport
Thanks given: 3
Nice one jemmcat, will give your map a shot,
will let you know results as soon as poss,
just waiting for my Galletto 1260 EOBD cable to come.
cheers.
impreza is offline   Reply With Quote
Old 13th June 2009, 23:05   #19 (permalink)
Foglight Covers FORSALE
gray52's Avatar
Thanks given: 45
i think this deserves a sticky, so we can upload custom maps and also download a standard map if someone was to wipe or lose there original . this could be an interesting thread as alot of us will have our warrentys expiring soon. do your own tuning, now this is good.
Old 13th June 2009, 23:16   #20 (permalink)
hope this helps .
slight mistake ,when i said it can only be opened with winols /wingal . it can also be opened with the uploading/ downloading used with the galletto 1260 of course
Jem
LinkBack to this Thread: http://www.civinfo.com/forum/engines-transmission/27958-remapping-made-simple-2-2-diesel.html
Forums CivicYume • Consulter le sujet - Reprog Civic This thread Refback 23rd March 2011 15:45
Forums CivicYume • Consulter le sujet - filtre à air "sport" pour ictdi 2.2 !!?? This thread Refback 23rd February 2011 22:50
Forums CivicYume • Afficher le sujet - Reprog Civic This thread Refback 5th August 2010 10:16
Forums CivicYume • Afficher le sujet - Reprog Civic This thread Refback 7th July 2010 19:07
Stilo ECU / Cheapy Galletto Clone Adventures This thread Refback 28th May 2010 14:38
THAOC - The Honda Accord Owners Club -> tuning 2.2 deisel This thread Refback 10th May 2010 22:40
Forums CivicYume • Afficher le sujet - [Tuto]Reprogrammer son Orni soi-meme pour 20? This thread Refback 26th March 2010 20:43
doityourselfdiagnostics.com - Sites Linking in - from Alexa Post #0 Refback 27th February 2010 08:58
Forums CivicYume • Afficher le sujet - Reprog Civic This thread Refback 4th February 2010 15:15
Nouvelle Honda Civic [Topic Unique] - Honda Civic - FORUM Honda - FORUM Auto par marques This thread Refback 1st January 2010 20:39
Forums CivicYume • Afficher le sujet - Reprog Civic This thread Refback 14th October 2009 21:43
?ipování motoru | Honda CIVIC 8. generace This thread Refback 21st July 2009 16:56
Forums CivicYume • Afficher le sujet - Reprog Civic Type-S GT @ 180ch This thread Refback 16th July 2009 17:31
Stilo ECU / Cheapy Galletto Clone Adventures - Page 2 - Fiat Stilo Owners Club This thread Refback 15th July 2009 09:42
www.chiptuners.org :: View topic - Question about new tuner at Civinfo forum This thread Refback 10th July 2009 20:24
Forums CivicYume • Afficher le sujet - filtre à air "sport" pour ictdi 2.2 !!?? This thread Refback 10th July 2009 06:02
Forums CivicYume • Afficher le sujet - filtre à air This thread Refback 4th July 2009 15:23
Forums CivicYume • Afficher le sujet - filtre à air This thread Refback 2nd July 2009 17:11
Forums CivicYume • Afficher le sujet - filtre à air This thread Refback 1st July 2009 12:10
Forums CivicYume • Afficher le sujet - filtre à air This thread Refback 28th June 2009 21:17
Forums CivicYume • Afficher le sujet - filtre à air This thread Refback 25th June 2009 18:42
Forums CivicYume • Afficher le sujet - filtre à air This thread Refback 23rd June 2009 04:58
Forums CivicYume • Afficher le sujet - filtre à air This thread Refback 22nd June 2009 20:19
Similar Threads for: remapping made simple 2.2 diesel
Remap Remapping - read this (ChippedUK) lordlucan Engines and Transmission 47 27th April 2012 11:21
Remap Remapping question... czechplastik Engines and Transmission 3 13th June 2009 23:01
AUX in Simple Solution Needed (for simple person) qcumber Ipods, MP3 Players and ICE 5 12th February 2008 15:53
Simple things! Topcat Any non Civic chat here please! 3 3rd May 2007 20:54
Remap ECU remapping during service t0ny0k Engines and Transmission 5 12th February 2007 10:13
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Site owned by Jayne Potts - nothing to do with Honda!
no new posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81
