| This thread is about: 1.8 i-VTEC Turbo Kit! WOW!, it's in Engines and Transmission at the Honda Civic forum Civinfo; check this out! http://www.honda-tech.com/zerothread/1809040... | ||
Perfect Guy!
Sorry am I missing something where does it say this is for the
1.8 i-vtec Didn't even know the americans has the 1.8 i-vtec |
#3 (permalink) | |
ok, they've removed some plastic covers, airbox, catalyc converter, changed colours... etc. but it is the same! for ex. EGR valve is on the same place also (on the right side of the engine - between cylinder head and air intake pipe) an the titel is: "Massive r18a1 turbo UPDATE" R18Ax is the engine code of the i-VTEC... you can check thread here: i-VTEC - R18A1 or R18A2?? |
if you look carefully at the video, that's on that forum ,you can see it's not for the hatcback, but for the civic coupe or sedan, that we don't have around here, so basicly it's nothing special, if you do a search on it, you'll find a lot turbokits for that car
Sod that,
I'm going to see if GrEDDY does a SUPERCHARGER.... Much more fun... though the belt will probably break at about 7000 revs - they usually do... Mechanical linkage? Now there's lovely... |
Not bad, but I'm still staying with the supercharger idea - as long as its not belt driven...
I reckon if I tinker with things (properly) there's at least 250 horses to be had..... |
LinkBack to this Thread: http://www.civinfo.com/forum/engines-transmission/3029-1-8-i-variable-valve-timing-valve-lift-electronic-control-turbo-kit-wow.html
| wutangpaul's bookmarks on del.icio.us | This thread | Refback | 26th March 2008 19:05 | |
| Induction Turbo sound? | Civic ASM | Engines and Transmission | 8 | 22nd April 2008 12:11 |
| Turbo Acura Integra GSR and Turbo Acura T | trev0006 | Any non Civic chat here please! | 0 | 26th October 2007 10:39 |
| Performance Turbo for a 1.8 | Egbert | Engines and Transmission | 8 | 18th August 2007 10:26 |
| Oil Simmer the turbo? | tonyt | Engines and Transmission | 16 | 3rd March 2007 16:49 |
| Tech turbo timer | Type S Bournemouth | Engines and Transmission | 2 | 16th February 2007 22:02 |
