| This thread is about: MPG after ECU reset, it's in Engines and Transmission at the Honda Civic forum Civinfo; To City Motors, Basingstoke Honda dealer this morning with the 2.2 Sport for the steering pump recall. I asked if they could take a look ... | ||
MPG after ECU reset
To City Motors, Basingstoke Honda dealer this morning with the 2.2 Sport for the steering pump recall. I asked if they could take a look at the creaking windscreen at the same time, and queried the way fuel consumption according to the trip computer has fallen off as the car approaches its first service. I also asked if they could check the aim of the headlights.
Collected this afternoon with a new steering pump, windscreen clips 'adjusted', headlights now properly aligned (boy, what a difference!) and a reset ECU. Fuel consumption on the way there was 51.4 - on the way back, in more stop-start traffic, 59.8. Now that's what I call a result. The car also feels more lively than it did before. A few people here have noted that the ECU can be reset by disconnecting the battery for a time - and that the car is often quicker after such treatment. But I wonder if anyone else has noticed better fuel consumption? I also wonder if those here who complain of average MPG in the region of 38-40 might find their cars benefit from a reset. I further wonder if the reset DOES actually affect fuel consumption, or whether it actually only alters the calibration of the trip compter functionality and thereby deceives. Only a brim-to-brim fill will show - and I'll do that over the next fortnight. KevinF. |
probably they've not just resetting but upgraded the ECU software...
I don't think a simple reset would bring that much... but you never know... |
#4 (permalink) | |
Enthusiastic Supporter
I've had mine back from its first service now for over a week and the mpg hasn't changed a bit - it's going back in in a week so I will mention that it's still down in the LOW 30's I'll be interested to see what you get brim-to-brim Kevin. |
low 30s in the cdti , what you got lead foot ???????????? must be the remap and you useing the power more , did you notice it drop or raise after reamp ? or have you not had time to check doing warp factor 9 all the time in your spaceship . Why dont you try batt' of reset ? see if it makes any diffence. mite say trip to dealer.
It depends on your usage pattern. Someone doing a lot of motorway driving is clearly going to do far better than someone doing lots of turbo, urban and short trips.
#7 (permalink) | ||
May be down to the fact they put the wrong oil in - 10W40 instead of 0W30. Still surprised at the difference though. |
#8 (permalink) | |
They also assure me there is no problem mixing it whatever was put in at the factory. Why do Honda recommend 0w30 ? |
Hi all,
The reset thing is interesting - I'll think I'll try it anyway. On my first few tank fulls i was geting 45mpg, even 55mpg on a long run on country roads where the top speed was about 50mph. Now with the same driving pattern its about 38 - 40 mpg. This is after 4 months and 6K miles. Its strange as i remember someone saying the mpg should go up and the milage goes up and the engine loosens up, but for me, its the othr way round! Cheers Les |
Would agree with the cold weather theory. My fuel economy dropped in the recent cold spell over Xmas to about 45-46 mpg in my ex diesel.
#12 (permalink) | |
Well not only do Honda recommend 0W30 they DON'T recommend 10W40 for the diesel! Checked with Honda UK and they actually stated it as being the wrong oil. There is also the matter that 10W40 is probably a lot cheaper than 0W30 fully synthetic - this is probably the reason they put it in. Cynical . . . maybe. Mixing the oils I'm told is OK - its the fact that its the wrong grade for the diesel that concerns me! |
#14 (permalink) | |
So today I went and tried it....and to be honest I've seen absolutly zilch noticable difference in MPG or performance. However this might be for a different reason. I left the battery unplugged for about 15mins, and then plugged it all back in. The HU has completely reset itself, including my climate control level, however the dash is the same, trip a and b were remembered, as were my speed alert settings, this makes me think that an ECU reset might do the job, but the dash and therefore quite probably the ECU remembers everything even after a battery disconnect. Obviously this could be different if left for an hour or more, but as it stands I think this is the case. Interestingly my Civic said "Check system" with the exclamation mark when I started it up, being a bit worried I tried again and got the message, third time it was fine and must have started her up 10 times since and been fine; it probably knows that something was wrong as it lost power for a little bit. |
#18 (permalink) |
You can always 'request' one...... Seriously, why would you want to 'upgrade' your ECU. If nothing is wrong don't go changing things. If there is a clearly identified issue that affects your vehicle and it is resolved by a later ECU revision then sure it should be applied. Do not change something just because you can - some dealers do this on the off chance it will resolve the problem - sometimes it just causes other unrelated problems/issues and/or masks the real problem. Do they keep a backup and would they roll it back to the previous state if it went wrong? Now wheres that latest beta firmware update for my pacemaker?????? |
#19 (permalink) |
The whole subject of ECU remapping is a little bit of an old wives tale. Dealers are able to install new software in the ECU but this would only be done in the event of a reason to do so. Don't for one minute believe you are going to get more power or better performance. These aspects of the engine software and operation are very tightly controlled by legislation and homologation. If there is an update for you car, it is probably to address a concern with error codes or to aid dealer fault diagnosis.
#20 (permalink) | |
Not so
| Computer Average speed reset | Urban Tangleweed | Bugs, faults and irritations | 18 | 19th August 2007 21:27 |
| Computer Reseting Trip A Manualy or Activating reset Trip A | alex | Electronics | 23 | 31st July 2007 18:15 |
| Electric window reset procedure | sandz | Wiki Article Discussion | 0 | 19th June 2007 14:29 |
| Servicing How To Reset the Oil Service | abu-sarta | Buying, Dealers and Servicing | 1 | 13th June 2007 19:20 |
| Computer Average Speed Reset | Steevie | Electronics | 6 | 25th September 2006 13:27 |
