This thread is about: i shift information, it's in Engines and Transmission at the Honda Civic forum Civinfo; Originally Posted by Maldax Their boxes come out a little more expensive than a Civic! Yes, and the're lucky if they last much longer than ...
Old 23rd January 2007, 17:16   #41 (permalink)
allan40alt's Avatar
Yes, and the're lucky if they last much longer than a few hours usage!
Old 24th January 2007, 00:34   #42 (permalink)
having driven my last 2 cars as automatics, and as 1 of them was the superb Audi DSG box, I have a couple of comments, if that's ok...
My wife's 206 Auto was, I thought, pretty good - certainly compared to the much older auto cars which was all I had to compare it to.
Generally always in the right gear (not struggling, not revving it's guts out).
The DSG in my TT was, in a few words, a marvel of modern engineering
BUT - it was still possible to catch them both out.
Ultimately, these boxes (inc I-Shift) are automatic in as much as they have pre-programmed stratgies for working out what gear they should be in at any one time.
They are based on any number of inputs, but 2 of the most important relate to revs and throttle position.
For example, in the TT, from standstill, if you just pressed lightly on the gas, it would have changed up to 6th gear by the time you got to 30mph (and you wouldn't have noticed the gear changes)
However, if you floored it from stopped, it would still be in first at 30 and you would be busy hanging on and ing LOL But the change to 2nd was then more noticable.
With I-Shift jerking from 1st to 2nd - think about what it is trying to
do.
Reasonably high revs, it 'dips' the clutch, and engages 2nd as soon as possible.
At which point, the wheel rotation tries to slow the engine down to match the road speed.
So it jerks.
Lifting off slightly means that the engine revs are already dropping slightly as the clutch dips, and probably at slightly lower road speed.
So the jerk as the clutch re-engages and sorts out road speed vs engine speed is less.
hope that makes sense!
Old 24th January 2007, 02:41   #43 (permalink)
IWANTACIVIC's Avatar
love to have a go in a i shift , ill have to go and sweet talk the dealer or my friend to let me try his jazz , but am i right the i shifts not on the 2,2 ?
is there to much torque for the i shift ? love the idea of paddles 7 speeds Sime's a bit much ? or is it about right ?
Old 24th January 2007, 08:55   #44 (permalink)
allan40alt's Avatar
I don't think the Jazz has the same system. They have CVT which is very different.
I-Shift is for the 1.8 VTEC.
Old 24th January 2007, 14:13   #45 (permalink)
Charles_Harding's Avatar
You took the words right out of my mouth!
"There's nothing wrong with me that re-incarnation won't cure!"
Charles H.
Old 24th January 2007, 19:37   #46 (permalink)
Kids use a lot of space
MC Hammer's Avatar
As TT so correctly points out the i-shift is a manual box with an automatic change system.
The jerky gearchange will of course happen in a manual if you keep the throttle at a constant level and change gear. I imagine it would take a little bit of getting used to, but possible to drive smoothly.
Not having driven one, I'm not sure if this is possible on today's roads.
Similar Threads for: i shift information
Engine Dash information messages PGM-FI - and hello...... chinwish Bugs, faults and irritations 25 18th October 2007 15:21
WTB: 07 Type R shift knob and shift boot 06Fg2 For sale and Wanted 46 2nd May 2007 06:03
Bunch of photos and information Clouseau Type-R 1 30th January 2007 21:51
Model year 2007 civic information.... skam Buying, Dealers and Servicing 25 25th November 2006 00:23
Transmission ES With I-Shift Pezza Engines and Transmission 10 24th June 2006 14:55
