Dude
![]() Car: 2006 EK3 EX, Cosmic.
Thanks given: 10
I have an annoying problem with the smoothness of my 2006 2.2 iCTDI with 50k on the clock.
During 95% of all driving, the car is smooth. There is lots of power and it feels great. Acceleration is smooth through the whole rev range. The problem shows up during town driving mainly and occurs at quite a specific rev range of 1500rpm which is a sensible driving engine speed. At a very gentle throttle (~10%) the car likes to act like a kangaroo and jump around as if it is close to stalling. This is roughly around 20mph in second and 26mph in third. This jumpiness goes away straight away if I give it a little more with my right foot. It is possible to 'drive around the problem' by driving a little faster (not always possible), but it is still annoying when trying to make smooth relaxed progress in town traffic. I thought maybe the car just really needs a service - its just had its big one (Level 4) at my local dealer on Friday so it has new oil and air/fuel/oil filters. Maybe it is because its just been driven around town for the past few months - so I went for a 300+ mile blast this weekend (I mean *blast*) to see a friend. Drove pretty hard and fast on the way there and took it easy on the way back. None of that seemed to make any difference. Anyone got any ideas? Anyone ever experienced the same with their 2.2? It almost doesn't really feel like its a mechanical problem since it only happens at such a specific engine speed - is there a new version of a Honda 'map' that my dealer can put on which will stop this flat spot? |
Dude
Thanks given: 10
Yeah, I'll try that soon - but mainly I'd really like to see whether anyone else has had such a problem with their car so I can know a little more about it. I just know that if I took it straight to the dealer they will say "its fine!" and send me on my way.
By the way, I also tried Total Std and Premium, BP Std and Ultimate, Shell Std, and at the moment there is V-Power Diesel in there. |
![]() Car: Jag XF 3.0
Thanks given: 127
I would be suspicious of the EGR valve. It can cause stuttering or kangerooing, and it is not unusual for it to require attention.
http://www.civinfo.com/forum/how/256...-ctdi-fk3.html |
Dude
Thanks given: 10
Thanks Pottsy!
Going to give that a look over asap. Also, very strangely on my drive home from work, the car seemed much smoother than usual around the 1500rpm mark. Very odd! A few days ago the problem was quite pronounced, but today it seems very slight. I hope it really is going away rather than being intermittent. I'll know for sure in the morning though, it doesn't like cold mornings. |
Dude
Thanks given: 10
Stuttering under light throttle 2.2
That thread is 2 years old, but it seems like exactly the problem I have. |
![]() Car: 2006 ES 5 Door Silver
Thanks given: 1
I also have a very similar problem, but I am in the 1.8petrol. So not sure if it is anything to do with the type of fuel that is being used. I will be taking it to the dealer (with the ever growing list of other problems that I'm noticing) - including the gears/clutch that's making it difficult to select 1st from standing and down shifting into 2nd from 3rd - I thought this might have had something to do with the kangaroo effect but doesn't seem like it now. If you visit the dealer could you let me no how it goes so they don't try fob me off with some old excuse. Cheers. |
Car: Civic 2006 2.2 ctdi EX
Thanks given: 1
I have this exact same problem on my 2006 CTDI (58000 miles) Service and new fuel filter hasn't solved it. Has anyone resolved this issue?
It's at large intermittent but always as low revs either running down to a stop, setting off from a stop or changing gear (doesn't matter which gear either). Sometimes the kangaroo-ing is quite violent. Other than that and the strange random dropping of the revs when I've stopped down to 400-600rpm then back up to 800 rpm idle, the car is as smooth as anything. Tried diesel cleaners and V-power fuel which has made no difference at all. Thanks |
Goat Fancier
![]() Car: 2005 Accord iCTDi Tourer
Thanks given: 59
I suggest that maybe either the EGR valve or the MAF sensor would benefit from a proper cleaning.
Welcome to the club! |
Thanks given: 1
Thanks Jon-G< yeah its been in at the dealers and a full EGR clean and new MAF and still no different.
It's really doing my head in.
#12 (permalink) |
Cockup Specialist
Thanks given: 737
The fact it drops to 3/4 or 1/2 800rpm might indicate its an injector shutting down.
The ECU has a correction algorythm where it tries to get equal torque from all 4 injectors by independantly varying the fuel load. If one injector is clogged or sticking the ECU might be modulating the fuel to try and get a balanced idle. Just an idea. Honda can log the individual injectors and they have test functions for this they can run too. |
Thanks to Relic from:
Thanks given: 1
She's died!!!!
Started the car from cold this morning and noticed the revs pulsing slightly and I could hear it with the engine. Set off and the flat spots were awful all the way to work (15 miles). Got to 1 mile off work and a massive flat spot happened where I had my foot to the floor and the engine didn't repond to the input or the revs in any gear. Crawled along to the last set of lights and it stalled, couldn't get it going for a good 10 mins This seems to me like something to do with the fuel delivery the way it just stalled and wouldn't fire back up. Still no engine management light though???? Weird!
#14 (permalink) |
Goat Fancier
Thanks given: 59
Sorry to hear that, but please do let us know what the problem was after Honda have sorted it out. Hope it isn't an expensive problem!
#15 (permalink) | |
Thanks given: 1
Just want it sorting out now but I will definitely post the verdict when I know.
#16 (permalink) | |
Did you ever get the problem sorted out as it sounds like exactly the same as the problem I am currently having. Would be nice to know if I am going to have my pants taken down by the dealer to get it sorted. Thanks. |
#17 (permalink) | |
Car: 07 2.2ctdi black
Thanks given: 1
interested to see what honda say the problem is
#18 (permalink) |
Thanks given: 1
Morning all...........
Drum roll please..................the cars fixed!!!!! ![]() ![]() ![]() ![]() The culprit: EGR Valve! The Honda dealer locally slaved a known good one on before going through the expense and pain of trying a new one and it cured it. The last time it died on me, the fumes in the car were awful so whilst it was in I asked them to look at the manifold. Low and behold theres a crack in it and it's still in an extended 7 yr warranty from Honda under a service bulletin BY 19 DAYS!!!! Phew! So its going back in for a new casted one for free!!!! Happy Days! It kind of took the sting out of the £600 EGR valve!
Thanks to Sue.S from:
#19 (permalink) |
Goat Fancier
Thanks given: 59
Glad to hear it. But £600 = minor 'ouch'... but thanks for confirming the problem.
Very disappointing that the dealer didn't realise the EGR valve was faulty previously when they cleaned it, but excellent news that they caught the cracked manifold in time! |
#20 (permalink) | |
Thanks given: 1
Tell me about it Jon! You peeps have been more helpful to solve this issue than their "technicians!" as they seem to call themselves, but it appears they haven't a clue unless theres a fault code glaring at them. But at least I get a manifold out of it |
LinkBack to this Thread: http://www.civinfo.com/forum/engines-transmission/34121-2-2-juddering-stuttering-1500rpm-light-throttle.html
| Honda Car Transmission Stutter | Stutter | This thread | Refback | 15th January 2010 17:40 | |
Similar Threads for: 2.2 Juddering / Stuttering @ 1500rpm Light Throttle
| Engine noise at 1500rpm upto 3000rpm | andyrexy | Bugs, faults and irritations | 8 | 7th September 2009 17:22 |
| Run in CTS Stuttering and Acceleration Problems | j_auluck | Engines and Transmission | 9 | 22nd February 2008 15:38 |
| Faults Stuttering under light throttle 2.2 | Tydo | Engines and Transmission | 10 | 7th January 2008 18:46 |
| Transmission Juddering i-Shift | jalaman | Engines and Transmission | 7 | 17th August 2007 09:48 |
| Engine Stuttering | Nadz | Bugs, faults and irritations | 12 | 27th February 2007 16:18 |
