| This thread is about: Recommended Oil for I-VTEC annd I-CDTI, it's in Engines and Transmission at the Honda Civic forum Civinfo; I went to my local, not where I purchased the car, dealer about 1 month ago for top up oil. They sold me Castrol 0-30 ... | ||
#41 (permalink) |
I went to my local, not where I purchased the car, dealer about 1 month ago for top up oil. They sold me Castrol 0-30 SLX in a very nice refill pack with gloves, funnel and a bag which velcro'd to the boot sidewall.
I then went back today and dealer told me he was out of it and to use any 5-40 synthetic. I told him about the SLX being 0-30 and he said 5-40 was the one to use. This contradicts the service book. Not happy |
#43 (permalink) |
Can I point out that the term synthetic (when referring to hydrocracked dino oil) has been sanctioned by the SAE and it's nothing to do with the Government allowing oil companies to get away with misrepresentation.
Secondly, don't get hung up on the weight of the oil - the weights aren't definitive, and as such one company's 0w-30 is another's 10w-20. What you need to do is find an oil that matches the Class your engine needs, e.g. API SL/CF, ACEA A3-04/**-04/C3-04. (2.2 i-CDTi) Fond fan of Liqui Moly - some useful/interesting info: http://oelberater.liquimoly.de/liqui...sp?LANGUAGE=en http://www.liquimoly.de/web/lmhomeen...ages/techinfos http://www.liquimoly.de/web/lmhomeen...index_produkte |
#44 (permalink) | |
#45 (permalink) |
For us here in the UK, pretty much as the relative difference in viscosity between 0w and 10w is negligible for the type of winter temps we see.
Similarly, 30 is more than adequate since we rarely see much above that. If you can get technical info and see the viscosity index and kinematic viscosity at each measured temperature point (40ºC & 100ºC normally), then you can see which brand is more fluid, which is better for fuel consumption and quicker to pump round the system when starting. So long as the API Class and weight are as per the owner's manual, you'll be fine - but some oils are "finer" than others. More reading - http://www.civictype-r.co.uk/forum/v...p?f=69&t=25347 Better oils would be: Mobil 1, Fuchs/Silkolene, Amsoil, Liqui Moly, Redline, Motul, than the generally sufficient big brands (Castrol, Shell, etc) FWIW, you should also be changing oil as per the severe schedule, especially if dino oil has been used - hydrocracked or not. It's a fallacy to believe oil lasts for 12 months or 12-15K miles. Last edited by PJS; 11th June 2007 at 20:31. |
#46 (permalink) |
PJS: re 'Better oils would be: Mobil 1, Fuchs/Silkolene, Amsoil, Liqui Moly, Redline, Motul, than the generally sufficient big brands (Castrol, Shell, etc)' what evidence is there that the first listed oil makers are 'better' than the last two? I also cannot see why severe service applies to all vehicles: again, is there evidence that accepted European extended OCI are harmful where correctly applied? Obviously there are certain patterns of use (short runs etc) where the oil should be changed early as the engine maker states this. Just wondering what info you may have.
#47 (permalink) |
The evidence is derived from the fact the former use PAO/Ester based synth base stock, whereas the latter use hydrocracked mineral oil.
As for severe schedule maintenance - I should clarify that that pertains to the hydrocracked oils rather than the true synthetics, but not exclusively. I'll see if I can dig out the link to where it was stated that oil degradation and therefore usefulness was reached with that sort of mileage - 5-7K miles. |
#48 (permalink) |
Some Castrol and Shell products use Gp IV and V, as well as severely hydrocracked Gp III. Some Mobil and Amsoil products are Gp III, some may well be Gp II. They all make a range of oils at various price levels. The 0w/30 Castrol oil is, I think, a Gp IV oil, as mineral derived oils are unlikely to achieve 0w/xx viscosity. It fully meets your preference for a full synthetic. So, why decry Castrol or Shell? I have no connection with the firms BTW: just curious about the stance.
#49 (permalink) |
I think you're reading too much into my original post - I wasn't decrying, but merely offering that the typical stuff a dealer will put in your car (if self oil changing isn't done) is adequate for the job it has to do.
Like all things - makes and specific models of cars included - some people prefer to go that extra bit beyond sufficient. The links above should be enough for most owners to help make their minds up whether the PAO type oils are more than they need, or exactly what they want to provide peace of mind for them. Haven't had a chance to find the link I had hoped to - but I will soon (he says hopefully!). |
#50 (permalink) |
Well, I've just had the 2nd (25,000 mile) service done. I took in two five litre containers of Amsoil 0W-30 in the boot, and asked the dealer to use it on the first line of the (very long) list of things to be done.
Sadly, I still have the 10 litres as that bit was missed. Very annoying, as the wear specs for the Amsoil are significantly better than for Castrol, and a fair bit better than Mobil 1. However the dealer has been very helpful otherwise, a number of other things were fixed at last, and I really didn't want to bring the car back again tomorrow to replace the Castrol - the offer was made. The dealer is anything but local, so it's a lot of extra time and mileage. I don't think this will happen again |
#52 (permalink) |
You lot are doing my head in with all this!
Went to the fuel station and saw Castrol Edge, was about to buy 0-30 but it did not specify if it was for Diesals so I left it. Now I find out you can use the same one for petrols and diesals. So safe bet is the Castrol 0-30 Edge/SLX AGREED? |
#53 (permalink) |
yes!
Castrol Edge (or SLX Longtec) 0w-30 is the perfect oil for diesel, petrol also exception: diesel with DPF there you should use Castrol Edge 0w-30 Diesel |
#54 (permalink) |
i will use the origianl honda 0w20 oil which is also good for the jazz 1.4, the thinner the better for the hp and fuel economy. the manual also says its allowed for the 1.8
#55 (permalink) |
yes that's also fine. but if you rev it hard etc. it will burn (a bit) more oil from the 0w-20
at my oil change I will buy the Edge or the Mobil1 0w-40 might be the second one... in these days the temp. was here 36++ C degrees here |
#56 (permalink) |
I really have concerns of what my dealer puts in during the service.
One thing I have done in the past is always ask for any oil left over in the bottle/tin. Recently I tried thesame with the dealership and the answer I got was that they buy a massive barrel of engine oil and they use that one for the cars. Straight away I didnt have a good feeling about it. Ask him to confirm they used 0-30 and after a slight delay it was the dreaded salesman answer of "Oh yeh they would of put the right one in!" |
#57 (permalink) |
sorry I ain't too clued up with oils, I have read this thread and am not 100% convinced which oil to use...I have the 1.8i-Vtec and live in SA, where we can temperatures of between 0 and 35, mostly our day temratures are above 10...What oil should I use?
#60 (permalink) | |
Hey Steve, Would be interested to here if your's is drinking alot (As I have the same model). Had mine nearly a week but haven't checked the oil as yet! (saving it till the weekend as an excuse to get out of the house and tinker with the new toy). Rich. |
| NHB - DIY Colour Coding - NOT recommended | TTDegs | How To | 35 | 27th October 2007 15:45 |
| 2.2 cdti to a 1.8 v-tec | christophe | Introduce yourself | 9 | 26th September 2007 19:12 |
| Winter 17" Winter tyres not recommended | pikkumies | Wheels, Tyres, Suspension and Brakes | 18 | 17th October 2006 12:19 |
| i-VTEC same as Type R VTEC | Chris | General Discussion | 3 | 31st July 2006 17:13 |
| Tech Honda 1.8 i-Vtec & 2.2 i-CDTI Engine Videos | WoolyCiv | Engines and Transmission | 0 | 22nd July 2006 22:55 |
