Exhaust Vapour/Smoke from Exhaust at Idle - Civinfo
 1Likes
  • 1 Post By tqp2001
post #1 of 10 (permalink) Old 16th February 2017, 13:31 Thread Starter
j0shimi's Avatar
Hi all,
I've had my Civic 06 1.8 ES for nearly a week now and last night after driving for about twenty minutes or so I hit traffic and saw a reasonably noticeable amount of vapour/possibly thin amount of white smoke from the right hand exhaust, I couldn’t tell whether it was coming from the left exhaust or if it just happened to be the wind direction making it appear to be the driver’s side exhaust.
It was only noticeable when idle and when starting to accelerate away, It wasn't exactly billowing out and hiding the cars behind me by any means and couldn't be seen again until I was stopped in traffic.
I has been cold and damp for the last week where I am so it could just be vapour but I'm really not sure if this is usual for Civic's from 2006 onwards, especially as I had been driving a good twenty minutes already.
Any thoughts would be appreciated, it looks to me very much like vapour as opposed to smoke but it was constant when idle and lit up by the car behind me.
j0shimi is offline
post #2 of 10 (permalink) Old 16th February 2017, 13:33
anthropolyte's Avatar
Car: 2008 Type R FN2, NHB
Pretty sure it'll just be vapour. Mine steams a bit in the cold when I've been in traffic for a while - I think it's just that the exhaust doesn't heat up sufficiently to vaporise all the condensation inside it, due to the engine not running at high revs.
It also steams a bit with the engine off for about five minutes after I've stopped... generally from the right hand exit (looking from the rear), likely because it's the closest pipe to the main exhaust section, so marginally hotter.
anthropolyte is offline
post #3 of 10 (permalink) Old 16th February 2017, 13:41 Thread Starter
j0shimi's Avatar
It doesn't seem thick enough to be smoke in my opinion but it seemed a bit odd considering I'd been driving the car a good twenty minutes at a decent pace, do these exhausts tend to stay reletively cool then?
j0shimi is offline
post #4 of 10 (permalink) Old 16th February 2017, 13:51
Not sure about the 1.8, but I have a Milltek on my FN2, which is wider bore than standard so arguably more metal. Stainless seems to stay colder than mild steel too, so maybe something to do with it...
Thanks to anthropolyte from:
post #5 of 10 (permalink) Old 16th February 2017, 13:53 Thread Starter
j0shimi's Avatar
I appreciate the input anthropolyte.
I would be interested to hear if anyone else notices this with their civic's, mine was kicking out a bit more vapour than most other cars I could see, everything seems to be running fine, no noticable smell from the exhaust either.
j0shimi is offline
post #6 of 10 (permalink) Old 16th February 2017, 16:56
Car: 2015 1.8 Tourer
Although very unlikely, it could be a bad head gasket or a fracture in the cylinder head. Check the oil if there is froth building up, monitor oil and coolant level. Especially rising oil level or loosing coolant would be suspicious. If reproducible, take a warming up drive, let it idle until the vapour turns up and go smell the exhaust. If the vapour has a somewhat sweet scent, that would be coolant burning and a clear sign for getting a check at the shop.
musegroove likes this.
tqp2001 is offline
Thanks to tqp2001 from:
post #7 of 10 (permalink) Old 16th February 2017, 17:43
Off-Road Nut!!!
1066 Boy's Avatar
Car: 2009 1.8 Type S GT
Mine dose the same thing in this cold weather. Not a single bit in the summer though, think its quite normal.
1066 Boy is offline
Thanks to 1066 Boy from:
post #8 of 10 (permalink) Old 17th February 2017, 07:53
sounds normal - mine does exactly that. It'll dribble water out of the holes in the rear pipe too, suggesting Honda knew about it and made a hole to drain it out.
1396midget is offline
Thanks to 1396midget from:
post #9 of 10 (permalink) Old 17th February 2017, 08:36
musegroove's Avatar
Car: 08 CTR, Milano Red
Does sound normal in this weather, I'm decatted and get a fair bit on idle on wet, colder days.
It can be as tqp described but you can usually tell from the smell and dropping coolant level over time.
Once it dries up should hopefully go away
musegroove is offline
Thanks to musegroove from:
post #10 of 10 (permalink) Old 17th February 2017, 09:41 Thread Starter
j0shimi's Avatar
Thanks for all the feedback guys, it doesn't seem to have any particular odour to it so I'm not too concerned, just wanted to make sure it wasn't anything out of the ordinary. Cheers again!
j0shimi is offline
  Civinfo > 8th Generation Euro Honda Civic > Engines and Transmission
Human Verification
Engine 2.2 I-CDTI excess smoke & poor idle / stalling ebod Bugs, faults and irritations 15 8th December 2016 23:58
White smoke came from my exhaust anti-rsca Bugs, faults and irritations (9G) 2 17th May 2016 21:25
Engine Engine cut-out and smoke/vapour emission J-Sev Bugs, faults and irritations 3 8th September 2013 14:30
white smoke from exhaust stuey88 General Discussion 44 28th March 2013 17:42
Exhaust loads of smoke from exhaust GT-S Engines and Transmission 14 28th January 2009 22:17
