This thread is about: i Shift change - new software, it's in Engines and Transmission at the Honda Civic forum Civinfo; I don't really understand the problem here. As far as I know, it is OK to "chip" your car or modify it in a way ...
Old 20th February 2007, 08:40   #41 (permalink)
pcr
pcr's Avatar
I don't really understand the problem here. As far as I know, it is OK to "chip" your car or modify it in a way that affects performance and/or emissions, as long as DVLA and your insurance are informed. So why is this any different ?
Old 20th February 2007, 14:07   #42 (permalink)
I-shift upgrade
The i-shift program is being updated and will be able to be inputted using the hds tablet at main dealers. it will basically improve the i-shift response, so say it will be sportier but i belive it to be just an improvement on a poor semi auto shifter...
af1grg is offline   Reply With Quote
Old 20th February 2007, 16:07   #43 (permalink)
mihael's Avatar
i shift
Brodick this is true however when the car gos into production knowing that the box has faults and the tecs are working on a solution Even before honda delivers its first i shift then you would think honda would intend to include all its i shift customers in the fix this is not like producing the car and then finding that there customer base would have preferred something like auto dip interior mirror so honda start including it as standard this i would not expect to get retro fitted or at a cost this is as already stated a fix for a known problem on the car no matter which way it is dressed up ie upgrade THIS IS A FIX ?
mihael is offline   Reply With Quote
Old 20th February 2007, 16:13   #44 (permalink)
mihael's Avatar
i shift
af1grg you sound like you know what you are talking about are you in the trade or is this just an educated response to the problem and do you think honda will recall all the i shifts to do this ?
Old 20th February 2007, 17:26   #45 (permalink)
Perfect Guy!
Brodick's Avatar
That's not my understanding been told by dealer that all cars need to go back to Honda - dealers cannot immplement the upgrade
having driven one or two i-shift's now mihael I have to say that this is not a fix the cars I have driven have been fine - yes there is some room for improvement but nothing wrong in general with the system
it sounds to me as if you have other issues - go and speak to your dealer!!
Old 21st February 2007, 02:05   #46 (permalink)
i-shift
i know a fair bit about honda a specialize in fault code diagnostics for honda (HUM) i hear a fair bit of what goes on in and around the production plant. the i-shift was not all that good so they are developing it to improve response as many customers have complained.
Old 21st February 2007, 06:56   #47 (permalink)
Cannot be done by the dealer and therefore must go back to Swindon!
How do they intend to implement that considering cars are now in dealers waiting for March?
Stop Press: Dealer just rang to confirm 3rd March and confirmed that it had already got the upgrade. He seemed to know all about it.
Old 21st February 2007, 16:27   #48 (permalink)
mihael's Avatar
i shift
Hi Kremmen which dealer have you used would like to find out more about the i shift change and if they know all about it this may help me
Old 21st February 2007, 16:31   #49 (permalink)
mihael's Avatar
i shift
Hi af1grg do you know is the change just software change if so why do the cars have to back to swindon
Old 21st February 2007, 17:03   #50 (permalink)
mihael's Avatar
i shift
Brodick issues i have with honda are simple having test driven many i shifts since dealers first started to get them in and then waiting until September to get my i shift in the right spec that i wanted and all the time having some doubts about the box as i really wanted a normal auto that as we know is not going to happen with certain reassurances from many honda personal on the box and at times strong assurances that work was ongoing to improve the shift system and it would be available to old i shifts yes i did go for the i shift and yes in general it gos well but after driving it since sep and putting 7000 miles on the clock it still jerks at times and it sometimes seams to take a long time to select the right gear once or twice nearly causing an accident on a roundabout due to lack off power for a split second having spent nearly £21000 i don't expect to have fixes,improvement,upgrades or what ever you like to call them happen to the box six months after getting the car with these issues known only to find out Honda have come up with an improvement and hard luck to any previous customers that bought in good faith
Old 21st February 2007, 18:12   #51 (permalink)
Perfect Guy!
Brodick's Avatar
Interesting - just been to our dealer to hand over cheque for balance
dealer said they are still awaiting confirmation of where our car is at
(upgrade wise From Honda) still hopeful for the 1st but will be in touch
Old 22nd February 2007, 07:21   #52 (permalink)
If the supplied car has not had the upgrade but they put the band D tax disc on they who's kidding who ?
I wonder if some dealers do have the required tools to perform the upgrade to the box but will only do it at service time to avoid too many visits?
Old 22nd February 2007, 13:01   #53 (permalink)
Wilky's Avatar
I've just been to my dealer to finalise the details of my new Civic for delivery on the 1st March (EX i-Shift) and asked about the new i-Shift software. He knew all about it and referring to the brochure I have, this is my take on the situation.
Some Civics (all EX and Sport and the MANUAL versions of the 1.8 S,SE and ES) have always been Group D. The i-Shift versions of the S, SE and ES are/were in Group C but only just... (149 g/km CO2 emission). If the new software increases the emissions (don't know by how much but I imagine it's not a massive amount), I guess it would just affect the latter from a VED point of view.
He also said that any cars that had been due at the dealers before 14/2 were held back for the mod (hence the delays mentioned), any due after that date should arrive as expected. He wasn't sure whether the mod would be available retrospectively on any of the models that would subsequently change VED band.
Wilky is offline   Reply With Quote
Old 22nd February 2007, 14:03   #54 (permalink)
Charles_Harding's Avatar
I'm very happy the way my i-Shift behaves and if it means I would lose 1 mpg and £25 more in road tax in the upgrade I'll stick with what I've got, cheers!
"If I'd known that I was going to live this long I would have taken better care of myself!"
Charles H.
Old 22nd February 2007, 20:43   #55 (permalink)
Perfect Guy!
Brodick's Avatar
Charles H.
Good to hear you are happy with the i-shift Charles
Dealer called today to confirm car in Swindon - and should be with us for the 1st - not bothered if it is a couple of days late ( infact would rather it was late than a rush job) will be interesting to see how she handles when we get her on the road
Old 22nd February 2007, 22:01   #56 (permalink)
mihael's Avatar
I SHIFT road tax costs
How much road tax is your car costing ex with i shift £125
how much is the new i shift going to cost ?
Old 23rd February 2007, 02:07   #57 (permalink)
i-shift upgrade
i have been told that the i-shift has been a fundamental let down and there for honda is redesigning the entire i-shift, from gearbox upwards.
Old 23rd February 2007, 12:13   #58 (permalink)
mihael's Avatar
i shift
af1grg when you say redesigning completely i presume the change being offered to new customers at the moment is just a miner software change then, so if what you have been told is right honda will be bringing out a totally revamped i shift box latter ? to make up for the poor auto box they have at the moment
Old 23rd February 2007, 12:29   #59 (permalink)
Let's hope I can get used to the i-shift as it currently stands. I have been used to auto's since the 1970's.
And I still think the latest batch of semi-intelligent auto's that apparently 'learn' your driving style are not as good as the old one's that changed at set speeds. At least you learned when it was going to change and semi-compensated.
The one thing that will take some getting used to is the lack of a 'P'ark facility to lock the transmission. Currently I stuff it in 'P' and don't bother with the handbrake - could be a tad disasterous if I park on an incline
Wish - in 3 years time I can get a 2.2 diesel Civic with a standard auto gearbox - end of wish
Old 23rd February 2007, 13:47   #60 (permalink)
BrianI's Avatar
You just leave it in the auto or manual position and it locks the transmission with the engine off.
Brian
BrianI is offline   Reply With Quote
LinkBack to this Thread: http://www.civinfo.com/forum/engines-transmission/3616-i-shift-change-new-software.html
Forums CivicYume • Afficher le sujet - ECU pour les i-shift 2006 ! This thread Refback 19th June 2008 18:23
I-Shift. This thread Refback 26th February 2008 19:35
AberdeenBikers.co.uk :: View topic - Who's a good law firm? This thread Refback 19th November 2007 13:06
Similar Threads for: i Shift change - new software
Engine Less power after 'software update'? Ovideo Bugs, faults and irritations 14 21st July 2007 00:01
Things I would like to see in a software update FWH General Discussion 20 3rd July 2007 13:47
WTB: 07 Type R shift knob and shift boot 06Fg2 For sale and Wanted 46 2nd May 2007 06:03
Transmission Gearical transitionary......umm (i shift gear change speed) wolverine Engines and Transmission 5 2nd February 2007 00:16
Search Engine Friendly URLs by
