![]() Join Date: 5th March 2009
Thanks given: 226
My CG motorsport 2.2 i-CDTI Clutch kit
Has arrived today with an uprated pressure plate, 5 paddle cerametallic friction plate and LUK O.E.M. flywheel! £744.89 all in with postage.
It gets fitted on Tuesday. |
Thanks given: 226
44,000miles and I will be keeping the old parts for inspection. Annoyingly it isn't slipping at the moment but has done repeatedly on three separate occasions in the last 5-6 weeks or so. The clutch is self adjusting which may be happening at the moment - I don't know. I would hope that the flywheel is O.K. but I am changing now to save potential expense later on.
Hello Chip, i also had a problem with my clutch, then i red that you ordered the uprated clutch at CG motorsports, so i did too. let it installed today and the pressureplate and flywheel are the same as what did come of, only the friction plate was specially made for the needs of the car. my clutch got slipping at 92000 miles, so that's not to bad, by me the problem was that some grease, what's between the dualmass-flywheel is, come on to the friction plate causing it to slip.
have to drive slow for the first 500 miles, but i'll keep it up to date who it goes with this clutch. for me there was also a big price different, because in Holland, only the dualmass-flywheel cost around 1100 pounds, originel at the Honda garage. |
#9 (permalink) | |
Thanks given: 226
Thanks, Chip |
the guy who did the jib, said that is was grease from the Flywheel, and you also could turn the flywheel to far to the left and right, so that was finished.
when i pull away, it bites much better, first, a lot of times the engine stolled, but now it drives away like a diesel should do, did only 40 miles today, so when i drive more i'll tell you more about it. |
#11 (permalink) | |
Thanks given: 226
#12 (permalink) |
![]() Car: 2006 2.2 ES, NHB
Thanks given: 2
Just being nosey buy how much are you being charged to fit the clutch and flywheel? In the future i might be tempted to try this myself. £700 odd for clutch and flywheel, i remember paying ~£90 for my (long long gone) fiesta's clutch
BFM |
#15 (permalink) |
Thanks given: 226
My flywheel was also dead
#19 (permalink) |
![]() Car: 2006 2.2 5d ES, Galaxy Grey
Hi Chip,
I've just been getting this whole slipping clutch issue that seems to be plaguing the 2.2s, seems like the flywheel is the problem more than the clutch. What made you decide to go for another stock dual-mass one and not maybe a solid one instead? I've had mine show slip under load in 5th & 6th, but is generally fine at the moment. So anticipating a full on failure in the not too distant future, I'm trying to work out what's the best way to go. Hence why I'm curious about you going for a performance clutch but sticking to a standard flywheel. Cheers. |
#20 (permalink) | |
Thanks given: 226
2.I was worried about killing the gearbox if I fitted a single mass flywheel. 3.The DMF from Clutch and Gearbox was £321.89 all in, whereas a custom single mass flywheel from Helix autosport would need development which would equal BIG money to be the first to have it done! I still have the old and dead DMF that was taken out for anyone who is interested. I am in two minds about whether I have done the right thing regarding the clutch upgrade. I am still thinking about further engine mods in the future (intercooler) but the judder in 1st gear is a bit grim, so unless you are doing serious tuning I wouldn't bother with the uprated clutch. |
Thanks to Chip from:
Similar Threads for: My CG motorsport 2.2 i-CDTI Clutch kit
| Koni FSD @ abp motorsport | ABP Motorsport | ABP Motorsport | 27 | 25th August 2010 22:27 |
| Clutch Creaking clutch 2.2 CDTI | babycat | Engines and Transmission | 13 | 27th December 2009 13:26 |
| Forza Motorsport 3 | Horizon | Any non Civic chat here please! | 4 | 11th October 2009 09:30 |
| Tuning 2.2 cdti Clutch upgrade????? | bazno1 | Engines and Transmission | 3 | 21st February 2009 01:08 |
| England Midlands ABP Motorsport FRS Day | WeHaveLiftOff | Past Events | 16 | 17th November 2008 00:37 |
