Transmission Can't find dipstick to check transmission fluid - Civinfo
 1Likes
  • 1 Post By lightningslow
post #1 of 14 (permalink) Old 19th April 2017, 17:05 Thread Starter
Hi I've been looking in the manual and on the forum but can't seem to see where the dipstick would be to check the transmission fluid. I have the 1.8 civic 56.
Juggernought is offline
post #2 of 14 (permalink) Old 19th April 2017, 17:11
If it's an auto gearbox then it'll be a yellow handled dipstick somewhere near the battery/airbox going into the transmission, if it's a manual then there won't be a dipstick.
Sent from my E6853 using Tapatalk
RollingChaos314 is offline
post #3 of 14 (permalink) Old 19th April 2017, 17:15 Thread Starter
Ok it's a semi automatic so I'm guessing there's no dipstick. Any idea how to check the fluid if there's no stick.
post #4 of 14 (permalink) Old 19th April 2017, 17:27
Oh is it I-shift?
post #5 of 14 (permalink) Old 19th April 2017, 18:05 Thread Starter
Oh is it I-shift?
Yeah there's only two pedals but you have the choice to drive manual with it.
post #6 of 14 (permalink) Old 19th April 2017, 18:08
Does it look like a manual gear selector with neutral to the right, reverse below it, and automatic/manual over to the left?
post #7 of 14 (permalink) Old 19th April 2017, 18:08
jaxckhan's Avatar
with the i shift its a sealed system, in other words there is no dip stick, there should be a fill point and a drain point, so if you are deciding to do a transmission fluid change, drain it, and fill it till it trickles out the filling point,
jaxckhan is offline
post #8 of 14 (permalink) Old 19th April 2017, 18:59 Thread Starter
Ok thanks. Yeah I'm looking to change the fluid but wanted to check the condition before.
post #9 of 14 (permalink) Old 19th April 2017, 19:03
It's the same as a manual box so it only needs to be changed after 75,000 miles but more than likely the clutch will go before then and the oil will be changed with it. But I didn't think the 1.8 engine came with an i-shift box.
post #10 of 14 (permalink) Old 19th April 2017, 19:20
lightningslow's Avatar
Theres no transmission level check as its a manual box which takes about 1.6L of fluid and is a sealed system. Theres a drain and a fill hole and thats about it. No torque converter in there as its a 6 speed computer controller manual box with a clutch!
As for the fluid, 2L od MTF will see you right. Drive it to get it up to temp, undo the fill bolt first before you undo the drain bolt. Drian it all out, replace Adrian bolt with new crush washer. Pump in as much fluid as the box will take before it starts spilling out the side. Wait until it dribbles out slightly as this is how you make sure its level fill. Pop fill bolt on with new washer and thats about it!
jaxckhan likes this.
lightningslow is offline
post #11 of 14 (permalink) Old 19th April 2017, 19:37
marcinwednesbury's Avatar
Car: 2007 Type S I Shift
i just done gearbox oil change well worth doing on i shift
marcinwednesbury is offline
post #12 of 14 (permalink) Old 19th April 2017, 20:05
scaramanga's Avatar
Car: 2.2 ctdi
people saying theres no level check isnt exactly correct
most gear boxs( and diffs on rear wheel drive cars) have a plug on the side similar to sump drain plug that is your level check just fill till it starts to dribble out
scaramanga is offline
post #13 of 14 (permalink) Old 19th April 2017, 20:38
Yes
post #14 of 14 (permalink) Old 20th April 2017, 12:42
peter66's Avatar
Car: 2006 blackhawk 1,8 i-shift
Hi
what do you mean transmission fluid , in i-shift there are in gearbox as in manual transmission 1,8l MTF3 and in actuator DOT4 brake fluid . In actuator system you can change DOT4 during CLUTCH FLUID AIR BLEEDING, the procedure in HDS system and the static learning procedure is required, you must looking for filling the fluid bottle during it and close the nut when program ask for it.
???????? ??????? i-SHIFT - ??????????? ?? ???????????? ? ??????? Honda Civic 3D
???????? ? ?????? MTF (????? ??? ???????????? ???????????) - ??????????? ?? ???????????? ? ??????? Honda Civic 3D
good luck
peter66 is offline
  Civinfo > 8th Generation Euro Honda Civic (2006 - 2011) > Engines and Transmission
Human Verification
Which Transmission Fluid? Sparky160 Type-R 3 7th September 2016 18:52
Transmission Transmission Fluid Jalalul83 Engines and Transmission 1 17th May 2016 17:53
Transmission Transmission fluid, Which one to get? MikeT4 Engines and Transmission 6 14th September 2014 10:50
Transmission Transmission Fluid wiimad Engines and Transmission 5 3rd February 2013 23:04
oil dipstick check 2.2escdti General Discussion 9 21st March 2012 23:04
