Oil Would this oil brand do for a 1.4 i-vtec? - Civinfo
 3Likes
  • 1 Post By Harryhonda98
  • 2 Post By bfranklin
post #1 of 8 (permalink) Old 17th May 2017, 23:13 Thread Starter
slashninjaken's Avatar
Car: 2009 1.4 i-Vtec si, Black
Just did some research on the wiki and this is what I gathered. Recommended 0w-20 or 0w-30, spec standards: API SN, ILSAC GF-5, can use ACEA A3/**. Oil capacity is around 4.2 litres and Fuchs 0W-30 was used at the factory. So the cost:
Castrol Edge Professional H 0W-20 Fully Synthetic Engine Oil 4 Litres = £43.12 inc vat (I'm sure cox can help me out with a discount)
TITAN Supersyn LONGLIFE PLUS 0W-30 = £34.99 inc vat (might get a discount from opie)
Finally, I found THIS!!! Petronas Syntium 7000 0W-20 - 5ltr = £ 22.78 !!!! from carparts4less, meeting API SN and ACEA C3, ILSAC GF-5. Surely I'm missing something? Why is this so cheap? Petronas any good? And have I just found a gold mine and advertised it to the world... if that's the case great I'm sure they'll take it down in a jiffy.
slashninjaken is offline
post #2 of 8 (permalink) Old 17th May 2017, 23:27
Not sure it needs 4.2 litres, my experience says about 3.7 or 3.8, can't speak for the brand but I'd personally rather spend an extra £20 for oil I trust.
Sent from my E6853 using Tapatalk
RollingChaos314 is offline
post #3 of 8 (permalink) Old 18th May 2017, 05:54
marcinwednesbury's Avatar
Car: 2007 Type S I Shift
Alwas use best oil other than cheapest one would not use my car as oil tester
Wysłane z mojego SM-N9005
marcinwednesbury is offline
post #4 of 8 (permalink) Old 18th May 2017, 07:16
Harryhonda98's Avatar
Car: 2009 honda civic type s 1.8
Eco display Eco display
Send a message via AIM to Harryhonda98 Send a message via MSN to Harryhonda98
Honda recommends Castrol I would stick to that.
Sent from my SM-G920F using Tapatalk
marcinwednesbury likes this.
Harryhonda98 is offline
post #5 of 8 (permalink) Old 18th May 2017, 11:15 Thread Starter
I agree Honda endorses Castrol, I just hope it isn’t due to marketing hype but extensive lab research behind it's support. For me brand isn’t the most important aspect of choosing a product but the science and quality behind it.
Petronas seems to have good reviews, people use it on their Mercs and BM’s as well, one of the boasting features of this oil is “CoolTech” which keeps the engine cooler compared to other oils. On another forum someone done a dyno test quite a while back on Petronas and interestingly had a decent uplift on their BHP here
I think I may just stick to Castrol like most, as I too don’t want the risk factor although it would have been insightful if someone tried Petronas before and shared their experience. My guess is the other oils are more costly due to high quality cleaning / protective additives which Petronas may not have.
post #6 of 8 (permalink) Old 18th May 2017, 11:42
Car: 2010 1.8 Si 5dr, Blue
You could always ask for the opinion of Oilman in this thread here:
Oil advice and recommendations here
Farqui and slashninjaken like this.
bfranklin is offline
post #7 of 8 (permalink) Old 18th May 2017, 11:53 Thread Starter
What a brilliant idea @bfranklin If you was a girl, I would of kissed ya!
post #8 of 8 (permalink) Old 25th May 2017, 08:18
chillidog's Avatar
Car: 0A Red Civic Sport
I'd stick with 0W30 or 5W30. My last oil change at the dealers was 0W20, but the engine is running rougher. 0 or 5 is OK for cold conditions, but I'm thinking the 20 when hot is a bit too thin. It clatters more under load and gathers more petrol, which in turn degrades the oil faster. Petronas is just fine for regular road conditions.
chillidog is online now
  Civinfo > 8th Generation Euro Honda Civic (2006 - 2011) > Engines and Transmission
Tags
oils
Human Verification
P2646 HONDA VTEC Oil Pressure Switch Circuit Low Voltage, after FD2 oil pump instaled goa_party Type-R 17 1st May 2016 13:25
Brand New Civic - Oil Warning Light=Very Low Oil 12watch General Discussion 23 11th February 2015 18:48
VTEC, no oil and the M4 GoatMasterUK General Discussion 140 2nd March 2013 10:43
Faults i-vtec oil leak from vtec valve? impreza Engines and Transmission 0 9th January 2011 21:23
Oil 1.4 i-vtec oil CatherineJ Engines and Transmission 18 14th September 2009 23:23
