Old 27th February 2010, 12:21   #1 (permalink)
Thanks given: 3
celtic tuning file only problem
Hello Everyone.
I am experiencing a problem with my Type S 2.2. It is a MY09 model. I brought the gelleto 1260 tool of ebay and I have purchased a file only re-map from Celtic Tuning. I also have a Samsung NC10 Netbook, which seems to be the same as the one used to re-map on You-Tube. I downloaded the map off my car no problem, sent to the Celtic to be modified, but everytime I go to put it on the car, it clears the ECU and when it goes to write, it Errors. Been back on to Celtic, they have modified the map 3x now, and taken out all security, and even tried zipping the file, but still the same problem. They say now, it may be the computer, but I am not so sure, cause I have put my standard map back on 4 times now. Has anyone had a similar problem?
Thanks Andy.
andy00009 is offline   Reply With Quote
Old 27th February 2010, 12:59   #2 (permalink)
Newt1's Avatar
Car: 2006 2.2 ES i-CTDI
Thanks given: 2
Power ?
Check you have mains power to the laptop. Sometimes these USB ports voltages drop in battery power saving mode.
Worth a quick go anyhow.
Good luck
Newt1
(Let me know how u get on with the remap cos I'm on the verge of doing exactly the same with Galetto / Celtic remap)
Newt1 is offline   Reply With Quote
Thanks to Newt1 from:
Old 27th February 2010, 13:43   #3 (permalink)
guido09's Avatar
Car: 2007 2.2 sport Champ. Met.
Thanks given: 1
i had the same problem, however the 3rd time they fixed it.
Had to do something with checksums.
Tony from Celtic helped me out with this.
guido09 is offline   Reply With Quote
Thanks to guido09 from:
Old 27th February 2010, 16:24   #4 (permalink)
Fabia vRS
H17YD_L's Avatar
Car: 2011 Fabia vRS
Thanks given: 4
I have the map file only from Celtic. It sounds to me as if there is a problem with the map from Celtic if it will still write your original. It may be that they have given you the wrong one as there are a few different firmware versions for the different model years. You can tell by connecting the galletto up and press 'ecu data' and it will give you your cars firmware i think its about 12 digits long then email this to Celtic and ask them to check they are sending you the right one.
NC10 should be fine its what i used (i didnt need to connect to mains just works off the laptop battery)
H17YD_L is offline   Reply With Quote
Thanks to H17YD_L from:
Old 28th February 2010, 12:56   #5 (permalink)
Thanks given: 3
Thanks for your help. We have just emailed Celtic with the ECU data. Just awaiting their reply. Will post the outcome. Thanks again guys for all your help.
Andy.
Old 1st March 2010, 13:29   #6 (permalink)
Thanks given: 1
Originally Posted by guido09 View Post
This one was an issue with ID tags which is not the same issue arrising on this occasion.
Celtic tuning is offline   Reply With Quote
Old 1st March 2010, 13:30   #7 (permalink)
Thanks given: 1
If we gave the wrong hardware variant the car would no longer recover the original file and I assure you we have never given anyone the wrong software variant.
Old 1st March 2010, 18:56   #8 (permalink)
Fabia vRS
H17YD_L's Avatar
Car: 2011 Fabia vRS
Thanks given: 4
If you put the wrong variant on the car, the car will have the problem as described by Andy, then you simply put the original map back on and it will work.
Similar Threads for: celtic tuning file only problem
Remap Celtic Tuning re-map Top Gun Engines and Transmission 107 24th March 2011 17:14
Group buy Celtic tuning map (File Only) H17YD_L Group Buys 35 28th September 2010 16:25
Remap Celtic tuning - map only? H17YD_L Engines and Transmission 161 8th June 2010 22:35
Remap Celtic Tuning Remap - DIY andy00009 Engines and Transmission 4 11th October 2009 14:19
Tuning Celtic tuning bazno1 Engines and Transmission 15 21st April 2009 16:55
