This thread is about: Cat smell in car when accellerating, it's in Engines and Transmission at the Honda Civic forum Civinfo; there seems to be a smell coming into the cabin through the air con when accellerating down a sliproad to join a motorway, at first ...
Old 26th July 2006, 19:17   #1 (permalink)
Mr. Foglights
civicsport's Avatar
there seems to be a smell coming into the cabin through the air con when accellerating down a sliproad to join a motorway, at first i just thought it was from the car infront but today there was no one in front and it was there again , i`ve had a quick look at the exhaust manifold after the cat and theres a pipe comes off and goes into a block with an actuator on top then comes out of the left hand side and goes under the alternator to who knows where , does anyone know what the actuator is for, is it for the vtec?, is this opening at high revs and leaking causing the smell?
any help or opinions welcomed :P
Cheers Martyn
Old 26th July 2006, 19:31   #2 (permalink)
Mr. Foglights
civicsport's Avatar
Well i`ve answered one question which brings me to another, the pipe to the left is from the cooling system to the water pump, so where do the exhaust gasses go???
Old 26th July 2006, 19:47   #3 (permalink)
The pipe could be the egr - this won't make any smells!
When you give the car full throttle, the aircon turns off - can you recreate the smell by switching the aircon off? Or at least the compressor (by going into econ mode - I don't have a sport, sorry).
Aircon can pong when switched off - it's nasties that grow in the moisture in the system, but it shouldn't happen to such a new car.
Old 26th July 2006, 19:52   #4 (permalink)
Mr. Foglights
civicsport's Avatar
Dont have an EGR and i dont think its the a/c, deffo smells like the exhaust but can`t understand how its getting into the cab.
Old 26th July 2006, 21:24   #5 (permalink)
basegreen's Avatar
Re: Cat smell in car when accellerating
Cheers Martyn
Smelt this for the first time last week.
Old 26th July 2006, 21:54   #6 (permalink)
Mr. Foglights
civicsport's Avatar
What conclusion have you come up with BG
Old 26th July 2006, 22:34   #7 (permalink)
basegreen's Avatar
I assumed that it was something to do with working the engine hard in hot weather.
Its a sort of gearboxy smell in my opinion (if indeed it's the same thing)...
Old 26th July 2006, 22:49   #8 (permalink)
kan2's Avatar
i had this once the exact same place, on a slip road going onto a motorway, i felt it smelt a bit like burnt plastic, hasnt ever happened since though.
kan2 is offline   Reply With Quote
Old 26th July 2006, 22:54   #9 (permalink)
basegreen's Avatar
I got mine coming off a roundabout, at 6000rpm
Old 27th July 2006, 09:05   #10 (permalink)
Smell My Cheese!
richierich's Avatar
6000rpm, the stuff of dreams for us dieselies.
Do any of you actually own a cat that could have crawled under the bonnet of an evening without you knowing. It happened to my mother-in-law, unfortunately series 2 Land Rovers running on African fuel make a hell of a noise on starting, it was several days before the air dried remains were found after noticing a bad smell.
Old 27th July 2006, 11:26   #11 (permalink)
elfa7's Avatar
6000 rpm on a roundabout --- was it from your trousers ??
Old 27th July 2006, 11:33   #12 (permalink)
elfa7's Avatar
Just a thought. I know its usually an "eggy" smell, but could it be the Catalyst ?.
Old 27th July 2006, 11:41   #13 (permalink)
basegreen's Avatar
Nah, it was perfectly safe, just couldnt be bothered changing gear
Old 27th July 2006, 23:15   #14 (permalink)
12th June 2006 1.8EX
WoolyCiv's Avatar
I have had a smell as well (but would have described it more like singed feathers) and it seems to occur around 6000 or more as well.
Old 28th July 2006, 07:05   #15 (permalink)
elfa7's Avatar
You've obviously had a strange bird in the car !!!
Old 28th July 2006, 23:26   #16 (permalink)
WoolyCiv's Avatar
Similar Threads for: Cat smell in car when accellerating
New car smell vtec-hungry Type-R 21 26th September 2007 10:37
Smell my cheese! richierich Any non Civic chat here please! 3 23rd March 2007 17:24
horrid smell markymark81 Cleaning and Styling 16 5th March 2007 13:03
Can you smell something?!?!?!? Kpow99 Any non Civic chat here please! 1 6th December 2006 18:16
My car Car so close i can smell it daz Buying, Dealers and Servicing 6 8th November 2006 10:46
