Old 2nd February 2011, 21:14   #1 (permalink)
griffian's Avatar
Car: 2007 2.2 i-cdti ES NHB
Thanks given: 446
Camber bolt washer location???
Hi all
I recently purchased camber bolts from ABP for my 2.2 civi in order to set it to FRS.
However when we were changing my springs yesterday we went to put the camber bolt in the top of the strut.
However we couldn't work it out?
Any ideas?
Notice the tabs on the washer.
There are no cut outs on the strut.
Are they the correct bolts?
Please see the photos below.
Attached ThumbnailsClick the image to open in full size. Click the image to open in full size.
griffian is offline   Reply With Quote
Old 2nd February 2011, 23:37   #2 (permalink)
coste1l's Avatar
Thanks given: 1,113
did i not answer this? im sure i did? the tab lines up with the high part on the cam lobe and will go into the hole the bolt came out of
coste1l is offline   Reply With Quote
Old 3rd February 2011, 00:45   #3 (permalink)
griffian's Avatar
Thanks given: 446
Hi Lee
I have had a think about it and I cannot see how as the hole in the strut is smaller than the washer if you see what I mean.
Is there any chance of you taking a photo of it on car when you can? As I want to get it done as soon as possible. It would be much appreciated.
Many thanks Griffian.
Old 3rd February 2011, 01:07   #4 (permalink)
Civinfo Wind Up Merchant
Scotty182's Avatar
Car: 56' 2.2, 5 door, 195bhp
Thanks given: 24
Wrong section matey, should be in Suspension
Scotty182 is offline   Reply With Quote
Old 3rd February 2011, 09:09   #5 (permalink)
coste1l's Avatar
Thanks given: 1,113
The little tab on the inside of the washer sits in line with the top of the cam lobe and goes inside the hole the washer then sits between the strut and the bolt head. Taking a photo isnt going help mate as it doesnt matter where the big tab on the washer is sitting its just the point you start from when you start to change the camber
Thanks to coste1l from:
Old 3rd February 2011, 13:18   #6 (permalink)
griffian's Avatar
Thanks given: 446
Thanks matey
Similar Threads for: Camber bolt washer location???
Camber bolt washer location??? griffian ABP Motorsport 4 3rd February 2011 15:31
Steering Camber bolt tab washer for Fast Road setup griffian Wheels, Tyres, Suspension and Brakes 5 3rd February 2011 13:54
Spacesaver bolt Rodders001 Items wanted 0 3rd September 2010 18:48
CRZ bolt ons emerge.... Dr_D Honda CR-Z 8 6th April 2010 23:24
Other Missing bolt ? GreasyPole Engines and Transmission 7 2nd August 2009 15:10
