![]() Car: 2007 TypeS GT2.2 Red
Thanks given: 6
Oil consumption
SO,
I had my car serviced at Brown Bros in Peebles on Valentines Day with 42something thousand miles on the clock, its now got 44thousand and my oil light has been on for low oil?? Having checked all about, there is no leak, surely I cant have burnt off that much in 2000 miles??? Please discuss, anyone else had this issue? |
![]() Car: 09 Suzuki Swift Sport white
Thanks given: 1,185
i take it you have checked the actual level? did you check the level after the service? do you check your oil
Cockup Specialist
Thanks given: 762
Have you actually got low oil or just the warning light ?
There is an ECU update for ghost oil sensor |
Thanks given: 6
I was travelling motorway at the time, PI-PINGthe oil light comes on...
I waited the book stated three mins before checking oil and spot on the Min mark Garage didnt have 0-30w (sigh) so topped up with 5-30w and will be checking it first thing tomorrow morning. After topping up no oil light again for the remaining 150 miles. I normally know my oil, I didnt check it recently as its only just been serviced... |
Thanks given: 1,185
Thanks given: 6
What is the top up requirement between Min and Max, I must have missed that in the book, I put in a half litre.
Phoned BrBros but they just said keep and eye on it |
Thanks given: 1,185
not sure mine never goes below 3/4 on the stick and takes about 250ml so im guessing a litre?
Thanks given: 6
Ill check tomoror morning , see how it goes.
I bet the motorway miles just chomped it all up :S Thanks |
The flying Dutchman
![]() Car: 2007 2.2 I-CTDI Sport
Thanks given: 54
mine is basicly the opposite, after 22K km the oil hasnt gotten lower AT ALL, not a drop
which is odd as the dealer told me to keep a lookout for the oillevel getting lower as it is very thin (0w30) |
![]() Join Date: 29th September 2009
Thanks given: 1
Similar to the orginal poster, I had my car serviced towards the back end of last year.
At the Service interval it had not seemed to have used a drop, and had done 10,500 miles. I am slightly slack in checking it frequently, but on my last check it was about 2/3rd -1/2 the way down the stick (which was about 2-3 weekends ago), when today my low oil warning light came on. I have only done about 3,000 miles since the last service, so would this be about right? I also only put a litre in, and it seems to filled it up to the correct position? I would have thought it required more if the warning light was on? I was just wondering why pre-service it didnt show to use a drop, but post service, it has had the warning light come on in 3,000 miles. Thanks in advance. Last edited by saeagle; 8th March 2011 at 15:08. Reason: missed out a point. |
#13 (permalink) | |
Thanks given: 1
If not meant for me, sorry. |
#15 (permalink) | |
I vtec'ed your mum!
![]() Car: 2008 Civic Type R, NHB
Thanks given: 74
Edit*** 1 litre in a Type R... I assume its the same on diesels. Last edited by fonejacker; 8th March 2011 at 16:12. |
#16 (permalink) |
I vtec'ed your mum!
Thanks given: 74
You'll probably find you only have a low pressure light. Low pressure is caused by low levels of oil, so they basically mean the same thing. Well... dont take that word for word, there are some differences, but if that light shows up, then check your oil!
#17 (permalink) | |
Thanks given: 1
Cheers Fonejacker. And you reckon its only a litre to fill it up? Any reason why it may have gone down so quicly as compared to last time? |
#18 (permalink) | |
I vtec'ed your mum!
Thanks given: 74
Yes, 1 litre is the difference between MIN and MAX |
#19 (permalink) | |
Thanks given: 1
It has only done 12,500 miles. So not sure if that is considered high or low? Its about 18 months old. I have filled it up with 1 lt, but now seems to be above the maximium? should I take it into the nearest garage and get it sorted, or will this be ok? Cheers again. |
#20 (permalink) | |
I vtec'ed your mum!
Thanks given: 74
Regarding your car, that's low mileage, so wouldn't explain the low oil pressure or relate to the above so forget that. Have you heard knock's from the engine at all? I am assuming thats a no! I just want to make sure no damage to the engine has occurred. If the oil has come down rapidly then expected, then this could be due to a failed gaskets and/or seals. Sometimes your oil filter will leak if not fitted correctly so check that also! However, if its an oil burning problem, this means the valve guides, rings and/or cylinders are worn or damaged and more costly repairs are needed. Either way, get yourself booked into the garage for safe measure... Or keep tab's on your oil level over the next few weeks, check daily, record daily. It shouldn't move much, if at all over a couple of weeks.... |
Similar Threads for: Oil consumption
| Oil Heavy oil consumption or not | Graffitimc | Engines and Transmission | 6 | 23rd April 2010 08:51 |
| MPG fuel consumption....is it just me?? | goldylfc | Engines and Transmission | 83 | 28th March 2010 17:10 |
| MPG Our 2.2D Type S Consumption | CatherineJ | Engines and Transmission | 29 | 10th January 2009 15:55 |
| Oil Oil Consumption!!! | blader | Engines and Transmission | 37 | 10th December 2008 12:00 |
| Excessive oil consumption in 1.8 | 12watch | Wiki Article Discussion | 0 | 16th August 2008 18:57 |
