![]() Car: Type-S GT, Vivid Blue
Thanks given: 1
Need a little help
I am going to change the oil, oil filter, air filter and fuel filter on my 2.2 next week after being quoted £389 from my local Honda garage!!
I have read a few posts about how to get into the sump with the engine tray cover thing so that should be fine. I am looking for a little information on the fuel and air filter, does anyone have a picture of where it is? and how to change it? and once the fuel filter is changed do I need to prime it again or am I thinking of something else? |
Cockup Specialist
Thanks given: 740
The fuel fiter is in the can behind the airbox bolted to the bulkhead.
You need to drain it then prime it after changing. Battery has to come out to get the airbox out to get to the fuel filter can. Priming bulb is under that metal box lid in the middle of the engine bay at top. Be gentle with the airbox so you dont damage the MAF sensor or yank on the wiring plug. The cold air feed is a pain that makes removing the airbox a little awkward.... as does the flex pipe connected to the back of the airbox which has to be slid off before you can get the airbox out. There is one bolt at the front base of the airbox.... then it needs to be popped upward to pop the rubbers off the barbed rods on the left and right. http://www.hondaoriginalparts.com/ho...&block_03=9918 http://www.hondaoriginalparts.com/ho...&block_03=9918 http://www.hondaoriginalparts.com/ho...&block_03=9918 Last edited by Relic; 7th March 2011 at 12:06. |
Thanks to Relic from:
Car: 2008 2.2 i-CTDi ES
You'll be swearing at the fuel filter before you're done changing it.
It is fairly straightforward, but there is not a lot of room. After removing the battery, tray, and Airbox as described by Relic. Disconnect the fuel pipes and sensor connectors to the filter assembly. Then remove the entire assembly (this is the awkward bit ), it is held by two bolts behind that you can't really see. You can just get your hand in to feel where they are. Once the assembly is removed you can dismantle it and replace the filter. I put the unit in a workmate then used a filter wrench to remove the filter. Don't be surprised if it dumps a load of diesel on you at this point. Assembly/re-fitting is just a reversal, and then pumping the priming pump until firm. Last edited by deaddog; 7th March 2011 at 20:01. Reason: typos |
Thanks given: 1
The air filters and fuel filter came today. I didn't even think about it till I seen someone post about a BMC earlier.
The filters aren't Honda parts, the air filter is a "Blue print" air filter (the same shape and size as normal filter) the fuel filter is a "wix" filter and a workmate who used to be a mechanic for VW said it will be fine. But after reading that there was restrictions when using "sports induction" panels, should I expect and problems using these? |
