![]() Car: 2007 2.2 i-CTDI EX Black
Flush or not to flush ?
Oil and filter change time this morning, do I get them to engine flush or not ?
Car has done 97,000 miles. Thanks |
![]() Car: 2007 TypeS GT2.2 Red
Thanks given: 6
I hear good oil has good cleaning/ anti sludge agents already in it and there's no need?
More expert heads on here will know... |
Cockup Specialist
Thanks given: 737
I always flush with filter and oil.
Just rather not get the oil filthy before its even used. Wether its good for the turbo or not is another matter...but I defo dont want sludge buildup in there. Forte is the only one that garages seem to recommend |
I didnt get it flushed in end, maybe I will do it at the next change, just worried that they dont get all the flush out and it damages the new oil they put in.
![]() Car: 2007 FN2 GT
Thanks given: 159
when i had my derv i always drained the old oil out and filled it with cheapest fully synth i could get and drove it for a few miles, then drained it all out and replaced the filter and put in the good oil
still stood me well at 100+ k ( vag 1.9pd 130 btw) |
![]() Car: 2006 1.8i SE, 5 door, Silver
Thanks given: 3
I always had my last car flushed at every service, Forte is what they used.
Also worked for a company that made engine bearings and slush does build up progessively in the bottom of the sump, whether you change the oil regularly or not and will cause more damage than good. Other causes: higher revs than required when cold wrong grade Cheap oil. |
Similar Threads for: Flush or not to flush ?
| Rear diff flush (grinding steering) | Pottsy | Honda CR-V | 7 | 5th March 2011 21:02 |
| fortron engine flush and fuel treatment | grahammorris | Items for sale | 0 | 6th May 2009 17:52 |
| Servicing Engine Flush and Fuel Additive | high.pressure | Buying, Dealers and Servicing | 9 | 6th May 2009 07:53 |
| Servicing Oil flush after first good drive? | Jeroen1000 | Buying, Dealers and Servicing | 4 | 3rd March 2008 22:31 |
