This thread is about: engine oil, it's in Engines and Transmission at the Honda Civic forum Civinfo; Originally Posted by Woette question three days ago i checked my oil level (1.8 vtec ). I found that the oil mark was just above ...
Old 4th May 2008, 20:20   #41 (permalink)
Originally Posted by Woette View Post
question
three days ago i checked my oil level (1.8 vtec). I found that the oil mark was just above the lower mark on the dipstick. Since that i have driven 75 km but when i parked my car today and shut down the engine, i could here something boiling in the engine bay. So i let the car stand for 45 minutes and checked oil level. Now it was almost against the uppermark and the oil was after 45 minutes still very warm. The oil light has not come on yet but i dont thrust it. Going straigt to the honda guys tomorrow for a refill, they said it needn't some special synthetic honda oil for a good running in period.
Now have i damaged my engine by driving it in pretty hot weather over here, what do you guys think?
grtz
No worry, no worry
As long as you did'nt hit the red at temperature gauge, nothing to worry, especially if oil light has'nt come on, the engine has not had time to suffer !
Now how muche of milage di you have ? What is your oil consumption ? I have 4700 km on clock and have not consummed any oil yet !!
Boiling could come from the water coil (radiater) which could be normal due to some hot period.
philippeclement is offline   Reply With Quote
Old 5th May 2008, 09:16   #42 (permalink)
Anastie's Avatar
I have a 2.2 and about 3000 miles ago when I checked the oil level it was on minimum (16000 miles). I put a litre in and at 19000 miles it needs topping up again!!!
Is this acceptable?
Anastie is offline   Reply With Quote
Old 5th May 2008, 09:27   #43 (permalink)
Woette's Avatar
Originally Posted by philippeclement View Post
No worry, no worry
Mileage is now at 10500 km, i already topped up the oil at 7500, but the car did its first big trip last week (550 km in 2 days) so i am thinking this has something to do with the higher oil consumption cause normally i do small trips in the city (between 5 and 15 km) After buying this car i have become one lazy fok
and it was the first time to hit the 600 km mark on one tank of fuel yeeey, reckon i could have gotten 650 out of it, but towndriving just kills mpg
Old 5th May 2008, 19:10   #44 (permalink)
cb550's Avatar
Is this acceptable?
Is it back to min.again?Seems a little bit thirsty.Does the car get driven hard?-likely to use a little more if it is
Old 5th May 2008, 19:13   #45 (permalink)
Anastie's Avatar
No not that hard and yes its on minimum again . Service due in a few weeks I will mention it. I just do not want to be fobbed off if it is quite normal for this engine.
Old 20th May 2008, 20:01   #46 (permalink)
refgenius15's Avatar
Yeah this is common. Keep an eye on the oil level and DONT rely on low level light!!
refgenius15 is offline   Reply With Quote
Old 23rd May 2008, 20:22   #47 (permalink)
Chris_J's Avatar
Castrol Edge TD or the normal 0/30?
Chris_J is offline   Reply With Quote
Old 23rd May 2008, 20:25   #48 (permalink)
Chris_J's Avatar
I guess as mine is a 57 it will have a dpf and need the TD oil.
Similar Threads for: engine oil
Oil 10w 40 Engine Oil vtidan Engines and Transmission 5 3rd July 2007 08:31
Faults engine hic ups!! civie Engines and Transmission 2 5th March 2007 20:51
Choices How`s the 1.4 engine?? BU5H1D0 Engines and Transmission 37 7th January 2007 09:37
Other anyone for an engine.... Glass Spider Engines and Transmission 9 6th October 2006 13:23
