This thread is about: 10w 40 Engine Oil, it's in Engines and Transmission at the Honda Civic forum Civinfo; My newly purchased ctdi was serviced at Alan days but according to the receipt they filled it with 10w 40 oil. Is it OK to ...
Old 2nd July 2007, 16:42   #1 (permalink)
vtidan's Avatar
10w 40 Engine Oil
My newly purchased ctdi was serviced at Alan days but according to the receipt they filled it with 10w 40 oil. Is it OK to continue using this until the next service or am I likely to encounter problems?
vtidan is offline   Reply With Quote
Old 2nd July 2007, 17:28   #2 (permalink)
greeze's Avatar
I don't know off the top of my head (though I'm sure someone on here does! ) but I'll have a look in the manual when I get home from work. If you have received no info from other members by then, I'll let you know...
greeze is offline   Reply With Quote
Old 2nd July 2007, 17:37   #3 (permalink)
basegreen's Avatar
Hmm.. that's annoying, I specified the RECOMMENDED 0w-30 oil when doing my service, and my top ups have been the same too.
Surely 10w-40 isn't ideal in the Civ?
Old 2nd July 2007, 17:43   #4 (permalink)
best answers so far seem to be in this thread -> Recommended Oil for I-VTEC annd I-CDTI
indicating that it isn't so much the weight on the packaging that matters, as the test results...
so - dunno is my answer!
Old 3rd July 2007, 06:05   #5 (permalink)
greeze's Avatar
Well, according to the manual; 10w/30 and 10w/40 are fine for ambient temps from -20 up to 40+. Hope that helps...
Old 3rd July 2007, 08:31   #6 (permalink)
vtidan's Avatar
cheers.
Similar Threads for: 10w 40 Engine Oil
Faults engine hic ups!! civie Engines and Transmission 2 5th March 2007 20:51
Choices How`s the 1.4 engine?? BU5H1D0 Engines and Transmission 37 7th January 2007 09:37
Other anyone for an engine.... Glass Spider Engines and Transmission 9 6th October 2006 13:23
Choices Which engine do you have WoolyCiv Engines and Transmission 41 1st October 2006 18:29
