| This thread is about: Exhaust trims?, it's in Engines and Transmission at the Honda Civic forum Civinfo; Hi I noticed a couple of new civics yesterday and both had the the triangular exhaust outlets blocked off, am I right to assume that ... | ||
Exhaust trims?
Hi I noticed a couple of new civics yesterday and both had the the triangular exhaust outlets blocked off, am I right to assume that these models were the 1.4DSi and that every other model including the 2.2 diesel have conventional rear facing exhausts?
It got me thinking that Honda did not use particle filters in the exhausts like on the new BMW 335d which prevents the need to point them towards the ground. |
Yeah, the 1.4's don't have the fancy twin triangular exhausts
1.8 and 2.2 have them. I thought Honda did use a particle filter in the 2.2 iCTDI? |
Perfect Guy!
the 1.8's exhausts fit into the triangular exhaust trim
the 2.2's exhausts have the bend in them that all diesel's have and have a small tube attached to them and attached to the triangular exhause trim and the 1.4's can have the triangular exhause trim as an option but Think that is right - someone might correct me tho |
#4 (permalink) | |
Is the exhaust output of the 2.2 all diverted through to triangle, or does some gas escape towards the ground in say a 50:50 split ? If all of the gas does get diverted through the triangle, what function does the bend have other than stopping the exhaust condensate from dripping from the fancy triangle and down the bodywork? |
It wasn’t me!
60:40 on the 2.2 CTDi
The exhaust splits, the smaller pipe through the triangles, the larger pipe bends downwards to direct particulates/smoke under the car |
Well said that man, someone also correctly stated that the triangles are inverted on the S + R models, i.e they are turned the other way round.
Well I've learned something today! I wondered how they managed to keep the chrome clean on the diesel version. Clever little buggers those designers.
#9 (permalink) | |
12th June 2006 1.8EX
CZ you have had me scratching my head with this statement, I have been looking at other owners cars and comparing them, couldnt see anything different until I visisted the Honda website. Now I know what you mean. They are crossed over left to right and right to left |
#10 (permalink) | |
Thanks guys, some interesting points made there and I also didn't know that the S & R models had inverted exhaust tips compated with the rest of the range.
So Honda didn't fit a particle filter in the pipes but simply split the pipes in two? Neat idea! |
#12 (permalink) | |
Ive looked at some and can agree they may be different, but inverted? |
#15 (permalink) | |
Observe... |
| Exhaust Remus Exhaust | Mr Lovedog | Engines and Transmission | 9 | 13th May 2008 09:58 |
| Touching up "Aluminium" trims | Spud | Cleaning | 12 | 15th June 2007 13:36 |
| Painted wheel arch trims | Silver Driver | Wiki Article Discussion | 6 | 12th May 2007 12:01 |
| Exhaust Fake Exhaust Covers | carlborton | Engines and Transmission | 4 | 29th January 2007 11:04 |
| Exhaust Exhaust Garnish! | DanKo | Engines and Transmission | 1 | 1st November 2006 23:45 |
