| This thread is about: Gentle miles, it's in Engines and Transmission at the Honda Civic forum Civinfo; Hallo every one! I like to hear your Professional opinion on first gentle mileage on Civic TypeR 2007. How many miles I must ride gentle, ... | ||
Gentle miles
Hallo every one!
I like to hear your Professional opinion on first gentle mileage on Civic TypeR 2007. How many miles I must ride gentle, without raving the limits, to better prepare engine. I heard that ideal is: First 2000 km (1200 miles) 2000 3000 rpm 2000 3000 km 3000 4000 rpm And so on till 5000 km. |
#2 (permalink) | |
http://www.civinfo.com/wiki/index.php?title=Running_in |
Hi Robles and welcome.
See the Wiki section for "running in". http://www.civinfo.com/wiki/index.php?title=Running_in We don΄t believe in gentle. But it is your engine and your choice. |
Perfect Guy!
Honda engines are run in by Honda prior to delivery
then it is up to the owner how they run in their car although I do agree with most of what is in the wiki section |
I reed, that al cars is necessary to gentle ride on till 3500 miles. It will better prepare engine and bring more real power in future, fuel and oil economy to.
Thanks to everyone for opinion. |
Brodders - have a peek at the Myths section of the running in article. I got this confirmed by an employee working in the engine assembly plant.
#10 (permalink) | |
Perfect Guy!
#12 (permalink) |
I have said it before and I'll say it again.
My stealer reckoned that the motor should be used with some gusto, and that 'running in' was a thing from the past. 'cos of that, after delivery, and after listening to my stealer, I got Millie up to 90mph before we left his car park! "If a kid says where does the rain come from? Tell him that it is probably God crying. If the kid then says why is he crying? You say 'It's probably something you did'!" Charles H. |
Running in.
I bought my 1.8 auto in Dec`06. Before I could amass 4000 miles I had to top up with 4pts of oil to extinguish the oil warning light. "It depends on how you drive it and it does tell you in the book that it will loose some oil during (dare I mention it) running in." said the helpful assistant.
Terry-James. |
#14 (permalink) |
So opinions are different.
From my past experience with 0 mile cars (unfortunately not Hondas) I could say that I always make run in process. As my friend who is top manager in Honda Latvian office sad, that as better you will run in car, the better performance you will have in future usage. For example Rally team Latvia, who driving Hondas Civic Type-R make such preparing of engines. As now I waiting for my Type-R delivery I am lucking for different opinions and experiences. |
#16 (permalink) |
For what it's worth...
I've had several Hondas over the years - all with less than 3 wheels up until now and I prefer to disagree with the Wiki advice in this forum.
It seems to me that most people only consider the engine when thinking about running in a new car. What about all the other components (gearbox, axles, suspension, brakes, etc.)? I won't bore you with the physics and metallurgy (guess what my degree was in Each to their own, I say, but I certainly always bed in the brake pads for a 100 miles or so. I look upon running in as an extension of the same process. |
#17 (permalink) |
running in the engine is not necessary as long as you don't floor it when it's cold...what brakes is concerned it is true that you don't want to do heavy braking the first couple of miles because they should weare down equally...
#18 (permalink) |
Have to agree - no ragging the nuts off it whilst cold, but after about 10 mins of driving once the oil temp and pressure are up to where they should be, then knock seven shades of ***** out of the rev counter and gear lever.
John, as a biker, I'm sure you're familiar with the bike oriented site that promotes the hard run-in procedure rather than the softly softly approach. The sooner you slough off those peaks on the rings and wall, the sooner your seal will be created, reducing the blow-by when cold, which is when most of the acid compounds are formed, and reducing the life of the oil. |
#19 (permalink) | |
#20 (permalink) |
I don't know what other boards you frequent, but I can't recall any flaming wars on here.....yet. That said, and back to the topic of debate, I'd be interested to hear "your side" of the argument, using your University provided knowledge base. In reply to "just because it's published on the internet, doesn't mean it's right", I'll counter with......not everyone providing information on the internet doesn't know what they're talking about or makes it up. So unless there's a requirement to list our educational achievements (and professional ones too) before taking their word, we have to work on the basis they're being genuine and have gained their knowledge through various means - personal experience, reading technical material, talked to individuals who work in the field, etc. Yes, there are some (a lot?) of urban myths that are repeated - probably started off mostly right, but like a game of chinese whispers, after being repeated numerous times, bits changed or were misinterpreted through poor explanation or badly phrased grammatical structure. As of yet, I've not seen one mention of the site I linked above being discussed in such a way as to indicate someone followed the advice given therein, and ended up destroying their engine. Like I said, please share the knowledge you've got that shows why the progressive approach is the best method. |
| Collection Delivery Miles | cnicolini | Buying, Dealers and Servicing | 27 | 18th October 2007 16:45 |
| Performance Engine noise at 500 miles | Tommo895 | Engines and Transmission | 8 | 10th October 2007 15:07 |
| MPG 30 mpg 500 Miles - whats wrong? | psykik | Engines and Transmission | 8 | 5th October 2007 16:38 |
| MPG 65 mph for 100 miles gives... | Pottsy | Engines and Transmission | 93 | 29th June 2007 23:59 |
| Yaris 28k Miles, 52 reg | Griffyn | For sale and Wanted | 7 | 12th April 2007 22:52 |
