Old 31st March 2012, 17:38   #1 (permalink)
FrankstaH's Avatar
Car: 58 Plate Milano CTR GT
Thanks given: 33
Checking my oil!
Hello everyone,
I'm sure this has been covered before, however i am always very paranoid about my oil. I always keep it topped up.
Now i know to check the oil when your car is on a flat surface and the oil is partially warm etc.
But when you unscrew the oil check bit, clean the metal and then dip it back in... DO YOU
A) Plug it right back in, so that the metal is at the point it would be if you were to close the bonnet (you have to twist / screw it back in)
B) Just push it down as far as it can go, without twisting it to click back into the stopped position
The reason i ask this is...
When i do A i am right on the Maximum for oil, and when i do B i am just above the minimum.
So i'd like to always keep it topped up just below the maximum
Cheers guys
FrankstaH is offline   Reply With Quote
Old 31st March 2012, 17:46   #2 (permalink)
Muscles From Brussels
RobertUtley's Avatar
Car: 2007 1.8 CTS Nighthawk
Thanks given: 168
Originally Posted by FrankstaH View Post
Hello everyone,
Cheers guys
Option A always goes down to where it permanently sits
RobertUtley is offline   Reply With Quote
Old 31st March 2012, 17:55   #3 (permalink)
FrankstaH's Avatar
Thanks given: 33
What happens if i put a bit too much oil in?
Old 31st March 2012, 17:57   #4 (permalink)
Thanks given: 168
Depends how much from min to max is 1litre i believe so you can guage size of overfill from that but it puts pressure on seals etc its not a good idea to overfill (i know it wasnt on purpose) if its a fair amount id suck it out with something.
Old 31st March 2012, 18:01   #5 (permalink)
misterk's Avatar
Car: 2007 CTR GT NHB
Thanks given: 204
Depends how much you call a bit, just over maximum will be fine but any more and you can do just as much damage to the engine as you would if you ran it with not enough oil
misterk is offline   Reply With Quote
Old 31st March 2012, 18:02   #6 (permalink)
FireBIade's Avatar
Car: M200, er.....CW
Thanks given: 9
A little bit too much oil is better than a little bit to little, but, dont put loads over the top dot!
FireBIade is offline   Reply With Quote
Similar Threads for: Checking my oil!
Checking oil Ash101 Type-R 26 10th August 2012 15:38
WAR Machine Checking In... WAR Machine Introduce yourself 11 29th April 2011 22:48
Oil unsure about checking my oil regan1985 Engines and Transmission 6 4th October 2010 10:28
Dealers HPI Checking Jaspabt Buying, Dealers and Servicing 5 18th August 2010 22:35
Oil Checking the Oil CatherineJ Engines and Transmission 13 25th January 2009 16:15
