Old 11th May 2012, 10:58   #1 (permalink)
Car: 2009 CW Type R
Thanks given: 3
Hondata Reflash
Is this available for Uk spec cars yet? i cant find any more info on it?
miller4648 is offline   Reply With Quote
Old 11th May 2012, 10:59   #2 (permalink)
C.B
UKDM
C.B's Avatar
Car: 2007 CTR NHB GT
Thanks given: 25
dont believe so and no date when it will be
C.B is offline   Reply With Quote
Old 11th May 2012, 11:01   #3 (permalink)
Car: 2009 CW Type R
Thanks given: 3
what is the difference? y wouldnt it work on the uk spec?
Old 11th May 2012, 11:03   #4 (permalink)
C.B
UKDM
C.B's Avatar
Thanks given: 25
You wouldnt need the flashpro, just turn up to a tuner have it mapped and drive away
Old 11th May 2012, 11:05   #5 (permalink)
Car: 2009 CW Type R
Thanks given: 3
so its just a straight swap from your own ecu? is there a map already loaded on to it?
Old 11th May 2012, 12:09   #6 (permalink)
C.B
UKDM
C.B's Avatar
Thanks given: 25
Not sure which of us is more confused here now
Flashpro - Handheld device that plugs into the car and allows the map to be changed in the ECU, it does come with a default map called the Group N you can upload as soon as you receive which is basically a slightly more aggressive standard map with a lower VTEC crossover. In order to get a custom or Etune you will need a flashpro.
Hondata Reflash - Turn up to a tuners, they map the car and save the map in the ECU and you drive away running that map, no flashpro required but the tuner will have used a hondata licence to unlock the ECU and allow the tuning. This is the way most other cars are tuned but we are at the mercy of hondata and this is not currently available in the EU
Hondata ECU - There is also a plug and play ECU called the Hondata Group N ECU which replaces the standard ECU and contains the Group N map. The map on the ECU can not be changed. They were a stop gap before flash pro was released really.
I think thats pretty accurate but I'm sure a more knowledgeable member will correct if not
Similar Threads for: Hondata Reflash
HONDATA Reflash ECU BRM Items for sale 31 24th January 2012 14:18
Hondata reflash for FN2/FD2 tdi-north TDi North 7 9th November 2010 20:30
Hondata reflash giulz Items wanted 0 6th February 2010 17:55
Hondata ECU Reflash FN2 Dawid S Items for sale 17 2nd July 2009 23:24
hondata reflash ecu chan267 FlashPro 1 5th December 2008 16:21
