Old 17th May 2012, 13:33   #1 (permalink)
Thanks given: 2
Noise from air filter?
Hi everyone,
Need a little help if possible.
Father-in-law did the service on my 2007 Civic EX 2.2 diesel yesterday, obviously changed oil, filter, air filter and cabin filter. Strangely though since then there is a noise when revving the engine.
It sounds like the exhaust blowing but from under the bonnet. I have noticed that the housing that encases the air filter does have some play on it, which i presume is normal. Not so sure whether it is an air noise or a vibration.
Just wondered if anyone has experienced anything like this. All the hoses seem fine so really baffling me.
Any help really appreciated.
Thanks,
Rich
icclebug is offline   Reply With Quote
Old 17th May 2012, 13:36   #2 (permalink)
Syx
Clingfilmed
Syx's Avatar
Car: 2008 2.2 CTS GT
Thanks given: 927
What was the replacement air filter used? OEM or aftermarket?
Get someone to rev the engine whilst using a cardboard tube against your ear to pinpoint the source of the noise.
Syx is online now   Reply With Quote
Old 17th May 2012, 13:38   #3 (permalink)
Thanks given: 2
Think it was aftermarket filter, will try what you said though.
Many thanks,
Richard
Old 17th May 2012, 13:39   #4 (permalink)
Thanks given: 2
Just asked and we did actually put the old filter back in and still did the noise
Old 17th May 2012, 13:39   #5 (permalink)
Most Active Australian
Grayfox's Avatar
Car: 2010 Black Civic Si FK2
Thanks given: 69
Eco display Eco display
K&N or some cheap one?
Grayfox is offline   Reply With Quote
Old 17th May 2012, 13:39   #6 (permalink)
Thanks given: 2
No not K&N, just standard filter
Old 17th May 2012, 13:41   #7 (permalink)
Grayfox's Avatar
Thanks given: 69
check to see if it is fully seated.
Old 17th May 2012, 13:44   #8 (permalink)
Thanks given: 2
do you mean the housing unit or the filter itself?
As the filter seems to be pretty secure when you clip the housing
Old 17th May 2012, 17:13   #9 (permalink)
delta0's Avatar
Car: 2006 1.8 Sport Ishift Milano
Thanks given: 134
The cover on the air filter should be opened and reseated. Also check the tubing joining immediately onto the air box for any loose joints. I don't remember the airbox being loose when i put a k&n in a few weeks ago. An OEM filter shouldn't change the noise.
delta0 is online now   Reply With Quote
Old 17th May 2012, 20:10   #10 (permalink)
Thanks given: 2
Thanks for the replies.
The filter housing was in clipped, old free slid out, new one slid in and them clipped to close. That's the reason I don't understand this, nothing else was touched.
Old 21st May 2012, 12:34   #11 (permalink)
It's definitely the filter. I had the same problem. Like you I thought it sounded as though the exhaust was blowing. However you can feel the lid of the airbox vibrate at certain revs. I replaced with an OEM one and the problem went away. The OEM one had a slightly thicker rubber gasket than the Unipart one I replaced, and was slightly more difficult to close the clips around it. It possible that disturbing the lid of the airbox when you took the old filter out means that even if you put the old one in, because it's previously been compressed, it won't reseal.
To summarise; get a dealer airfilter.
tjg04 is offline   Reply With Quote
Similar Threads for: Noise from air filter?
Remap Rolling Road Plot Results - Remapped 2.2 with OEM filter & Pipercross Filter damianscott71 Engines and Transmission 26 22nd April 2012 01:16
Induction Air filter noise! ajiboy Engines and Transmission 9 26th May 2010 21:58
Panel Filter or Open K&N Filter MiChA Type-R 9 17th March 2010 20:58
Engine Noise at low RPM laluks Bugs, faults and irritations 8 26th June 2008 06:14
AC/Heater Air Con noise rogie Bugs, faults and irritations 6 23rd April 2007 20:16
