Car: Civic 2.2cdti ex
Hello to all.
My honda civic needs a clutch replacement i was wondering does anyone know of a good local independant garage to do the work as i dont want to go to the stealers to give them the pleasure of robbing me,anyway im in newcastle upon tyne , any help would be greatfull. Thank you guys and ladies :: |
![]() Car: 09 Suzuki Swift Sport white
Thanks given: 1,122
Hyperformance in sunderland are reasonable mate but tbh the dealer price isnt bad its a good 6hr job
Sent from my GT-N7000 using Tapatalk 2 |
![]() Car: 2008 2.2 Type S GT Red
Thanks given: 21
Honda dealers now have a fixed price for replacing the clutch just over £600 pounds for the CDTI this does not include the DMF
Thank you guys that is really great help ill check with hyperormance in sunderland . Thank you once again
![]() Car: 08 2.2 nhb type s gt
Thanks given: 135
im just after selling my passat and am going buying a cdti ex or type s gt.my question is in the passat when my flywheel started knocking(common fault on these usally bout 50-60,000 miles) your best of replacing clutch aswel when replacing flywheel,as they reckon the clutch will at sum stage start to slip and it will cost the exact same all over labour wise(never had a clutch slip on me yet)touching wood.Is this the opposite story with the honda, your aswell replace the flywheel when the clutch starts slipping??
Similar Threads for: Clutch replacement
| 2.2 after clutch replacement | Gregry254 | General Discussion | 14 | 14th June 2012 13:00 |
| Clutch Second Replacement Clutch? | bluefish1 | Engines and Transmission | 11 | 21st August 2011 11:49 |
| Clutch Clutch Replacement | SicklyPilot | Engines and Transmission | 4 | 8th July 2010 09:14 |
| Clutch Replacement clutch | Pete52 | Engines and Transmission | 9 | 16th January 2009 11:52 |
| Clutch Replacement clutch | curlyearly | Engines and Transmission | 10 | 20th November 2008 15:25 |
