This thread is about: Logging the OBD2 data, it's in Engines and Transmission at the Honda Civic forum Civinfo; Will this work on the Civic? Carchip OBD 2 serial data logger , perfomance monitor. on eBay, Performance Tuning Parts, Car Tuning Styling, Cars, Parts ...
Old 7th September 2007, 17:31   #1 (permalink)
Big Civic fan
stu_iow's Avatar
Carchip OBD 2 serial data logger , perfomance monitor. on eBay, Performance Tuning Parts, Car Tuning Styling, Cars, Parts Vehicles (item 280150722203 end time 16-Sep-07 21:32:38 BST)
Stuart
stu_iow is offline   Reply With Quote
Old 7th September 2007, 18:26   #2 (permalink)
depends what you mean by 'work' I guess
Is there a good chance it will be able to monitor those outputs from the ECU?
Yes, there probably is, as they are (I'm pretty sure) the group that make up the standard set which all ODBC ECUs tend to log.
Bear in mind though that there are an extra (lot!) of things the ECU checks out which may be a lot more informative, but that this device and s/w won't know anything about.
Will you be able to use it with your laptop?
Probably not, unless you have an old one with a serial port, or a serial to USB adaptor which then may (or may not) be happy with this device.
Will you be able to mod the ECU with this?
no, I doubt it very much.
Personally I would have no use for this, but given the limited use it may have, it might be what you are after.
Similar Threads for: Logging the OBD2 data
Satnav Data recency on new EX Media_Chil Electronics 3 30th August 2007 17:57
Computer obd2 interface??????? nstergi Electronics 21 9th October 2006 17:25
