![]() Car: 2006 2.2 5 door galaxy grey
Thanks given: 85
Hi all,
Just changed my air filter on my 2.2 and noticed a split of abt 4cm in one of the coregated folds in the air flow tube. Is this detremental in any way? Looks complicated to replace as 2 pipes (I think water pipes to feed heater matrix?) are in the way so from what I can make out they will have to be removed to gain access to the engine side of the air flow tube! I am thinking perhaps seal with a bead of silicone automotive sealant? Has anyone changed there air flow tube?, any hints or tips? Many thanks in advance John |
![]() Car: 2007 FN2 GT
Thanks given: 159
Replace the tube. The silicon could be ingested and cause serious engine damage . As an interim fix maybe a few loops of duct tape.
Yes it is important it is fixed as the car is taking in unmetered air which affects the air fuel calculation |
Thanks to stoney from:
Thanks given: 85
Thank you for your response.
Now for the next question, shall I replace it myself or shall I take it to a Honda dealer to replace? Has anyone replaced this part themselves? |
Cockup Specialist
Thanks given: 737
The clamp is normally unscrewed from over the top of the engine with a very long screwdriver.
Neve got round to changing mine....but had a good luck. |
Thanks to Relic from:
Thanks given: 85
Hi Relic,
Thank you for your answer. From what I can see from listers its about £37.00 for the air flow pipe. I never thought of that, will have to have a look. I take it the O ring has a special design to allow loosening from the top rather than the side? For £37 odd quid, its worth checking and changing if ned be as mine has perished from the side facing me so obvious but others may perish on a side that isnt directly visible! Just out of curiousity how would it be detremental in terms of impact on driving? |
Cockup Specialist
Thanks given: 737
Honda Car Parts / Choose by Model / Genuine Honda Parts | Honda Cars | Honda Motorcycles | Honda Power Products | Lings Honda
Item 7 Its just a worm drive clip (items 11 and 12). Its the same mechanism as the end that connects to the airbox. You can use socket or small head phillips screwdriver. |
Similar Threads for: Air Flow Tube
| Found on U Tube | jaygee58 | Any non Civic chat here please! | 2 | 15th March 2010 18:24 |
| This You Tube just gets better! | Charles_Harding | Any non Civic chat here please! | 10 | 8th January 2008 12:38 |
| you tube | Cookie | Type-R | 6 | 10th September 2007 16:36 |
| 5th Gear you tube link | vikingskelhorn | Type-R | 1 | 9th May 2007 09:36 |
| Air Flow | Charles_Harding | General Discussion | 6 | 26th January 2007 17:00 |
