Car: 2007 2.2 5dr es. elec blue
p2004, fault code, error code. help!
Hi guys...
I've got a 07 reg diesel car with 60k on the clock... Over the last few weeks ive been getting this error code pop up on my car. Only happens occasionally but while im going at a steady speed if i try to speed up by a small amount i'll get a small hesitation. The check engine light comes on and after a day it goes off again..... Any ideas what i need to replace? The odbii data info says "P2004 = INTAKE MANIFOLD RUNNER CONTROL STUCK OPEN" hummmm... Also ive done a search and some guy changed a "faulty IMRC solenoid"... whats that?... Help please... Thanks in advance Jav |
#2 (permalink) | |
![]() Car: 59 Type-S, Silver
Thanks given: 7
I'd try and find a replacement solenoid. Honda is possibly the best bet for that Good luck |
![]() Car: 2012 F10 BMW 520D
Thanks given: 78
All the answers are in here, very common problem. You may need to register to see the pics, very easy part to replace and you might even get away with just replacing the little black filter
Slight Missing or Hesitation, Excessive Smoking etc - TypeAccord |
Thanks for the replies guys...
So i need to change the filter and/or the solenoid .... or .......... I can get a remap with EGR off...... hummm Fahad.... how much do you charge for these remaps... what power should i expect... can i do it via the cable myself?... Thanks Jav |
Thanks given: 78
Drop me a line to discuss, before tuning I would check the IMRC with a functional test. It can sometimes be successfully closed as part of an EGR OFF, but we won't know until we try as it really depends on the condition of the part. File Only not recommended in this scenario.
Similar Threads for: p2004, fault code, error code. help!
| Faults Error code P1326 | thebandit | Engines and Transmission | 11 | 4th June 2012 10:30 |
| Warnings Fault code P2004 Help and buzzing noise | equanimity | Electronics | 8 | 14th September 2011 14:51 |
| Help with an error code needed. | webstar555 | FlashPro | 7 | 6th June 2011 09:10 |
| Other Error Code thing | Dan33-uk | Bugs, faults and irritations | 1 | 14th May 2011 11:16 |
| fuelinjection error code | blom_ | Type-R | 6 | 23rd December 2010 09:42 |
