![]() Car: 2007 CTR,Black
Thanks given: 60
Whirring/rattling noise
Just been for a blast in the beast for a burn round the country lanes and thought she sounded a bit whinney?Getting paranoid i think,so i parked up and opened the bonnet to listen and i hear a rattling(slight)from the aux belt on the left of the engine bay???but after a bit it stops?????rev it up and it does it again(rattles)and then after a bit it settles???is this normal or am i getting paranoid about the beast???any feed back would great!
![]() Join Date: 4th October 2009
Thanks given: 5
theres a thread on here with regards to the rattle, search for aux belt or PCV valve on this forum, my CTR whines alot too, not sure if its normal
Thanks to Jason85 from:
![]() Car: 2009 milino red CTR GT+
Thanks given: 121
+1 its defo PCV well the rattle is anyway had the same thing so went to honda and they statred up 3 other type R's that were there and they did the same thing. I was told you can change it for around £25 but will make no difference.
Mine also whines i have had a new top pulley put on and new belt( pullley bearing very noisey) and the whine was there before and after the new parts put on. Hope this is of some use. Last edited by tonymac; 14th August 2012 at 21:33. |
Thanks to tonymac from:
Thanks given: 60
Cheers for the input guys,awesome as usual!tried a bit of wd40 on it but still the same.So it seems its a CTR thing.Gonna check to see if my mates also has the same noise 2moz?Thats cool,can live with that.Will probably still take it down to Honda because it will drive me nuts!!
#7 (permalink) | |
![]() Car: FN2 CTR GT
Thanks given: 17
Thanks to Forbidden8701 from:
#8 (permalink) | |
Thanks given: 121
I have worked on cars most my life and I still go back to the dealer as they are the ones that hold your warrenty etc and 9out of 10 there correct in what there saying. Also pinching the pipe will stop the noise as you stopping the vapours from escaping the crank there for creating pressure in there so don't pinch to long |
Thanks given: 5
SO what do you think about this PCV issue? is it worth fixing?
with regards to this, I have taken it to my dealers and they couldnt diagnose the problem, they came back saying a whining noise was due to my car being low on oil. they had a look at all bearings and couldnt figure out the scraping noise, so as you can imagine, forums hold the knowledge here :/ |
Thanks given: 5
howcome sometimes the noise disappears?
whats causing this? also what could be causing a whine when revving - its very distinct, not like engine whine it seems to be slightly delayed |
Similar Threads for: Whirring/rattling noise
| Road Noise Whirring noise when accelerating?? | mark_VII_jenkins | Bugs, faults and irritations | 22 | 25th June 2012 17:44 |
| Electrics whirring noise behind glovebox | Alzy | Bugs, faults and irritations | 7 | 18th May 2012 19:24 |
| Trim Rattling Noise | acidrider | Bugs, faults and irritations | 10 | 10th October 2011 21:32 |
| rattling noise from rear or car??????????? | freddiecider | Honda CR-V | 4 | 25th August 2011 21:43 |
| Faults rattling noise | tamzin | Engines and Transmission | 2 | 3rd April 2009 14:58 |
