Old 15th August 2012, 21:54   #1 (permalink)
Thanks given: 1
Question 2.2 Diesel Rebore / Stroke ?
Hi Guys
Just a quick thought...
on a 2.2 Diesel what are the options re-bore/stroke wise ?
are there any aftermarket kits or would it need to be custom ?
Is it even possible? and is there worthwhile gains to be had?
Let the Begin
HCCTDI is offline   Reply With Quote
Old 15th August 2012, 23:18   #2 (permalink)
Angry cat says NO
JohnnyBoy's Avatar
Thanks given: 783
JohnnyBoy is offline   Reply With Quote
Old 16th August 2012, 00:38   #3 (permalink)
coste1l's Avatar
Thanks given: 1,122
Clutch/dmf cant take the torque anyway so the 2.2 limit will never be found until a workable permanent solution is found
Sent from my GT-N7000 using Tapatalk 2
coste1l is offline   Reply With Quote
Old 16th August 2012, 09:37   #4 (permalink)
elegance's Avatar
Car: 2012 2.2 i-dtec EX GT
Thanks given: 19
Originally Posted by HCCTDI View Post
Hi Guys
Let the Begin
Going that route, you would need to upgrade all the internals.
Don't see the point when you can easily get 200 bhp and 330 lb ft torque
just from a remap.
If you want more than that, buy a different car (Evo, Scooby, etc)
Steve
elegance is offline   Reply With Quote
Old 16th August 2012, 09:56   #5 (permalink)
Syx
Clingfilmed
Syx's Avatar
Car: 2008 2.2 CTS GT
Thanks given: 853
As others have indicated - absolutely no point in doing this at all.
Old 16th August 2012, 10:43   #6 (permalink)
coste1l's Avatar
Thanks given: 1,122
in theory there is value in it but no-one has even explored all the bolt on options, i think that smf with the acura twin plate clutch should resolve the clutch issues
Old 16th August 2012, 10:48   #7 (permalink)
Syx
Clingfilmed
Syx's Avatar
Thanks given: 853
Can the box take it with a SMF though? I'm waiting for someone to test this out
Personally I don't think that a rebore is worth the cost when there's other options (e.g. hybrid) to explore first.
Old 16th August 2012, 11:08   #8 (permalink)
coste1l's Avatar
Thanks given: 1,122
who knows? in theory the box should be stronger than a type r one and tdi north should know how far that box can go?
Old 16th August 2012, 14:27   #9 (permalink)
LincsPoacher's Avatar
Car: 2009 2.2 EX GT Milano Red
Thanks given: 47
LincsPoacher is offline   Reply With Quote
Old 16th August 2012, 15:57   #10 (permalink)
pulpmelon_r's Avatar
Thanks given: 22
Why take a perfectly good eco focused engine in a family hatchback and spend tens of thousands to make it into a performance engine?
Does not compute...
pulpmelon_r is offline   Reply With Quote
Old 16th August 2012, 16:07   #11 (permalink)
stevencavanagh's Avatar
Car: 58 2.2, Black ; 09 CTR, Red
Thanks given: 3
Does not compute...
Agreed it doesn't compute, but please tell me it isn't an eco focused engine as I'd have to sell!
I try very hard not be buy eco based rubbish!
Sent from my BlackBerry 9900 using Tapatalk
stevencavanagh is offline   Reply With Quote
Old 16th August 2012, 16:57   #12 (permalink)
coste1l's Avatar
Thanks given: 1,122
Does not compute...
The sense of satisfaction that comes from built not bought? 70's fords with v8's and nitrous springs right to mind
Old 16th August 2012, 17:01   #13 (permalink)
stoney's Avatar
Car: 2007 FN2 GT
Thanks given: 160
***** n giggles , best excuse ever for trying new ideas
stoney is offline   Reply With Quote
Old 16th August 2012, 17:23   #14 (permalink)
Deathstar's Avatar
Car: 12 2.2 CR-V EX (The wifes)
Thanks given: 36
Give the guy a break, it's only like spending tens of thousands on a 1.5 cr-z.
If TDI mentioned it, you would all be creaming yourselves!
Sent from my phone!
Deathstar is offline   Reply With Quote
Old 16th August 2012, 17:34   #15 (permalink)
Thanks given: 22
Those 1970's diesel v8 fords with their 60MPG and low carbon emisions, those were the days...
Old 16th August 2012, 18:39   #16 (permalink)
Thanks given: 1
Thanks for the opinions everyone =)
Maybe I should have explained my intentions better and It is true that the clutch is a known week spot and a solution does need to be found also it would be cheaper to change the car to a petrol as pointed out,
The reason I bring the subject up is because surly the mpg regardless would be better on the diesel engine ,there is more torque at the moment than we can handle with remaps but I would like to focus on low down grunt at low rpm's and around improvement with the same reliability with faster and lower in the rpm turbo spool. one of the best ways to do this would be to increase capacity or have I got it wrong ?
In reply to elegence what other components would you suggest need to be included and why ?
In reply to Syx the hybrid idea I hadn't even thought off, Good idea that would also aid my goal but that's another option and another discussion. If there is an existing thread if so I would really appreciate a link to it
In reply to Stevencavanagh & Pulpmelon I believe the engine is eco focused but in this day and age this is also becoming an important factor in performance cars.
this video on the 2.2 i-CTDi engine may interest you and other members
That particular video also makes me want to take into account the modifications honda have made to improve efficiency and I also believe 1min in it demonstrates a need for the piston shape to be the same to maintain this efficiency, can anyone confirm this ?
Also Does anyone know how much play we have with bore / stroke ?
I understand the expense but other people clearly are interested also so I believe its worth discussing.
Old 16th August 2012, 19:02   #17 (permalink)
Derv Driver
Car: 2008 Civic 2.2 VXi 5Dr
Thanks given: 34
Well, if that video is anything to go by, you have exactly zero play regarding the bore- it's already down to 3mm between cylinders. I dunno, but that's a bit hard to swallow. Not saying it isn't, but damn... So any increase in capacity will have to be in the form of 'n stroker crank.
SykomantiS is online now   Reply With Quote
Old 16th August 2012, 23:36   #18 (permalink)
Cockup Specialist
Relic's Avatar
Thanks given: 740
Low and mid Torque/power isnt the issue
You can have 370lb ft by 2800rpm if you want.
The drivetrain wont take it.. well the clutch/flywheel at least.
therefore...cc = fail
Where it does lack is top end power.
Mainly down to the exhaust ports being so goddam small and choking the engine.
Space and decent piping would be more beneficial along with a modified turbo.
You can pump upto 83mg/str fuel (100mm3) at high rpm which allows for 231hp @ 4000rpm
If the airflow is there that is.
Fuel system will need recalibration if you want to load the pump more.
Old 17th August 2012, 00:11   #19 (permalink)
stoney's Avatar
Car: 2007 FN2 GT
Thanks given: 160
Surely if you stroke the motor your rod speed will increase so you will have to limit the revs??
Narrowing the power band even more -not what you want on an already low revving engine
Old 17th August 2012, 08:46   #20 (permalink)
Cockup Specialist
Relic's Avatar
Thanks given: 740
I dont think that is so much of a limiting factor with this engine.
I believe the main issue is ignition delay and how long it takes to inject all the required fuel and burn it.
Diesels simply run out of time to do this at high revs.
Similar Threads for: 2.2 Diesel Rebore / Stroke ?
Fuel 2 Stroke mixed with Diesel greasemonkey Engines and Transmission 80 2nd July 2011 16:32
Performance Adding 2 stroke to diesel Trevor7979 Engines and Transmission 16 31st January 2011 12:44
Fuel 2 stroke oil Big Sas Engines and Transmission 2 30th January 2011 18:14
Honda World Honda Releases BF115 4-Stroke Outboard Engine Honda News Feed Honda News 0 3rd June 2010 04:10
Save a Stroke Victim - Serious! Charles_Harding Any non Civic chat here please! 0 19th February 2008 21:31
