Old 7th September 2012, 23:48   #21 (permalink)
Cockup Specialist
Relic's Avatar
Thanks given: 738
Swap what exhaust from what to what ?
Old 8th September 2012, 19:07   #22 (permalink)
Geek :)
jonnyansell's Avatar
Car: 2008 2.2 EX 5 DOOR
Thanks given: 31
From a oem 2.2 exhaust to a oem ctr exhaust??
jonnyansell is offline   Reply With Quote
Old 8th September 2012, 23:35   #23 (permalink)
Cockup Specialist
Relic's Avatar
Thanks given: 738
straight swap...unbolt one and bolt on the other.
Blow torch might be good or some wd40 beforehand.
OEM 2.2 exhaust has a larger bore then a OEM FN2 exhaust ....no point
Old 9th September 2012, 01:58   #24 (permalink)
HID FANATIC@#$!
jeremiah's Avatar
Car: 2007 NHB Civic 5D 2.2 i-CDTi
Thanks given: 385
Originally Posted by jonnyansell View Post
There's no smell in the car unless I start it and have the window open or I start it and reverse back into the fumes. Would a dealer check FOC or not??
Couldn't it just be the car regenerating??? Or don't you have DPF?
jeremiah is offline   Reply With Quote
Old 9th September 2012, 18:12   #25 (permalink)
Geek :)
Thanks given: 31
Ermmmmm not to sound too stupid here but the first bit makes complete sense the last bit went over my head at a similar altitude to a 747??
An I don't believe it does have a dpf.
Old 9th September 2012, 20:33   #26 (permalink)
Cockup Specialist
Relic's Avatar
Thanks given: 738
Why would you put an exhaust with a smaller diameter than what you have onto your car ?
Thanks to Relic from:
Old 9th September 2012, 20:46   #27 (permalink)
Geek :)
Thanks given: 31
What difference does it make??
Sorry if these seem like daft questions.
Old 9th September 2012, 21:48   #28 (permalink)
Goat Fancier
Jon_G's Avatar
Car: 2005 Accord iCTDi Tourer
Thanks given: 59
It would give a poorer flow of exhaust gases, which would degrade performance.
It would be better not to do this (unless you have a good reason that I've somehow missed!).
Jon_G is offline   Reply With Quote
Thanks to Jon_G from:
Old 9th September 2012, 22:19   #29 (permalink)
Geek :)
Thanks given: 31
No, no good reason. I just didn't know there would to a degradation in performance. Now I do though.
Although it's not a the full exhaust it's just the back box and tailpipes I was going to add. I'm not sure if this makes a difference or not?
Last edited by jonnyansell; 10th September 2012 at 09:31. Reason: Thought of Something Else.
Old 12th September 2012, 10:50   #30 (permalink)
Geek :)
Thanks given: 31
*bump*
Old 12th September 2012, 11:05   #31 (permalink)
Goat Fancier
Jon_G's Avatar
Thanks given: 59
If it's smaller, then it'll make a difference. And, if it is smaller, then it'll take a bit of adaptation to fit.
Similar Threads for: Horrible Burning Smell & Rattle
How to remove horrible smell from screenwash?? danlat1415 Cleaning 14 3rd January 2011 23:01
Burning Smell after Vtec Jason85 Type-R 35 12th November 2010 08:47
Other Burning smell on start up? Robbieee Bugs, faults and irritations 13 15th February 2009 18:01
Bad burning smell reb Type-R 16 29th December 2008 20:47
Oil Burning oil smell question... uncler Engines and Transmission 6 5th January 2008 15:15
