Old 22nd October 2012, 19:41   #141 (permalink)
coste1l's Avatar
Thanks given: 1,186
Yup the clutch would be sprung instead
Sent from my GT-N7000 using Tapatalk 2
coste1l is offline   Reply With Quote
Old 29th October 2012, 17:57   #142 (permalink)
WAG 45's Avatar
Well, I have just ordered the 8 paddle clutch kit and flywheel. I had the standard clutch replaced by Honda at 17000 miles,the car has now done 42000 and that one is stuffed also.I have had a good chat with Linda at CG and I am having it fitted by them on November 12th... Watch this space!!
WAG 45 is offline   Reply With Quote
Old 29th October 2012, 18:34   #143 (permalink)
Cockup Specialist
Relic's Avatar
Thanks given: 762
Will do with interest.. tah
Relic is online now   Reply With Quote
Old 29th October 2012, 18:39   #144 (permalink)
stevencavanagh's Avatar
Car: 58 2.2, Black ; 09 CTR, Red
Thanks given: 3
Sent from my BlackBerry 9900 using Tapatalk
stevencavanagh is offline   Reply With Quote
Old 29th October 2012, 20:08   #145 (permalink)
Goat Fancier
Jon_G's Avatar
Car: 2005 Accord iCTDi Tourer
Thanks given: 65
ditto
Jon_G is offline   Reply With Quote
Old 29th October 2012, 20:53   #146 (permalink)
LincsPoacher's Avatar
Car: 2009 2.2 EX GT Milano Red
Thanks given: 48
me too
LincsPoacher is offline   Reply With Quote
Old 30th October 2012, 00:18   #147 (permalink)
sawrel's Avatar
Car: NHB 2.2i-CDTI
Thanks given: 2
sawrel is offline   Reply With Quote
Old 30th October 2012, 01:31   #148 (permalink)
mark2390's Avatar
Car: 2007 2.2 type s gt
Thanks given: 80
I'm having an 8 paddle fitted next Monday the 5th, then another remap after with the extra torque hopefully it will be ok, at the mo I had it limited to 300 to make the standard clutch last a bit!
mark2390 is offline   Reply With Quote
Old 30th October 2012, 11:26   #149 (permalink)
Andy@CG-Motorsport's Avatar
Thanks given: 23
So no pressure then....
Andy@CG-Motorsport is offline   Reply With Quote
Old 31st October 2012, 01:52   #150 (permalink)
Alzy's Avatar
Car: 2009 2.2 type s gt
Thanks given: 4
Lol
Andy if the 8 paddle is smooth and can handle the torque you guys are going to sell a shed load
Alzy is offline   Reply With Quote
Old 31st October 2012, 11:47   #151 (permalink)
hondacivicnut's Avatar
Thanks given: 32
I'd like to see an in car video of the 8 paddle vs the 6 paddle vs the original honda clutch when setting off. I'm sure you guys could do it
hondacivicnut is offline   Reply With Quote
Old 31st October 2012, 11:52   #152 (permalink)
lucian18's Avatar
Thanks given: 30
Hi,are you having the new smf or sticking with oem dmf?
lucian18 is offline   Reply With Quote
Old 31st October 2012, 11:55   #153 (permalink)
coste1l's Avatar
Thanks given: 1,186
You wouldnt see it on video imo the judder isnt bad enough that the whole car shakes
Old 31st October 2012, 15:10   #154 (permalink)
So do we reckon that these competition clutches and the flywheel are now good for 100000+ miles, or is there no gaurantee that premature failure will start to occur 20-30k down the road? All seems likes early days to me.
Just about to pull the trigger on a 2010 cdti and now I'm not so sure.
Sean282 is offline   Reply With Quote
Old 31st October 2012, 15:16   #155 (permalink)
Syx
Clingfilmed
Syx's Avatar
Car: 2008 2.2 CTS GT
Thanks given: 927
If you're not planning to remap it you won't need a paddle clutch.
Old 31st October 2012, 15:33   #156 (permalink)
I don't?
Hondas OEM clutch suffers from premature failure (from what I read here). It would be nice to know that there is A clutch out there that will not do so (map or remap). Hence why I asked the question
Old 31st October 2012, 15:36   #157 (permalink)
Thanks given: 3
I don't?
The oem clutches did suffer premature failure. However, the latest incarnation (ending in 325) seems to be holding ok, assuming it's not remapped.
Old 31st October 2012, 15:41   #158 (permalink)
Syx
Clingfilmed
Syx's Avatar
Thanks given: 927
I don't?
Your 2010 may well have the 325 clutch fitted already, and my 2008 (which definitely won't have the 325 clutch) is still on the original clutch at 60k miles.
There are alternatives such as kevlar clutches that will handle the standard power without needing a paddle clutch. I understand why you asked the question but a paddle is only needed when remapping for more torque than the OEM map.
Even if you don't have the 325 clutch and yours does fail, it's not massively expensive.
Genuine Honda Civic 2.2 Diesel 3 Piece Clutch Kit [22105PGE325] - Ł150.75 : Cox Motor Parts Direct - Genuine Honda Brakes Clutches & Accessories
Old 31st October 2012, 15:43   #159 (permalink)
Thanks given: 3
It's not that expensive to buy but the labour to fit it is!
Old 31st October 2012, 15:46   #160 (permalink)
Syx
Clingfilmed
Syx's Avatar
Thanks given: 927
IIRC CG charge Ł250 to fit their paddle clutch and DMF, didn't think that was too bad. If you get it fitted somewhere other than Honda you'll save your wallet some pain!
LinkBack to this Thread: http://www.civinfo.com/forum/engines-transmission/83869-cg-motorsport-5-paddle-clutch.html
Sprzgo... - Strona 14 This thread Refback 7th November 2012 17:14
Prokluzující spojka, problém s otá?kami | Honda CIVIC 8. generace This thread Refback 1st November 2012 14:55
Similar Threads for: CG Motorsport 5 paddle clutch
CG 6 Paddle clutch griffian Items for sale 126 11th January 2013 22:41
Clutch CG Motorsport 6 Paddle Clutch Experiance JohnJonjo Engines and Transmission 81 10th September 2012 17:40
Clutch CG 6 Paddle clutch, but which DMF? hapzuk Engines and Transmission 7 4th July 2012 10:57
Clutch CG 6 paddle clutch griffian Engines and Transmission 45 8th June 2012 13:56
Clutch C&G 6 Paddle CLUTCH griffian Engines and Transmission 6 13th June 2011 12:38
