![]() Car: 2006 2.2 5 door sport silver
Thanks given: 34
Cg clutch help
Hello
I went for the CG clutch and now it is all bedded in (600miles) i am finding it difficult to go from second to third on change down the gear stick is quite stiff to get in gear. And also the clutch bite point is right near the top is this normal set up when using a paddle clutch. Before it was installed the bite was just over half way. Could it be down to the fitting. Sent from my GT-N7000 using Tapatalk 2 |
Cockup Specialist
Thanks given: 735
Doesnt sound right to me, normally you have to pushe right into the carpet on a new clutch to release it.....so the bite would normally be low too.
Theres a guy from cg on the forum now so ask in that thread. |
Thanks given: 34
Performance autoworks in Fairford was a top job but just doesnt feel 100%
![]() Car: 09 Suzuki Swift Sport white
Thanks given: 1,108
Sounds like the adjusting mech wasnt properly aligned at installation mine bit 1" off the floor and after 16k of spirited use wasnt much higher
#6 (permalink) | |
![]() Join Date: 24th September 2012
Thanks given: 22
I'm here more in a sales capacity than technical but if you call our technical team (there not allowed on the forums!!!) Im sure they could give you all the info you need. Our number is 0113 2426359 or alternatively if you PM me your number I'll get them to ring you. |
#7 (permalink) | |
Thanks given: 34
Thanks given: 34
Right then folks.
I have spoken to the garage and spoken to CG. After speaking with CG they have recommended that i give the car a good thrashing on the way home from work a little abuse not kill it!! And it has certainly helped with the gear changes alot smoother now. From what he has said i have bedded it in now a full 650 miles so start abusing it. The advice was spot on and i will give it a few more days and see how it goes. Its still booked in next week for the garage to look at. Sent from my GT-N7000 using Tapatalk 2 |
Thanks to mylesjohn from:
Thanks given: 34
Update...
Well after 2 days of showing no respect for the clutch i have covered just shy off 100 miles, and the gear selection is easy now not when its cold but it was always like that. Just not 100% happy with my clutch pedal biting point it has lowered slightly but not enough for me to be happy. Can the pedal be adjusted in anyway with out touching the clutch?? Sent from my GT-N7000 using Tapatalk 2 |
![]() Join Date: 5th October 2011
usually you can do this at the pedal itself, there will be 2 sets of nuts/ bolts that you can use to adjust.
This isn't really a solution though imo, my clutch (not cg) is a year old and still bites near the floor - if something's been done incorrectly i'd still get the garage to check / sort it for you |
#14 (permalink) |
Thanks given: 1,108
Yeah you can adjust the pedal box but ive never done it. The whole point of a self sdjusting clutch is the pedal doesnt move its bite point as the clutch wears.
#15 (permalink) |
Thanks given: 34
Ok cars going in on Thursday so will get him to look
#16 (permalink) | |
![]() Car: 2008 ctdi es nighthawk black
Thanks given: 13
#17 (permalink) |
Thanks given: 34
Well clutch is all sorted after a week of abuse and torture all is 100%.
The clutch bite is just over an inch from the floor. After speaking with the fitter it sounds like after driving it like my nan for 600miles meant the adjusters were never put under stress to adjust it self. So once put under stress it has adjusted it self like it should do and now feels normal. I am very happy with CG as i even spoke to them about my concerns and there help and knowledge, mainly Micks was really helpful. So all in all sorted Sent from my GT-N7000 using Tapatalk 2 |
Similar Threads for: Cg clutch help
| Tuning Slipping Clutch - Tuning or Clutch issue? | Jambo0607 | Engines and Transmission | 7 | 24th May 2012 10:14 |
| Clutch New CG Kevlar Clutch Slipping - Suspect oil on clutch plate | mschwab | Engines and Transmission | 27 | 17th March 2012 02:57 |
| Clutch Clutch - 325, 315 or 305 | xxDIABLOxx | Engines and Transmission | 2 | 13th January 2012 11:52 |
| clutch | clarky0150 | Type-R | 7 | 28th February 2010 22:56 |
| Clutch | Ash_TypeR | Type-R | 5 | 27th February 2010 19:33 |
