#21 (permalink) |
![]() Join Date: 1st October 2012
Thanks given: 8
Cheers Derek, I was being sarcastic about the cooling treatment, not aimed towards your post but the info you provided in reply is much appreciated
Ive ordered some BG44K for my 1.8 and wifes TFSI so will see how it goes and report back on the main thread. |
#22 (permalink) |
[ Laird Mac Nac Feegle ]
Thanks given: 297
The 'MOHA' stuff is very good as well - it's unbelievable how much sludge \ crud appears in the old oil filter ...
Thanks to J. Derek Riddell from:
#23 (permalink) |
![]() Car: 2006 1.8 Sport Ishift Milano
Thanks given: 134
BG44K uses polyether amine, which is very effective at cleaning the engine and does not cause damage. It quite an expensive chemical incomparison to others, but it works exceptionally well.
Thanks to delta0 from:
#24 (permalink) |
![]() Join Date: 27th July 2012
Thanks given: 1
I'm tempted to try the Archoil Petrol stuff next.
Thoughts? http://www.powerenhancer.co.uk/produ...ne-concentrate Last edited by TaKeN; 11th October 2012 at 20:09. |
#26 (permalink) |
Thanks given: 134
Polyether amine is a aliphatic hydrocarbon-substituted amine. The list of ingredients is normally disquised or hidden completely, even on the MSDS they get around it because it is proprietary.
#28 (permalink) |
Thanks given: 134
It is their way of getting around the regulation which states they need to put the amount of each ingredient on the tin. Hydrocarbon is basically anything with hydrogen and carbon bonded which includes polyetheramine and then summed the total of all these chemicals which comes to 99%. Then all they need to do is print 99% hydrocarbons on the tin to comply with the regulation and not give away their formula.
#30 (permalink) | |
Thanks given: 134
Edit: Just looked at the BG44K MSDS, they have put all the ingredients into identification codes so you can't work out the formula. They have also specified a range of % to stop people guessing how much of each of chemicals are used. Last edited by delta0; 12th October 2012 at 10:16. |
#31 (permalink) |
Thanks given: 297
All I know, is that BG44K works
First time I used it, it was two cans / tanks, back-to-back It made the engine - smoother, quieter, more responsive Now I use it about three times a year, and the engine is better than new |
#32 (permalink) | |
Thanks given: 1
But why not try the Archoil Derek?
I emailed power enchancer and he says they're both equally as good. You get more Archoil in a bottle aswell Quote:
#33 (permalink) |
Thanks given: 134
Exactly what I found. I currently have the two cans I ordered last week. Will pop one in soon.
#35 (permalink) |
Most Active Australian
![]() Car: 2010 Black Civic Si FK2
Thanks given: 69
You can get BG44K in a bottle too.
Finding a reseller is the issue. Like the idea of a bottle so i can put in half now for a half a tank and rest later and i know no crap went in. I wanted to get some this week but can't had to fix my civic. |
#38 (permalink) |
Thanks given: 134
BG244 has a diesel fuel pump lubricant I believe. As pointed out it is not suitable for the petrol. BG44K is fine for both.
Similar Threads for: What is bg44k?
| Fuel BG44K Fuel System Cleaner and Carbon Remover | ElNino9 | Engines and Transmission | 87 | 21st May 2013 09:47 |
| BG44k | crowmar kirkliss | General Discussion | 4 | 16th July 2011 10:30 |
