Old 22nd October 2012, 16:10   #1 (permalink)
regrets his username
Car: Championship White
Thanks given: 542
metalic rattle
Noticed this morning a faint metallic rattle when blipping the throttle whilst stationary (thought it might be the heat shield) but I found if I press the clutch and blip it the engine revs perfect no metallic noise just pure engine noise.
I had my clutch replaced in march so maybe rule that out, could it be the flywheel?? or even worse gearbox, is there anyway of finding out without a garage doing the diagnoses
dweezle is offline   Reply With Quote
Old 22nd October 2012, 16:49   #2 (permalink)
Mugen wannabe
Fartnugget's Avatar
Car: 2010 type r championship
Thanks given: 418
I found this morning it was cold and damp I had a clicky strange noise on choke but when I pressed clutch it went and a mile up the road as choke came down the clicky noise reduced but all my gear changes were fine clean etc and didn't get the cold start pull away whine
Fartnugget is offline   Reply With Quote
Thanks to Fartnugget from:
Old 22nd October 2012, 17:07   #3 (permalink)
Thanks given: 542
Hmmm maybe the damp it was really foggy this morning my changes were fine as well, I've got some Redline Mtl sat at home maybe should stick it in
Old 22nd October 2012, 17:11   #4 (permalink)
Mugen wannabe
Fartnugget's Avatar
Thanks given: 418
I have to look for a better gearbox oil I dont want to have to wait for oil to warm up before I get smooth gear changes like last winter
Old 22nd October 2012, 18:11   #5 (permalink)
Thanks given: 542
I was in p.m. with oilman about the best gearbox oil for the champ white he told me to either mix a bottle of fuchs mtf with a bottle of Redline Mtl,
Or to sort out any niggles with syncros and the best for the cold weather is to use the Redline Mtl on it's own and to do a yearly change as its a thinner oil than the mtf, which is what I'm doing, at least that way the oil is fresh every year, I know parsco is using this oil and he says it's brilliant stuff.
Thanks to dweezle from:
Old 22nd October 2012, 20:09   #6 (permalink)
Mugen wannabe
Fartnugget's Avatar
Thanks given: 418
Shall look into this asap, thanks matey
Old 24th October 2012, 00:33   #7 (permalink)
Forbidden8701's Avatar
Car: FN2 CTR GT
Thanks given: 17
I've noticed this on mine as well. Sounds like a loose bolt or something.
Forbidden8701 is offline   Reply With Quote
Old 24th October 2012, 16:04   #8 (permalink)
hondacivicnut's Avatar
Thanks given: 30
VTEC engines are noisy though, my ITR motor sounds noisy when cold. As soon as it's warm it's quiet. As for gearbox oil, I'd only ever use Honda MTF. My ITR is on 170k and regularly tracked and that it all it has ever had in it.
hondacivicnut is offline   Reply With Quote
Similar Threads for: metalic rattle
Metalic Paint? ibanezguy General Discussion 8 26th September 2011 20:38
Trim Rattle Windlepoons Bugs, faults and irritations 5 26th August 2011 23:17
Squeaks Metalic scraping noise from front wheel gef Bugs, faults and irritations 9 11th May 2011 19:35
Squeaks Rattle Rattle @ 50mph Mang0 Bugs, faults and irritations 11 27th February 2011 20:42
Brakes Loud metalic click under braking fennj Bugs, faults and irritations 19 23rd August 2008 22:42
