| This thread is about: Engine noise at 500 miles, it's in Engines and Transmission at the Honda Civic forum Civinfo; I am getting a very gentle but clearly audible ticking noise from the engine at idle when it has warmed up. A Honda tech told ... | ||
I am getting a very gentle but clearly audible ticking noise from the engine at idle when it has warmed up. A Honda tech told me it was tappet noise but I cant believe that as it has only done 500 miles. This is a Type R, 10 days old, and it was even run in gently ie not done more than 5000 rpm. Is this usual? Comments....
That will be tappet noise - but it's a good thing (tappets with no gap are not a good thing).
I would try taking the car for a good thrash (having warmed it up) and see if that reduces it. |
#3 (permalink) | |
Civic Mad!
A good thrash will certainly get the oil flowing so give it a go |
Fuel injectors also make a similar clicking / ticking noise. I havent noticed anything unusual from mine, but will have a listen to it on idle tonight.
well I don't know the Type-R engine but at the 1.8 petrol there is no hydraulic stuff. The clearance will be set by a screw.
(must be checked at every 48k miles) at the 1.8 the valve clearance can be checked by the Honda Diagnostic System. my opinion is if you will rev your engine hard (will be a good fun are you sure it is a problem? can't you compare it with another CTR? (make sure both engines are warm enough!) can it be sg else is giving the noise? some plastic/cover vibration? or alternator? is the ticking frequency changeing/increasing with the rpm? |
#6 (permalink) | |
Civic Mad!
| engine noise | shakie1973 | General Discussion | 9 | 11th July 2007 05:26 |
| MPG 65 mph for 100 miles gives... | Pottsy | Engines and Transmission | 93 | 29th June 2007 23:59 |
| Faults Engine noise! | gs7776 | Engines and Transmission | 7 | 25th February 2007 15:09 |
| Engine 3000 miles, 7 weeks and 1 expired Diesel Engine! | cosmic girl | Bugs, faults and irritations | 53 | 11th November 2006 03:52 |
| Other is civic hb engine type-r engine? | mrcanadian | Engines and Transmission | 1 | 26th October 2006 21:56 |
