This thread is about: Rolling Road Results, it's in Engines and Transmission at the Honda Civic forum Civinfo; I had my car on the rollers today @ Awesome GTi in Manchester. I'm not aware of a 'standard' car being tested as such, just ...
Old 20th October 2007, 16:54   #1 (permalink)
Type S GT
I'm not aware of a 'standard' car being tested as such, just remapped ones.
(Please correct me if I'm wrong)
Here are the results of the three runs:
Run 1 = @wheels - 125.90 bhp @clutch/flywheel - 136.17 bhp = 269.65 max torque
Run 2 = @wheels - 126.22 @clutch/flywheel - 133.76 bhp and 272.95 max torque
Run 3 = @wheels - 128.17 @clutch/flywheel - 138.10 bhp and 270.61 max torque
Average: 136.01 bhp and 271.07 max torque
Honda Max Torque quote: 251 ft/lbs
Last edited by robbo51; 20th October 2007 at 20:31. Reason: Added more information. Graph to follow
Old 20th October 2007, 17:02   #2 (permalink)
Yours is standard?
Old 20th October 2007, 17:09   #3 (permalink)
Seirrah's Avatar
FWH: Seems standard from the results.
So now you're going to 'chip' it to show the improvement it makes???
Seirrah is offline   Reply With Quote
Old 20th October 2007, 17:34   #4 (permalink)
Rated at 140 on the flywheel as standard - 136 is good on the wheels!
Not first claim of the 2.2 being powered beyond spec.
Old 20th October 2007, 19:18   #5 (permalink)
Type S GT
136 is at the flywheel.
Old 20th October 2007, 19:24   #6 (permalink)
Never having been to a rolling road myself I presumed that it only measured wheel power and torque.
How is the flywheel power calculated from the test result data?
Old 20th October 2007, 22:39   #7 (permalink)
FWH - it calculates it on the slowdown part of the graph.
From this it can (cleverly, somehow) work out what the power loss is due to transmission drag.
no idea how - just know that's what it does
@ robbo - nice one sir!
@both - interestingly, when I had my standard engine done, the transmission losses cam to about 20bhp, not the 10 bhp awesome's did.
My max bhp @ wheels was about 128 too...
Diesel Tuning UK 'chip'
Old 20th October 2007, 22:51   #8 (permalink)
dug out 323GT-R's stock results
interestingly they are showing less power at the wheels than yours, but more losses, giving bigger corrected numbers...
which is why, I guess, it's best to get a 'before' and 'after' from the same dyno whenever carrying out any work
Old 21st October 2007, 09:13   #9 (permalink)
I would agree.
Are you sure it just doesnīt "asume" a %-age?
Old 21st October 2007, 09:43   #10 (permalink)
when I had mine done it definately didn't - you could watch the power graph line going up with the revs, then a flat(ish) line along the bottom on the coast down, then it calc'd a 'power at flywheel' line afterwards
Old 21st October 2007, 09:46   #11 (permalink)
very interesting - would like to know how they work that out..
Old 21st October 2007, 10:47   #12 (permalink)
Puma Race Engines Technical Guide - Measuring Engine power - engine dynos and rolling road dynos
and
Puma Race Engines Technical Guide - Coastdown Losses as measured on Rolling Road dynos
Old 21st October 2007, 11:12   #13 (permalink)
basically they donīt (correctly)...
Old 21st October 2007, 11:33   #14 (permalink)
Indeed - they just make a good, semi-measured guess. Wheel horsepower off the same rolling road is the only good comparison. And even then this is not representative of real power on the road - for example a diesel with an intercooler will make more power when travelling at speed than it will on the rollers.
Old 21st October 2007, 15:06   #15 (permalink)
Type S GT
The torque figures are better than Honda say anyway!!
Old 23rd October 2007, 15:57   #16 (permalink)
Type S GT
EDIT:
Some pics now added
Old 23rd October 2007, 18:10   #17 (permalink)
was the blower blowing robbo?
nice pics
scary isn't it!
Old 23rd October 2007, 18:59   #18 (permalink)
Type S GT
Very loud and a lot of air coming from the blower.
Scary.....??...er....No?
NOW WITH VIDEO!!
Old 5th November 2007, 19:13   #19 (permalink)
this thread also worth a read
i-CTDI chipped from poland
Old 5th November 2007, 19:28   #20 (permalink)
time for a remap to unleash the 2.2 s power
LinkBack to this Thread: http://www.civinfo.com/forum/engines-transmission/8950-rolling-road-results.html
YouTube - Dynorun Honda Civic FK3 @201 bhp!!! Post #35 Refback 29th April 2008 19:28
Similar Threads for: Rolling Road Results
Wales Rolling Road Day 07/10/07 Newport, South Wales Salem Meetings 70 12th October 2007 19:55
Survey Results richierich General Discussion 9 14th July 2007 21:46
JD Power Survey - the results are in!!! Brodick General Discussion 72 1st June 2007 00:14
Tyre Other Rolling resistance DEK Wheels, Tyres, Suspension and Brakes 2 24th January 2007 22:50
Euroencap Results tucker101uk General Discussion 2 29th November 2006 20:54
