This thread is about: how much oil do you use, it's in Engines and Transmission at the Honda Civic forum Civinfo; Same here, run in nice and hard. No oil usage yet - 700 miles done. Tom...
Old 4th November 2007, 16:32   #21 (permalink)
Smart A*se
Old 5th November 2007, 06:59   #22 (permalink)
TANSTAAFL!
GHGH's Avatar
Checked this weekend - now the consnotion is at least visable - after 15500 km (9600 miles).
Old 5th November 2007, 09:40   #23 (permalink)
squirrelz's Avatar
2.2 CTDI Sport - 4500 miles and ~800ml used
Tried to use the Mototune method for running in, but only used occasional full throttle.
squirrelz is offline   Reply With Quote
Old 5th November 2007, 22:13   #24 (permalink)
aside from chucking in a couple of glugs at 11,000 miles (was heading towards being low and service was a month away), mine hasn't used a drop
now at 27,000 miles in 15 months
also ran in using Mototune method
Old 6th November 2007, 03:53   #25 (permalink)
Vider's Avatar
I did exactly the same. and have the same resoult 4700miles and about 800ml of oil used. However after first 600miles I changed all my oil to castrol edge diesel 0W30. But still had to top up after 2000miles as it was showing me low on deep stick. Put 500ml then. Second top up after another 2000miles about 300ml.
Vider is offline   Reply With Quote
Old 6th November 2007, 09:02   #26 (permalink)
spile's Avatar
I had to top up at around 2000 miles. It hasn't needed a drop since - currently on 5800 miles
spile is offline   Reply With Quote
Old 6th November 2007, 15:40   #27 (permalink)
cnicolini's Avatar
Originally Posted by gsyme View Post
It would be interesting to know how the cars that use a lot of oil were treated during the 'running in' period. Is it a case that the cars with a high oil consumption were treated gently for the first 1000 miles or so?
I have now done 1,500 miles and treated the car gently for the first 1000 miles. I must of only brought the car up to 6000 rpm around 4 times during this period, and the car has nt used any oil as of yet.
The dipstick is a bit tricky to read on the Type R's. I always used to check the oil from cold, but apparently you now have to check it after a run on this car!
Old 7th November 2007, 00:51   #28 (permalink)
little to nothing....unlike some modern VW's where I have heard it costs you more in oil between oil changes than it costs for the service as the oil is so expensive.
jenny29 is offline   Reply With Quote
Old 15th November 2007, 20:30   #29 (permalink)
surferjr1999's Avatar
oil used
8000 miles and 1 Litre used. Early on some fast runs in line with motortune method.
surferjr1999 is offline   Reply With Quote
Old 15th November 2007, 20:58   #30 (permalink)
aardvark's Avatar
0.5 litre in 6000 miles
aardvark is offline   Reply With Quote
Old 17th November 2007, 21:59   #31 (permalink)
JIMBO7268's Avatar
Just completed 4000 miles in 5 weeks, 90% motorway miles. The oil light has jjust come on (in the middle of the moors) and used 900 ml.
JIMBO7268 is offline   Reply With Quote
Old 18th November 2007, 00:01   #32 (permalink)
andrewuk's Avatar
I've done 4,500 miles now - haven't used a drop.
andrewuk is offline   Reply With Quote
Old 24th November 2007, 16:40   #33 (permalink)
Exiled Englishman
bucketp's Avatar
11750 miles not used a drop, oil will be changed at 1st service in two weeks.
Old 24th November 2007, 16:47   #34 (permalink)
Type R GT 09570
Just done the first 600 miles in mine. Checked the oil and it is still on the upper mark if not a tiny bit over.
Old 26th November 2007, 18:27   #35 (permalink)
sco77harris's Avatar
i was just at the dealer for various things and i have the orange dipstick it is now metal i think, and in the manual it says fill between the two dots, thinkng this was the massive bubble on the dipstick ive had it completely overfiled and its lucky we disscussed it with the technitian as he said the engine could blow lol what a stupid car manual and dipstick
Old 27th November 2007, 16:47   #36 (permalink)
Honda aficionado
Doubtingthomas's Avatar
How much oil do you use
My NHB ES i-shift has now done just 1000 miles after a very careful run in as per practice advocated in the Wiki. I find the plastic dip stick not the best to read and I sense that the engine oil level has dropped a little. I am keeping a close eye on it.
Old 27th November 2007, 17:53   #37 (permalink)
Smart A*se
The dipstick is an abysmal thing especially with new oil.
Old 28th November 2007, 08:33   #38 (permalink)
cnicolini's Avatar
I have had my car for 2 months now and have checked the oil weekly, it still does nt need topping up. Just clocked 2200 miles. There is a big difference in performance now that the car has run in. I still have nt red lined it and dont think that I will for a few more miles.
Old 28th November 2007, 09:03   #39 (permalink)
dondon's Avatar
2.2 EX - 2 litres used in 10,500 miles. Gentle running in.
dondon is offline   Reply With Quote
Old 28th November 2007, 09:23   #40 (permalink)
Charley Farley's Avatar
Hi All
Now done 10,600, miles and used just over a litre of oil. First service on 28.12.07 at Balmer Lawn Garage.
