This thread is about: Reverse Gear, it's in Engines and Transmission at the Honda Civic forum Civinfo; Have any of you experience the following: I was putting the car into my garage and reversing back, then I decided to go forward to ...
Old 26th October 2007, 20:36   #1 (permalink)
cnicolini's Avatar
Reverse Gear
Have any of you experience the following: I was putting the car into my garage and reversing back, then I decided to go forward to straighten up, and while moving forward and decided to switch to reverse while moving, manage to put the gearing half way in reverse. The gear stick got stuck in this position and I had a job taking it out!
I believe that the car has a safety feature stopping you from selecting reverse while moving forward? If so I should stop these bad driving habits!
Old 26th October 2007, 21:23   #2 (permalink)
Yes it has - what else would prevent selecting reverse during a normal drive in this kind of gearbox
Old 26th October 2007, 22:19   #3 (permalink)
cnicolini's Avatar
OK thanks, I thought so. I must remember to completely stop before trying to put the car back in reverse, I thought the gearbox had broke!
Old 27th October 2007, 10:41   #4 (permalink)
On my i-Shift, it doesn't always find reverse!
Then I have to select neutral and start again.
Make you look a right prannie when doing a three point turn or similar.
"Would you say that I am selfish?
"No, not to your face!"
Charles H.
Old 27th October 2007, 16:49   #5 (permalink)
cnicolini's Avatar
I was looking at the manual and it does state that you have to be completely stationary before selecting reverse, or it wont engage gear. With me I must of released the foot brake as I was putting it into reverse. and rolled forward. I wont be doing that again!
Its a clever system as when you are driving you cant shift the gear level right across to select reverse, it just does not go that far unless you are stationary and completely stopped.
Old 27th October 2007, 17:02   #6 (permalink)
Korkut Varol's Avatar
Yep, the "i-" stands for intelligent!
Old 23rd November 2007, 21:39   #7 (permalink)
cnicolini's Avatar
It did it again, the car was totally stationary and I went to put it into reverse, it started to go in and then the gear stick just got stuck. I could nt get it into reverse and had to yank it out back into neutral. It worked the second time.
I dont think that the dealer can do anything as its only the second time its happened in 2 months, and I cant reproduce the problem. The only common facter is that it was pretty cold outside on both occasions. I'll call the dealer tomorrow, see if its a known problem????
Old 24th November 2007, 01:57   #8 (permalink)
ukpm's Avatar
Interesting side fact: the 2.2's gearbox has a syncromesh reverse gear, but the 1.8 does not. Much handier to have full syncro reverse, as you can engauge it without coming to a total stop. You also don't get that annoying whine sound while using reverse gear.
I wonder why they're different?
Old 24th November 2007, 07:19   #9 (permalink)
cnicolini's Avatar
I think that in this case its the auto lockout thats causing the issue, when the car is moving forward, or when it thinks it is it locks out reverse gear. This stops you from pushing the gear stick further along to select reverse. In my case its decides that you are moving forward as you are selecting reverse and sticks. Thinking about this, it may not be the actual gearbox but maybe a senser problem, its only happened twice, once a month so far.
Mind you the gear box is still stiff as its only 2 months old!
Old 24th November 2007, 17:06   #10 (permalink)
cnicolini's Avatar
I called the dealer today and he told me to keep an eye out on it, and it was nothing worth worry about! Also said that the gearbox should become looser as the linkages wear in. I've only done 2000 miles. I bet all this cold does nt help!
Old 3rd December 2007, 20:29   #11 (permalink)
uncler's Avatar
Well, just thought I'd put my comment in here, seeing as someone else has experienced this... Had my Type R for 2 days now, and leaving work today I had the same as you describe - the gearbox just locked up half way into reverse. I had tried to engage it whilst stationary, so shouldn't have locked. However, for the life of me I couldn't get it to pop out again, so I had to turn off the car, lift the clutch up, depress the clutch, fire up the engine again and sort of tugged it back into neutral. I looked a right wally in front of colleagues. It had better not do this again else Honda shall be getting a call. I'm just pleased I have 3 years warranty!
uncler is offline   Reply With Quote
Old 4th December 2007, 12:48   #12 (permalink)
cnicolini's Avatar
I'm taking the car in to the dealers tomorrow about my wipers creaking and the relay clicking, I will mention the gearbox to them and will let you know! The problem is that its only happened twice in over 60 days! I would of thought that Honda would of been better than this!
Old 4th December 2007, 13:43   #13 (permalink)
uncler's Avatar
If you could let us know what they say, that'd be great. Being that my car is only a few days old, my plan is to wait a few weeks to see if anything else crops up before reporting back to Honda. Haven't noticed anything else as yet, touch wood!
Old 4th December 2007, 14:46   #14 (permalink)
cnicolini's Avatar
OK. I've now clocked 2500 miles and the engine has loosen up. I did call the dealer about the gearbox last week, they told me it may be because the gearbox was still new and needs to wear in a little. they told me not to worry! Who knows, but I will talk to the dealer about it again!
Old 5th December 2007, 12:19   #15 (permalink)
cnicolini's Avatar
I have just returned from the dealer, the mechanic told me that there was nothing to worry about. He said that the gearbox sticking could be down to the oil and the parts in the gearbox still being tight, as its still new. In time everything should loosen up. He also said that you can try placing it in 1st, and then reverse. I suppose thats good news!
Similar Threads for: Reverse Gear
top gear vtec-hungry Type-R 22 30th August 2007 12:05
Sunday Times - reverse beeper bibster80 General Discussion 20 15th February 2007 13:09
Top Gear Mag Unguided General Discussion 25 9th January 2007 10:02
Transmission 2nd gear stu_iow Engines and Transmission 10 15th November 2006 19:23
Auto locks in reverse gear Copycat General Discussion 4 25th October 2006 19:28
