This thread is about: Oils well that ends well, it's in Engines and Transmission at the Honda Civic forum Civinfo; After reading multiple threads about this subject, I know its been talked to death, but I`m afraid I still need some advice: I spoke to ...
Old 22nd November 2007, 11:45   #1 (permalink)
Splodgehead's Avatar
I spoke to my dealer about what type of oil to use in my `57 plate 2.2. He said that so long as it was synthetic it would be ok. He also confirmed that my car has a DPF. Looking on the castrol website it states that the oil to use is Castrol Edge (turbo Diesel). Is this the one to go for?
Also, (and I feel a bit of a dumbass asking this one), when is the best time to check the oil - When the engine is cold, or after a run out? Which gives the best indicator of oil level?
Thanks in advance.
Splodgehead is offline   Reply With Quote
Old 22nd November 2007, 11:48   #2 (permalink)
philiphenderson's Avatar
Castrol Edge (turbo Diesel). <- Yes
A warm engine left for 3ish minutes.
Phil.
philiphenderson is offline   Reply With Quote
Old 22nd November 2007, 11:55   #3 (permalink)
mattlittle's Avatar
Thanks in advance.
The thread on DPFs suggests that these are definitely not standard on UK cars - did you have as an optional extra?
mattlittle is offline   Reply With Quote
Old 22nd November 2007, 11:59   #4 (permalink)
No, to be honest I didn`t put too much credence into what he said, (he told me previously that he has only worked at Honda for acouple of months) I personally don`t think that my car has a DPF, but the castrol site does recommend different oils for `06 `07 cars.
Old 22nd November 2007, 12:07   #5 (permalink)
Essexboy's Avatar
He sounds like an idiot, I would ignore anything he tells you....
[quote=Splodgehead;122213He also confirmed that my car has a DPF.
[/quote]
I've not heard of any UK civics having a DPF, surely you wouldn't add it unless you had to?
Essexboy is offline   Reply With Quote
Old 22nd November 2007, 12:26   #6 (permalink)
So, Castrol Edge (turbo diesel) it is then....
Old 22nd November 2007, 13:02   #7 (permalink)
mattlittle's Avatar
I'm guessing that '06 Civic might mean the old one and '07 (being the first 'full year of production) means the new civic?
Old 22nd November 2007, 18:41   #8 (permalink)
cnicolini's Avatar
Its quite striaght forward really, check out the manual. On my CTR its 5-40w oil and they recommend semi-sythetic. You can use any brands of oil as long as they meet this specification. I would use fully-sythetic but its suppose to be more watery and can do more harm than good. I'm using Mobile 1 which is apparently what Honda Enfield use.
Old 26th November 2007, 23:42   #9 (permalink)
Civic Fan's Avatar
Why not just try plain old ordinary water like these guys did!! Check this You Tube film out. Its astonishing. Just don't try to make a warranty claim if you do.
The guys are having some fun but wait and see what they do to try and kill the car. It just wont give up without afight!!
I love my Honda!!
http://uk.youtube.com/watch?v=uyAwFw0eXwE
Civic Fan is offline   Reply With Quote
Old 1st December 2007, 02:17   #10 (permalink)
lobey dosser's Avatar
Originally Posted by Civic Fan View Post
Why not just try plain old ordinary water......
Water is a perfectly good lubricant...it's the sole lubricant for the external prop shaft bearings on ships.
It's just that it's boiling point is a bit on the low side for automotive use!
lobey dosser is offline   Reply With Quote
Old 2nd December 2007, 15:43   #11 (permalink)
Civic Fan's Avatar
Interseting but I think I'll stick to using oil in the Civic.
Similar Threads for: Oils well that ends well
Red Civ, four lane ends. Andrea Was it you? 23 26th March 2007 22:28
