This thread is about: Who wants a flip key?, it's in General Discussion at the Honda Civic forum Civinfo; Originally Posted by Stef I also noted that the transponder is connected to the processor. I am 99% sure that this is to configure the ...
View Poll Results: Are you interested in purchasing a flip key?
Yes, and I am willing to pay upto £15 for one. 803 88.93%
No, I am happy to live with the key I have. 100 11.07%
Voters: 903. You may not vote on this poll | Withdraw Vote
LinkBack (14) Thread Tools
Old 3rd February 2008, 20:20   5 links from elsewhere to this Post. Click to view. #321 (permalink)
Civic's got Big Booty !
csmcqueen's Avatar
I am 99% sure that this is to configure the transponder.
Once it is configured it can be removed, since NO power is needed to make the transponder work...
Once I have my Ebay key, I will probably try to remove the transponder if the key does not work
oops missed this post before i posted my question !!!
csmcqueen is offline   Reply With Quote
Old 3rd February 2008, 21:25   #322 (permalink)
Marky's Avatar
still puzzled as the pictures of the accord key show that the transponder is not connected to anything so how is it programmed.
I would have thought that if it is connected there must be a reason like possibly making it more secure somehow ?
Still expensive to just pull off with some pliers in case it does not work. Think I will be sticking with the standard key for now.
Marky is offline   Reply With Quote
Old 4th February 2008, 08:15   #323 (permalink)
mark511915's Avatar
IS there no way we could conact someone from honda to help with this ?
mark511915 is offline   Reply With Quote
Old 4th February 2008, 09:27   #324 (permalink)
Stef's Avatar
Car: 2006 Civic EX
A transponder does not need power to opperate, it uses the car transponder induction field to provide is own power (that is why it is so sensitive for distance).
Transponders can be pre-programmed (like accord one) or can be Reprogrammed like Civic.
I also think that 2006 Accords will have the same type like Civic.
Old 4th February 2008, 09:27   #325 (permalink)
eighteentee's Avatar
Damn! I just ordered one of these flip keys off ebay to put me on until the Bentley one's become available. Buggeration!!
eighteentee is offline   Reply With Quote
Old 4th February 2008, 10:14   #326 (permalink)
Marky's Avatar
Presume as it is not a Honda OEM product they would advise to steer clear and I bet that they would not endorse removing the transponder from the circuit board just to get the flip key working.
Mark
Old 4th February 2008, 10:38   #327 (permalink)
mark511915's Avatar
oh well guess we be patient and see what our chinas come up with !!!! ill hold thumbs !!!!
Old 4th February 2008, 11:08   #328 (permalink)
babyjoe's Avatar
If you cut the connection, you can always solder it back on again if it shouldn't work.
babyjoe is offline   Reply With Quote
Old 4th February 2008, 12:14   #329 (permalink)
So, in conclusion if you've ordered one off eBay it's next to useless?
Old 4th February 2008, 12:20   #330 (permalink)
Stef's Avatar
Car: 2006 Civic EX
Just received my Ebay keys.
It does not look too bad, but could be better.
It does look made for the Accord type key, with separate transponder. There is a cavity for the transponder in the front of the key.
Also the Civic internal does not fit exactly, some plastic from the flip key must be removed
I gues I will have to remove the transponder from the Civic key to make a test, cross our fingers.
Old 4th February 2008, 12:37   #331 (permalink)
TYPE_S_GT's Avatar
it actually looks quite good, keep us posted on how you get on. As someone has said earlier the transponder does not require any connectors or power you should be able to put it in the cavity and the key "should" work.
TYPE_S_GT is offline   Reply With Quote
Old 4th February 2008, 12:38   #332 (permalink)
csmcqueen's Avatar
Now the big question is does the transponder need the main processor of the remote more than once to initially set the code or does it 'roll' every now and again and need the processor again, in any case I suppose you could extend the connections on the transponder and solder to the main board (this is what I would do)
But.... It doesn't make the job easy for the average person and the Bentley type keys.
Old 4th February 2008, 13:35   #333 (permalink)
TYPE_S_GT's Avatar
i dont think there are any connectors, i think the bits on the side of the transponder are simply there to hold it in place. i had a remote start clifford on my previous car this required the transponder to be removed from the key and taped inside the steering column. i had it for 4 years and never had any problems.
Old 4th February 2008, 13:40   #334 (permalink)
csmcqueen's Avatar
anyone know what model number is on the transponder and I will trace the manufacturer
Old 4th February 2008, 17:45   #335 (permalink)
kamshaft's Avatar
that ebay one dose look quite tastey
kamshaft is offline   Reply With Quote
Old 4th February 2008, 18:22   #336 (permalink)
The Talented Mr. Robbieee
Robbieee's Avatar
Car: 2.2 type S GT (Milano)
Does it feel cheap?
Old 4th February 2008, 19:50   #337 (permalink)
Stef's Avatar
Car: 2006 Civic EX
Flip key is a fact !
The Ebay flip key WORKS.
It will take some skills, you will have to move the transponder out of the original box. The transponder MUST BE WIRED to his original pads. it does NOT work without connection.
So:
1- cut the flip key plastic like in the picture to make the original box perfect fit
2- Check the original transponder position (polarity)
3- Remove the transponder from the original PCB (Use 2 soldering irons, to heat each side, or use a special desoldering tool)
4- Connect 2 small wires to the original transponder pads
5- Solder the wires to the transponder (mind original polarity)
6- Glue the transponder in place as far to the front as possible (cut the flip key transponder cavity )
Hint: put some silicone grease on the flip mechanism.
Pollish the metal key part after cutting.
Good luck
Old 4th February 2008, 20:12   #338 (permalink)
Stef's Avatar
Car: 2006 Civic EX
Originally Posted by Robbieee View Post
Does it feel cheap?
Just had a VW flip key in my hand and the Ebay one feels same.
I do find the Ebay one a bit too big, it is allmost a mobile phone...
I also think the plastic will scratch easily.
Old 4th February 2008, 20:14   #339 (permalink)
Robbieee's Avatar
What size is it?!?!
Old 4th February 2008, 20:35   #340 (permalink)
mark511915's Avatar
What size is it?!?!
you can see the size in a previous post ! just need a pic of it open now i still like the bently !!!
LinkBack to this Thread: http://www.civinfo.com/forum/general-discussion/10803-who-wants-flip-key.html
S2000 Forums -> Flip key option that works? This thread Refback 5th November 2008 01:38
RDX flip key - Page 27 - 8th Generation Honda Civic Forum This thread Refback 13th October 2008 11:28
RDX flip key - Page 26 - 8th Generation Honda Civic Forum This thread Refback 20th September 2008 05:57
anybody interested in flip key ? - HondaCivicForum.com This thread Refback 19th August 2008 05:11
Chaveiro Canivete - Adaptação para o New Civic This thread Refback 19th August 2008 00:22
Flip Key Civic si altele - Page 5 - Hondafan Post #0 Refback 17th August 2008 19:23
Forums CivicYume • Afficher le sujet - Aimeriez-vous une clef de contact pliable ou rétractable? This thread Refback 14th July 2008 17:34
Honda Flip Key - Page 2 - Ozhonda Forums This thread Refback 11th May 2008 01:02
RDX flip key - Page 17 - 8th Generation Honda Civic Forum This thread Refback 10th May 2008 22:39
Forums CivicYume :: Voir le sujet - une cl...typ ? This thread Refback 6th May 2008 10:28
Llave retractil para Honda en Ebay - Club HondaSpirit This thread Refback 15th March 2008 15:05
www.clubhondacivic.com :: Ver tema - LLAVE PEGABLE para el Civic + info + FOTOS This thread Refback 13th March 2008 17:03
anybody interested in flip key ? This thread Refback 1st March 2008 03:03
www.clubhondacivic.com :: Ver tema - Llaves tipo espadín This thread Refback 5th February 2008 08:45
Similar Threads for: Who wants a flip key?
Alarm Flip Keys pekwah1 Electronics 19 15th July 2007 23:53
