This thread is about: Who wants a flip key?, it's in General Discussion at the Honda Civic forum Civinfo; Originally Posted by gray52 for all my fine work i always use a 12w, and have had no problems. the 25w will have a screw ...
View Poll Results: Are you interested in purchasing a flip key?
Yes, and I am willing to pay upto £15 for one. 492 87.70%
No, I am happy to live with the key I have. 69 12.30%
Voters: 561. You may not vote on this poll | Withdraw Vote
LinkBack (10) Thread Tools Search this Thread Display Modes
Old 15th April 2008, 16:58   #701 (permalink)
Honda aficionado
Doubtingthomas's Avatar
Originally Posted by gray52 View Post
for all my fine work i always use a 12w, and have had no problems. the 25w will have a screw driver type bit in it, and this could end up melting the plastic transponer if you slip with it. this is 2 jobs in one, so you have to heat the transponer and prize it off all at the same time, one end at a time. with the 25w you will be putting alot of heat in one place while you fiddle around trying to prize it off.
Oh s**t! Good luck Allan!
Old 15th April 2008, 17:05   #702 (permalink)
allan40alt's Avatar
Looks like a job for Solderman then!
Old 15th April 2008, 18:30   #703 (permalink)
gray52's Avatar
the other option is to buy a 12w soldering iron, about £10. much cheaper than a new key at around £100.
Old 16th April 2008, 09:38   #704 (permalink)
Robbieee's Avatar
Or you could just borrow one out your work like me that has a variable temp setting Doesnt help i know!
Yep u can pick up 12w soldering irons with fine tips off of flea-bay for about the 10 quid mark...
Old 18th April 2008, 10:53   #705 (permalink)
allan40alt's Avatar
I have a spare flip key if anyone is interested. I'll post details in the 'For Sale' section.
Old 29th April 2008, 06:34   #706 (permalink)
tzo
tzo's Avatar
gray52 i probably damaged the transponder (H 650 D)from my original key.so, do you have any idea where and how(PN,site,etc) i can found another one transponder only, (new) in order to fix it and make my flip key to work ? thanks in advance.
tzo is offline   Reply With Quote
Old 29th April 2008, 08:42   #707 (permalink)
Type-R GT [R-11523]
Harlequin's Avatar
I damaged my transponder when I did mine. I only had a 25W soldering iron and thought I was clever enough to get away with it.
Turns out I wasn't.
HOWEVER: I figured that because the TS is attached to the Circuit board on this model key and was free floating on the last one that there was a good chance that the Transponder is actually programmed my one of the other chips.
Based on this I jumped on ebay and bought a 2nd hand (already cut) key off some bloke and went at it again - having bought a smaller soldering iron.
I was right - transponder from a key that has nothing to do with my car - soldered to my remote key electronics - works a treat.
The 2nd hand key cost me £8... Much cheaper than a new key from Honda - and now I have a spare battery as well.
-H
PS: the code printed on the TS of the key I bought was NOT the same as the one on my original - still worked.
Harlequin is offline   Reply With Quote
Old 29th April 2008, 09:18   #708 (permalink)
Crab - 2.2 Diesel Sport
Sandozer's Avatar
Turns out I wasn't.
-H
That`s a valuable piece of information there Harlequin, nice one......
Sandozer is offline   Reply With Quote
Old 29th April 2008, 09:18   #709 (permalink)
gray52's Avatar
tzo, i would follow harlequins advice, as ive never stuffed one and dont know to sort one. i was right on the soldering iron guide, 25w is abit to much, as you have just found out.
Old 29th April 2008, 11:49   #710 (permalink)
tzo
tzo's Avatar
Turns out I wasn't.
-H
thanks Harlequin.yours info were very helpful.it would be very polite if you have also a link to buy a second hand key ?thanks a lot !
Old 29th April 2008, 11:51   #711 (permalink)
tzo
tzo's Avatar
ok gray52 i will do hopping to work at the end
Old 29th April 2008, 12:18   #712 (permalink)
Type-R GT [R-11523]
Harlequin's Avatar
This is the Guy I got mine from:
HONDA REMOTE CONTROL ALARM FOB BUTTON KEY BLIP on eBay, also Keyrings Keyfobs, Branded Automotive Merchandise, Automobilia, Cars, Parts Vehicles (end time 03-May-08 15:58:25 BST)
HONDA REMOTE CONTROL ALARM FOB BUTTON KEY BLIP on eBay, also Keyrings Keyfobs, Branded Automotive Merchandise, Automobilia, Cars, Parts Vehicles (end time 03-May-08 15:58:54 BST)
Those 2 Auctions are open until May 3 and they are both sitting at 99p at the moment...
-H
Old 30th April 2008, 07:20   #713 (permalink)
tzo
tzo's Avatar
A new happy flip key (active) owner !
Old 30th April 2008, 22:56   #714 (permalink)
markvirgo's Avatar
I have received my replacement flip key after the key cutter messed up the first one and now I need to find a key cutter near north London.
Anyone know of one?.
I used a 12v soldering iron that has a car cigarette lighter on the end powered by a car charger set to 12v.
This was the only low powered one that i had and it wored great.
markvirgo is offline   Reply With Quote
Old 7th May 2008, 12:49   #715 (permalink)
allan40alt's Avatar
I found this seller who appears to have a better quality switchblade key.
This particular key is for the American market but I've contacted the seller and he does do a two button version for the European Civic.
I have ordered one as a sample to see the quality and will report further when I receive it in a day or so.
You can view the American three button version here:
eBay Motors: HONDA RIDGELINE PILOT SWITCHBLADE REMOTE KEY CWTWB1U545 (item 360047364984 end time May-05-08 14:27:54 PDT)
Old 7th May 2008, 16:33   #716 (permalink)
Robbieee's Avatar
Practically the same as the usual ebay one TBH
Old 8th May 2008, 07:53   #717 (permalink)
iamholam's Avatar
I'd definitely be interested in your results allan. Looking forward to your write up. What flip key have you got at the moment? The standard ebay £11.99 one?
Old 8th May 2008, 08:10   #718 (permalink)
allan40alt's Avatar
Yes, but I'm not too happy with the overall 'feel' of it and the quality of the spring return; but, for £12 it's pretty good.
This new one is a little more expensive, but looks a better quality (in the picture anyway!!!). We shall see. It should arrive any day now.
Old 8th May 2008, 09:20   #719 (permalink)
Robbieee's Avatar
Interesting.....very interesting.....Post pics of the comparison?
Old 11th May 2008, 11:26   #720 (permalink)
got my key from ebay.
now need to do the hard job
JohnRambo is offline   Reply With Quote
LinkBack to this Thread: http://www.civinfo.com/forum/general-discussion/10803-who-wants-flip-key.html
Honda Flip Key - Page 2 - Ozhonda Forums This thread Refback 11th May 2008 00:02
RDX flip key - Page 17 - 8th Generation Honda Civic Forum This thread Refback 10th May 2008 21:39
Forums CivicYume :: Voir le sujet - une cl...typ ? This thread Refback 6th May 2008 09:28
RDX flip key - Page 13 - 8th Generation Honda Civic Forum This thread Refback 17th March 2008 22:21
www.clubhondacivic.com :: Ver tema - LLAVE PEGABLE para el Civic + info + FOTOS. Funciona This thread Refback 17th March 2008 07:53
Llave retractil para Honda en Ebay - Club HondaSpirit This thread Refback 15th March 2008 14:05
www.clubhondacivic.com :: Ver tema - LLAVE PEGABLE para el Civic + info + FOTOS This thread Refback 13th March 2008 16:03
anybody interested in flip key ? This thread Refback 1st March 2008 02:03
RDX flip key - Page 5 - 8th Generation Honda Civic Forum This thread Refback 8th February 2008 18:34
www.clubhondacivic.com :: Ver tema - Llaves tipo espadín This thread Refback 5th February 2008 07:45
Search this Thread:
Advanced Search
Similar Threads for: Who wants a flip key?
Flip Keys pekwah1 Electronics 19 15th July 2007 22:53
Search Engine Friendly URLs by
