This thread is about: SNAKE, it's in General Discussion at the Honda Civic forum Civinfo; hi guys wonder if someone can put abit of light on my problem. when i drive my car on the motorway i have noticed the ...
Old 6th September 2006, 16:01   #1 (permalink)
john1509's Avatar
SNAKE
hi guys wonder if someone can put abit of light on my problem. when i drive my car on the motorway i have noticed the car like snakes and i have to correct it. its funny realy to pinpoint its all tho the steering goes light. it like when you have your boot full which makes the steering lighter its only happend twice now. but im thinking its me cos i had a 4x4 before the civic im thinking it might be the shock obsorbers that people on the forum is talking about so i dont know if anyone else has had this problem thanks john
john1509 is offline   Reply With Quote
Old 6th September 2006, 16:51   #2 (permalink)
elfa7's Avatar
Make sure your tyre pressures are correct. If they are correct , take it to the Dealer to check out.
Old 6th September 2006, 17:26   #3 (permalink)
Newboy's Avatar
must be a bit disconcerting. as elfa7 says, get it checked !!!!
Newboy is offline   Reply With Quote
Old 6th September 2006, 17:42   #4 (permalink)
john1509's Avatar
tx guys will check the tyre pressure if ok will phone the dealer
Old 8th September 2006, 12:21   #5 (permalink)
The Great Soprendo's Avatar
Don't want to underestimate what could be something else (so get it checked), but is it possible that it's just down to getting used to the characteristics of the Civic steering? From memory, it only has 2.2 turns lock-to-lock. My Alfa 156 has exactly the same - 2.2 - and I remember it being described once as having the fastest (ie shortest number of turns lock-to-lock) steering of any production car. As an aside, the Alfa also has a crap turning circle, whereas the Civic seems a bit more manouverable.
When I first got the Alfa I noticed that it's a bit jittery on motorways, with the steering often requiring correction. I always put it down to this fast steering, as even the slightest correct seems to turn the car noticeably. Since the Civic has a similarly ratioed steering system I didn't notice anything unusual when test driving it...I guess I got used to it with the Alfa.
One benefit of quick steering - you really feel like you can throw the car around like a go-cart (though the Civic rolls more than the Alfa, as you'd probably expect) and don't have to cross your hands during manoeuvres. It's particularly great on twisty roads out of town.
Alternatively I've got the total wrong end of this particular stick, in which case excuse my ramblings....
The Great Soprendo is offline   Reply With Quote
Old 8th September 2006, 13:33   #6 (permalink)
Although the quick steering doesn't help, I think the car is prone to tramlining, as any car with relatively firm McPherson strut front suspension and wide wheels does. Anyone know if the Civ has a good dollop of neg camber? The sharp cornering makes it feel like it does, and one side effect of neg camber is also tramlining.
Old 8th September 2006, 13:41   #7 (permalink)
I think you will find it is the steering.
Most other cars have a very small amount of play/slack in the steering i.e. your hands move the wheel very slightly - no directional change to car. However, what you will find is that the steering on the new Civic is so tight and responsive that it picks up even the slightest hand movements wich may have gone un-noticed in other cars, and the car seems to move slightly out of position.
Sorry if this is wrong, but just down to my own early observations when drivingit and watching others drive it.
Cheers, Brian
onboardtraining is offline   Reply With Quote
Old 8th September 2006, 14:27   #8 (permalink)
3rd Honda's Avatar
I agree that it is likely to be the 'quick' steering.....and made more noticeable due to the low profile tyres having quite stiff sidewalls, but also due to the dreadful 'grooving' that there is on some sections of motorway, especially in the left hand lane. This is most noticeable to the eye when the sun is low, but undoubtedly does affect the steering
Old 8th September 2006, 15:06   #9 (permalink)
allan40alt's Avatar
Is it possible for you to test another Civic on the same stretch of motorway to see if the same thing happens
Old 8th September 2006, 19:03   #10 (permalink)
john1509's Avatar
hi guys just a update on my prob took my car to the dealer today who went for a test drive. he said that the steering seems ok. around town but i said it happens on the motorway at speed. so i have to take it back on monday when he will test it at speed with the head mechanic can go with him as he was off today
Old 8th September 2006, 21:19   #11 (permalink)
12th June 2006 1.8EX
WoolyCiv's Avatar
Originally Posted by onboardtraining
Cheers, Brian
Totally agree. When I first collected the civic , my wife complained that she did't feel safe as I kept 'jerking all over the road like a learner'. Soon got used to it though and I would now find any other car totally unresponsive.
Old 11th September 2006, 22:23   #12 (permalink)
Enthusiastic Supporter
Miggins's Avatar
This is characteristic of wide low profile tyres - especially on the motorway where the HGV's have worn a track a bit wider than the Civics.
I've also found that tyre pressures are critical - just 2 psi over the recommended settings and the car gets very lively but this would be the case on all roads.
(no fun on a poor dipped beam at speed!)
