| This thread is about: Why the plastic tube attached to the screenwash cap???, it's in General Discussion at the Honda Civic forum Civinfo; Evening all, it's been awhile... So-I was filling (again..) the screenwash tank, and I was wondering why the cap is connected to a long piece ... | ||
So-I was filling (again..) the screenwash tank, and I was wondering why the cap is connected to a long piece of black, opaque ribbed plastic tubing My Espace was similarly equipped, but the tube was transparent and smooth- The idea being, I take it, that you would put your finger on the little hole in the cap, extract the tube, eyeball it, and this would give you a rough indication of the amount of screenwash left in the tank. However, the Civic's being totally opaque, it's purpose escapes me... Enlightenment, anyone? Cheers, Maxbert |
Hello Maxbert.
Not sure myself what it is for, it make sense to me though that it is some kind of air escape duct. However, there are some disagreement among the members on here what the purpose of it really is. See this thread: Low washer fluid |
Mange Tak (sp?) Amronno... That will teach me to use the Search function!
Still, it seems to remain a bit of a mystery... Maxbert |
#4 (permalink) | |
You are welcome! Very nice! Yeah, it is a bit of a mystery, we still need someone to enlighten us... Anyone |
Perhaps, but it still makes filling easier (and prevents the cap from falling). A dipstick doesn't make too much sense even if so intended by the manufacturer, if you have the bonnet open and the cap in your hand you may as well fill up
#11 (permalink) | |
Just pointed out what it was meant to be by the manufacturer as it was the question at first. |
#12 (permalink) |
Sorry, I don't buy either reasons
1. If it is to serve as an indication of quantity left, I put it to you that the Espace arrangement is superior, in that it worked (in the absence of a real, Honest-To-Goodness gauge or light on the dash)- A black ribbed tube which S-C-R-A-P-E-S as you pull it out will give a useless indication, unclear to boot! 2. Breather tube? Then the hole in the cap is all that's necessary, shurely Either way, poor design at best, unnecessary at worst (especially when the first filler bit falls off and you have to wedge it back in place, and no matter how you jiggle it, it still leaks screenwash on the forecourt Maxbert |
#13 (permalink) | |
A much better solution was in my old C5, a huge opening with a flip-cap, you could fill off a bucket without spilling anything (and had an onboard level warning but this again was cr@p) |
#14 (permalink) |
Yes, but yes, but yes, but NO, Civicfan...
I'm all in favour of a "Stop me losing the cap" solution, but if the purpose of the snaky black tube is just that, then sorry, but "Poor design" again... |
#15 (permalink) |
it's only for level indication. As the screenwash tank is very deep situated and the filling pipe has some curves, Honda has used this kind of indicator to give a reliable indication of the fluid left in the tank.
#17 (permalink) |
P@tje-
Misschien wel, maar het werkt niet!!! En het is heelmaal niet "reliable"! Mods- Don't panic, nothing rude or diffamatious (?) Cheers, Maxbert |
#18 (permalink) |
@Maxbert
well I can see where the fluid level is. The difference between wet and dry is clear visible. So for me it works. And if you can't see the level, it's empty |
#19 (permalink) |
Well it does serve one purpose. You can pull it out far enough to be able to fill up without completely removing the black tube but you don't lose the cap down the back of the engine.
Incidently the joint of the filler neck is total rubbish, resulting in washer fluid leaking all down the inner wing when filling up. Another example of something designed on a computer instead of in real life. |
#20 (permalink) |
yep - it's a dip stick. The corregated/ grooved tube hold water in the grooves and thus you can see the water level.
Used to use the clear tube with a hole on the cap to create the vacuum - some people had trouble with it - those not manually dexterous - and also due to the positioning of the tank vs the opening on the new car then the tube was somewhat longer than older models and thus this alternative method where you don't have to keep that finger on the top while extracting a mile of tube. There was also the doubt factor - is the tube empty cos the tank is or because I didn't hold my finger on the top properly. As to whether you check it or fill it. I check it frequently in bad weather when I fill up at the petrol station and thus I find it useful. |
| This You Tube just gets better! | Charles_Harding | Any non Civic chat here please! | 10 | 8th January 2008 11:38 |
| you tube | Cookie | Type-R | 6 | 10th September 2007 16:36 |
| 5th Gear you tube link | vikingskelhorn | Type-R | 1 | 9th May 2007 09:36 |
| Windscreen Adjusting screenwash jets? | Maxbert | Bugs, faults and irritations | 12 | 27th April 2007 14:10 |
| Washer bottle - tube - whats it for? | jonokimber | General Discussion | 14 | 24th April 2007 22:41 |
