This thread is about: Rear panel cracked, it's in General Discussion at the Honda Civic forum Civinfo; Crash, boom, bang, my bad. I was reversing into a tight parking spot in a shopping mall garage, and saw nothing in the reverse camera. ...
Old 25th January 2008, 09:19   #1 (permalink)
Skaven252's Avatar
Rear panel cracked
BANG! Aïe!
Turns out there was a horizontal concrete support beam just barely above the camera's view cone. I don't think parking sensors would have helped here, either, would they? The beam was so high up, and there was nothing beneath it (just an open gap to the lower floor of the garage).
Note to self: also check the rear view mirror when reversing.
I wonder what the spare part deal is in this case? Do I need to buy a full set of rear plastic parts, out of which only one gets replaced, or is this cracked part (see picture) available separately?
Skaven252 is offline   Reply With Quote
Old 25th January 2008, 10:13   #2 (permalink)
BigP's Avatar
The centre section can be replaced. Mine has been done due to water leaks which are still not fixed and is getting fixed again! but thats in another thread. No idea about cost tho.
BigP is offline   Reply With Quote
Old 25th January 2008, 10:18   #3 (permalink)
Vivid Blue Rocks!!!
Foggy69's Avatar
You can get the centre section of the reflector separately, but it's not cheap.
Holdcroft Honda are quoting £200 for the Type R version, and I would expect the standard one is very similar in price.
Old 25th January 2008, 10:23   #4 (permalink)
Type R GT 09570
It's an expensive mistake, but accidents do happen and it could have been worse, at least there's no panel damage.
Old 25th January 2008, 11:25   #5 (permalink)
heinc's Avatar
i had same with all rear ligths, dealer changed it for free
heinc is offline   Reply With Quote
Old 25th January 2008, 11:31   #6 (permalink)
You would actually be surprised what the rear sensors will pick up.
Mine even pick up higher than normal kerbs that would have grazed the underneath. Also had it pick up a barrier that was about the height of your damage.
Old 25th January 2008, 12:06   #7 (permalink)
Skaven252's Avatar
I took the car to the repair shop (which is conveniently located right next to where I work), and had it checked. They said it's not a serious problem (ie there are no electronics parts there that would get damaged by the moisture that gets under the panel - a relief), and that the spare part costs €320.35, and changing it costs €45. Thank goodness the camera wasn't damaged.
I'll get it fixed at some point then, I guess.
Old 25th January 2008, 12:07   #8 (permalink)
Skaven252's Avatar
That sounds pretty lucky, if it was an accident and not a manufacturing defect?
Old 25th January 2008, 13:19   #9 (permalink)
HACKIN & SLAYIN
So much fro the camera
Old 26th January 2008, 08:11   #10 (permalink)
Skaven252's Avatar
The camera wasn't damaged in the bump.
Or was your point to bash the camera because you have parking sensors yourself? What's the point of that? We both have a Civic, and that's all that matters, no? Besides, the camera puts the EX LCD display to better use than sensors would.
Old 26th January 2008, 09:36   #11 (permalink)
The camera can't see everything, neither can the sensors I would take the repair bill to the mall guys - there are norms for almost everything these days and this includes parking spots. If theirs is not norm-compliant they must pay for the damage, it's the same case as with damage to wheels by potholes
Similar Threads for: Rear panel cracked
rear door panel uk1simon General Discussion 4 13th November 2007 12:49
Car key encryption cracked by Belgian and Israeli university babyjoe General Discussion 9 30th August 2007 18:32
Speakers is there a 3 door rear speaker panel removal guide? andy dys Ipods, MP3 Players and ICE 1 27th March 2007 18:56
Lights cracked headlights???? Nickels Bugs, faults and irritations 1 20th February 2007 23:13
Windscreen Windscreen cracked by icy conditions!!! Fedorov Bugs, faults and irritations 21 20th February 2007 00:15
