This thread is about: Drilled Pedals On An SE???, it's in General Discussion at the Honda Civic forum Civinfo; Hi Does anyone know if drilled pedals come as standard on an SE? From the Honda site if you build a car it doesnt say ...
Old 27th February 2008, 17:32   #1 (permalink)
madslug's Avatar
Hi
Does anyone know if drilled pedals come as standard on an SE? From the Honda site if you build a car it doesnt say in the text but if you look at the internal pic it clearly shows ally drilled pedals. Also when I went to see an SE at the dealers when he showed me, what he said was an SE, it also had drilled pedals.
I have my SE on order and really would like the pedals.
madslug is offline   Reply With Quote
Old 27th February 2008, 17:34   #2 (permalink)
Coldwarkid's Avatar
As far as I can remember, no.
Coldwarkid is offline   Reply With Quote
Old 27th February 2008, 17:38   #3 (permalink)
sallytraffic's Avatar
On the Honda, 'build a car' section you will see that the 'Drilled Pedals' pops up as standard on the ES but not on the SE. Just hover your mouse between ES and SE models once you have picked Civic as the car of choice.
sallytraffic is offline   Reply With Quote
Old 27th February 2008, 17:41   #4 (permalink)
madslug's Avatar
But if you select the SE then view the interor it shows the pedals, I wont be happy, as I say even the dealer showed me an SE at that had them in
Also I have just discovered, in the build a car section once you've chosen the model and colour then goto the section where it say fact file / spec / equipment, click on equipment and there they are again listed under Comfort And Convinence
Old 27th February 2008, 17:45   #5 (permalink)
Esox Lucius Rules!!!!!!!!
They are an Extra on most 5dr models I believe, standard on the R & S though.
Old 27th February 2008, 17:47   #6 (permalink)
madslug's Avatar
Not sure thats the case Tom. They are deffo std on the ES and EX
Old 27th February 2008, 17:50   #7 (permalink)
Thats why I said 'most' (the 1.4, and basic 1.8/2.2's have them as extra's the better specced ones they come with I believe).
Old 27th February 2008, 17:56   #8 (permalink)
Right, I see what you mean I checked the 1.4 SE and that also showed what appeared to be drilled pedals. A bit like the ads where it is the 'invisible' print that tells you all the options the pictured car has and the big quoted price does not.
Looks like they were rather cavalier with the pictures.
It looks like the only way to solve this is to go to the dealer and pin him to the ground for an answer and get it in writing !
Old 27th February 2008, 17:59   #9 (permalink)
4th Honda
longitude's Avatar
My SE 2.2 does and I didn't have to pay extra. That was back in Sep 07.
longitude is offline   Reply With Quote
Old 27th February 2008, 18:10   #10 (permalink)
Well, the gods appear to have smiled and saved us, Honda are bit slapdash with their photo's sometimes (as are most car makers), adding extras and thing like the new Twingo I believe 7,995 in the add (or whatever), then read the small print car pictured 12,999 (or whatever), auto gear box bigger engine, all the bells and whistles, bit misleading really.
Old 27th February 2008, 18:29   #11 (permalink)
madslug's Avatar
Just been to the dealer again who says the SE does come with the pedals just doesn't have a foot rest, Wow talk about making savings, how much can a footrest be
Anyone else got the SE? What pedals have ya got?
Old 27th February 2008, 18:32   #12 (permalink)
Not a lot, but then, there's the holes. They don't come cheap
Glad you got a definitive answer.
Old 27th February 2008, 18:36   #13 (permalink)
madslug's Avatar
Oh yeah, I forgot the holes, I reckon 1 big hole would be much cheaper than all those little ones
He was a car salesman, do you actually believe what he tells you.
Old 27th February 2008, 18:40   #14 (permalink)
Surely if there are holes, you are getting less material, so it should be cheaper.
Old 27th February 2008, 18:44   #15 (permalink)
bounce75's Avatar
Hi Madslug, I own a 1.8 SE & I can confirm that it does have drilled pedals but not a drilled footrest. I believe the only model that does not have drilled pedals is the 1.4 SE.
bounce75 is offline   Reply With Quote
Old 27th February 2008, 18:47   #16 (permalink)
madslug's Avatar
Yipee, Im dancin around as happy as this pink elephant
Where do they get these icons.
Old 27th February 2008, 18:51   #17 (permalink)
I can confer...i sell the bloody things!
Variantealta is offline   Reply With Quote
Old 27th February 2008, 18:58   #18 (permalink)
4th Honda
longitude's Avatar
Not sure if this applies to all models but on my SE the pedals are chrome with holes but the holes are filled with black rubber studs for grip I guess.
Also there is a foot rest with the same studs but it is all black.
Old 27th February 2008, 19:05   #19 (permalink)
madslug's Avatar
Ahhhh, a footrest you say...on an SE.
Old 27th February 2008, 19:30   #20 (permalink)
Foggy's Avatar
My 2.2 SE is the same
Foggy is offline   Reply With Quote
Similar Threads for: Drilled Pedals On An SE???
Drilled Alloy Foot plate. jimbo Styling 23 18th April 2008 23:00
Aluminum Pedals lambic General Discussion 13 23rd June 2007 21:47
Trim At odds with the aluminium pedals... JB75 Bugs, faults and irritations 21 5th February 2007 19:21
Pedals BERT General Discussion 5 26th September 2006 23:19
Options Sports pedals Nadz Buying, Dealers and Servicing 8 19th September 2006 15:40
vB.
